Eric,
That looks great! Josh |
Latest blog entry: VIDEO: Real Helicopter Rescues Hangar 9...
Here's the thing with "100 amp" ESCs.....
The castle ICE 100 ESC's burst current is 170A. The budget brands are all around 120A.. That's a HUGE difference. ![]() The higher amp rating means the ESC will alway run cooler under all circumstances. We put Castle ICE 100s in all our Habu32s. (100 or 120HV depending on the cell count) They are placed between where the ducts converge inside the cockpit. (some with the bulky plastic cover removed and the heat sinks expoxied together) This also eliminates the need for added battery wire length and the use of additional caps. I have never had a problem the Castle ESCs in the 5 Habus that I've built. They are all 150-160mph birds. ........................................... Eric Clark, Your jet looks great. My eyes are too old to detect orientaion of that color that blends into the sky. You might consider adding a wide yellow band to one wing if it's a problem at long distances. Just my .02$
Joined Oct 2012
Thanks for all the great tips on the thrust tube. I'll get it taped up. Now just have to appropriate a spoon from my wife's kitchen!!
Sold this plane RTF for 1200.00 after 100 flights with no issues. And the buyer is still flying her to this day. I have built over 27 of these for Tamjet Customers...Ive used HS5085's, HS85mg's, JR servos, HS82mg's...it all in the setup...if you take your time all these will work. The only small servo I used was a HS65 HB, yes not even metal geared, for the nose door. Work perfectly every time. James AKA...The habu master. |
HW's Platinum PRO ESC range is made with some of the highest spec FET's and ancillary components available, their 100A ESC is rated 150A short term, IE 30 seconds, not burst, and I run the ESC at 100-110A constant while pulling on the inbuilt BEC with 7 servos.
The Platinum 150A opto is good for 220A short term, and is super tough. These ESC are used around the world by thousands of flyers, I have never had one issue with their product. |
| Thread Tools | |
| Discussion Fiberglass Habu Airframe | Calvin_220 | Electric Ducted Fan Jet Talk | 92 | Nov 10, 2012 02:53 AM |
| Sold New in box Habu EDF PNP | flyboy1945 | Aircraft - Electric - Jets (FS/W) | 2 | Aug 01, 2010 08:24 PM |
| Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread | SalamSyed | Foamy EDFs | 0 | Mar 20, 2010 11:15 PM |
| New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer | nitroplanes | Nitro Planes | 0 | Jan 24, 2009 09:58 AM |
| Discussion Baja SS Speculation and hopup thread. | DaveESPI | Large Scale Cars | 3 | Feb 03, 2008 07:39 PM |
