Old Feb 12, 2013, 10:40 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
thanks fried
settings for the ice100 and bl32 would be low timing and 8 or 12khz pwm
jcdfrd is offline Find More Posts by jcdfrd
Old Feb 13, 2013, 12:32 AM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Quote
Bad ass video on 7 cells. Pardon me while I doppler those passes tonight. I am also going to 7 cells on stock
power. Anyone have the Ice 100 settings for stock?
Edit: BTW.. that pilot is very good.
Friedclutch,
Do you have the ambient temperature at flight time for your doppler analysis?
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Feb 13, 2013, 11:54 AM
sothpaw is offline
Find More Posts by sothpaw
Joined Jun 2012
Originally Posted by swps View Post
On my stock 7s (I've had 3 now) I've gone no heatsink, Tam's heatsink/CF Tailcone and a 28mm heat sink from Effluxrc. I can't tell the difference to be honest. I've run all three in the heat of summer and I've never had an issue.
I think in any case you need throttle management. Just realize that a 28mm motor isn't great from heat dispersion so even with a heatsink 7s is still stressing the motor. Fortunately, the E-flite motor is inexpensive and e-flite over engineers all their products so you should be good to go any way you decide.
7S sounds fine except...who sells a good, reliable 7S pack? And how do I balance charge it? I could sew together a 3S and 4S pack and have separate balance plugs and charging ports, but it'd be a mess and some hacking of the wires.
sothpaw is offline Find More Posts by sothpaw
Old Feb 13, 2013, 12:08 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
we use two packs 3s+4s and charge separate
swps is online now
Find More Posts by swps
Some Girls r Bigger thn Others
swps's Avatar
USA, UT, Cedar Hills
Joined Jun 2010
That's simple. A series connector and get a 3s and 4s or a 5s and a 2s set of packs. Ideally they would be of the same capacity, C rating and manufacturer. You can then charge each pack separately. Or if you want to spend some money on a new charger, my Hyperion i1420 will charge any combination of 2 packs up to a 14s pack. Or you can buy a 7s pack, Revolectrix would be my first choice but there are more and more becoming available, like Zippy Compacts. Then again you'd need a charger that is capable of charging a 7s pack, like the Hyperion.
swps is online now Find More Posts by swps
Old Feb 13, 2013, 01:02 PM
BadLemon is offline
Find More Posts by BadLemon
Just having fun before I die!
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
I have a question for the guys that have installed the Stumax 80mm unit what kind of speed do you get using a Stumax? I have the PNP 80mm with a Het 700-60-1735Kv motor. I'll be using an ice 100amp esc. I have several 4400mah 45c packs to make either a 6s or 7s packs other then that the rest of the Habu will be stock with retracts.
BadLemon is offline Find More Posts by BadLemon
Old Feb 13, 2013, 01:18 PM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
I never could get a Doppler on my 12s Stumax 80. It had some kind of strange whistle which threw off the readings. (This could have been my rebuilt intakes. Don't know)
I'd say a good bit faster than stock. But that's a guess. i never flew stock.
I was at 3K watts at 70 amps on 12S.
After getting the fan balanced how I wanted, it flew very well and sounded good.
Michael Paxton is offline Find More Posts by Michael Paxton
Old Feb 13, 2013, 01:28 PM
Nashville TN.
Joined Mar 2006
Here's a couple passes that got filmed. One on maiden, and one after rebuild and rebalancing fan.
http://www.rcgroups.com/forums/showt...6#post24124586
Old Feb 13, 2013, 01:35 PM
BadLemon is offline
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
I guess it could be hard get get doppler on a quiet fan setup. so an onboard speed indicator or a radar gun would need to be used. I'm sure your setup is topping out better then a 2.5k watt setup what is your outlet diameter on the thrust tube?
Thanks for the input.
Old Feb 13, 2013, 01:43 PM
Nashville TN.
Joined Mar 2006
I had the thrust tube the same diameter as the fuses exit. Don't remember what that was. ???
Old Feb 13, 2013, 04:27 PM
efflux RC's Avatar
Joined Aug 2009
We use two packs in series for anything more that 6s, (7s-12s)
Site Sponsor
Old Feb 13, 2013, 05:02 PM
whisperdancer is offline
Find More Posts by whisperdancer
Portugal, Porto District, Maia Municipality
Joined Aug 2008
Anyone knows what is the amp draw on a stock 7s setup?
whisperdancer is offline Find More Posts by whisperdancer
Old Feb 13, 2013, 06:00 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
let me check with Nick but I think its in the 80-90amp range
ok Nick has chimmed in...... 90-93amps 2300-2400watts 45,400rpm
Old Feb 13, 2013, 08:37 PM
Friedclutch is offline
Find More Posts by Friedclutch
Got Brushless?
Friedclutch's Avatar
Sacramento
Joined Sep 2007
Doppler temps
Friedclutch,
Do you have the ambient temperature at flight time for your doppler analysis?[/QUOTE]
At the beginning of the video the camera man states at the ambient temp is 55 deg f. I should have the readings ready tonight.
Friedclutch is offline Find More Posts by Friedclutch
Old Feb 13, 2013, 08:46 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
friedclutch
glad to see your paying attention
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
