Old Jan 28, 2013, 09:04 PM
Friedclutch is offline
Find More Posts by Friedclutch
Got Brushless?
Friedclutch's Avatar
Sacramento
Joined Sep 2007
Not knocking Hysol because I have not used it... But... I have not had epoxy fail. Not since I started R/C planes in 1992. I fly 100cc giant scale. All my IMAC buddies fly 100cc to 200cc. All of us use 30 min epoxy. (also used it to build my H-32) What does Hysol do that warrants switching? Just curious.
Friedclutch is offline Find More Posts by Friedclutch
Old Jan 28, 2013, 09:08 PM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
If you don't prep the parts properly, it doesn't matter what you use, it can come de-bonded. Make sure you give the horns a sanding at the bonding area to remove the "blush" which will prevent the glue from keying in.
jayb1rdz is offline Find More Posts by jayb1rdz
Old Jan 28, 2013, 09:33 PM
dennisjm is offline
Find More Posts by dennisjm
Proud RC Addict
United States, UT, American Fork
Joined Nov 2009
+1 you can scrape hysol off a smooth plastic as easy as anything else.
dennisjm is offline Find More Posts by dennisjm
Old Jan 28, 2013, 09:39 PM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Hysol is thixotropic meaning it is thick and does not run. It has a very high sheer strength too. I used Vpoxy to glue the horns. It dries quicker than hysol and is clear too.
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Jan 29, 2013, 01:36 AM
Tealc is offline
Find More Posts by Tealc
United States, OR, Portland
Joined Aug 2011
response
No reason for switching on the Habu. Just asking to see what some of you thought. I was considering trying it on the control horns because I have heard it stays where you place it and does not run like normal 30 min epoxy. This is the reason that it is recommended for use on my other project.
Yes, I know that a sanded and clean surface is needed for adhesives to work right. Was planning on doing that anyway. It has been a while since I have read the manual, but I believe it calls for 5 min epoxy. I was going to mix up 30 min and use that but thought since I need to order some Hysol anyway I thought why not give it a try.
Tealc is offline Find More Posts by Tealc
Old Jan 29, 2013, 07:53 AM
ZACATTACK is offline
Find More Posts by ZACATTACK
ZACATTACK's Avatar
Canada, ON, Hamilton
Joined May 2011
Very Simple....Tensile stregth of Hysol is 3200 PSI + with an operating teperature to - 67* to 140*......5 min expoxy cannot touch those numbers, I believe tensile strength is 2400-2500 PSI and temperature failure of 5 Min epoxy is no where near those temperatures...You get what pay for with Hysol and includes peace of mind.
ZACATTACK is offline Find More Posts by ZACATTACK
Old Jan 29, 2013, 08:05 AM
dennisjm is offline
Proud RC Addict
Joined Nov 2009
The tension on the control horns is no where near those numbers either. The manual says use 5 min epoxy and it works fine for thousands of people that used it there.
Again, you won't be disappointed with Hysol. It's good to mix a bit up and see how it mixes/dries reacts anyway before your other project. I'd just hate to see people recommending it for an application that doesn't really need it. You have to order it since you can't just grab a pack at the LHS (any I know of anyway). You have to wait a day for it to dry. It costs $15 + shipping for every pack. So yeah, if you have some go right ahead if you feel the need. I used epoxy regardless even though I have it.
OK... enough... back to your regularly scheduled show now
Old Jan 29, 2013, 11:43 AM
houstonderk is offline
Find More Posts by houstonderk
United States, MD, Clinton
Joined Oct 2010
Got my wheel air brakes working after acouple of hours. Found out that the pin in the block that has the o-rings to hold the air in was in backwards... :/ Spun it around and everything works as should.
houstonderk is offline Find More Posts by houstonderk
Old Jan 29, 2013, 05:36 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Nothing wrong with epoxy, the Habu is made with it isnt it?
Extreme_RC is offline Find More Posts by Extreme_RC
Old Jan 29, 2013, 05:52 PM
ZACATTACK's Avatar
Joined May 2011
Cannot comment any further on adhesives for we are back to our regular scheduled program....
Old Jan 29, 2013, 07:51 PM
jimmy34256 is offline
Find More Posts by jimmy34256
Destructive Tester
jimmy34256's Avatar
Tampa, FL
Joined Apr 2008
and now for something completely different....
jimmy34256 is offline Find More Posts by jimmy34256
Old Jan 29, 2013, 09:11 PM
Jetnfast is offline
Find More Posts by Jetnfast
Jetnfast's Avatar
United States, CA, Temecula
Joined Feb 2008
Post some pics of your setup. Not sure if many guys have wheel air brakes on the Bu.
Jetnfast is offline Find More Posts by Jetnfast
Old Jan 29, 2013, 10:34 PM
Tealc is offline
Joined Aug 2011
Any one managed to get the brakes from shulman aviation to work with Tam's gear.
Old Jan 30, 2013, 02:58 AM
SmokeDogg is offline
Find More Posts by SmokeDogg
"Fly Low, Fly Fast, Turn Left"
SmokeDogg's Avatar
United States, CA, Red Bluff
Joined Jul 2009
I put a set on my reaction and love them. The p-38 and habu are next!
SmokeDogg is offline Find More Posts by SmokeDogg
Latest blog entry: Miss Foxy Lady eBuild
Old Jan 30, 2013, 03:03 AM
Joined Oct 2010
Someone tried and mentioned the pin was slightly larger than the diameter of the hole on the tamjet struts...
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
