Taiwan, 北市
Joined Dec 2008
Kevin |
United States, ME, Wells
Joined May 2008
Long Flat Glide: Key
The reason I employ crow is that one approach end has trees that already ate another pilots Habu 1 (original foam version) and the trees are close enough that you have a very short distance to lose about 80' or thereabouts. Even with full flaps, there is still too much speed if one dives to lose the altitude.
With crow, however, the descent angle can be steeper, but you have to be comfortable with adding throttle to arrest the vertical sink rate; easily learned, IMHO. The other end has trees farther away, so a flat approach should work. However, even very experienced pilots have lost their models on a long flat approach because of the visual effect of the trees; especially with a small model such as ours. Also, and I was surprised by this, the dark red color does not stand out against a field of trees. So, I use the same approach on both ends. Michael Quote:
We carry the SAPAC Viper struts. They are a great product and will be offering them (along with the new electric retracts and brakes)for our new full composite F-20 as well.
Buuuut... The SAPAC struts are for a 5lb MAX aircraft. (70mm) and not adequate for the 7-8lb Habu 32. You might be able to bet a proper bushing size to replace the bearing in the SAPAC rims. You could possibly drill out one the bushings from these wheels, or get a bronze bearing from McMaster Carr I'll look into it. ![]() Tamjets has a Wheel/Brake kit for the Habu 32. |
| Thread Tools | |
| Discussion Fiberglass Habu Airframe | Calvin_220 | Electric Ducted Fan Jet Talk | 92 | Nov 10, 2012 02:53 AM |
| Sold New in box Habu EDF PNP | flyboy1945 | Aircraft - Electric - Jets (FS/W) | 2 | Aug 01, 2010 08:24 PM |
| Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread | SalamSyed | Foamy EDFs | 0 | Mar 20, 2010 11:15 PM |
| New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer | nitroplanes | Nitro Planes | 0 | Jan 24, 2009 09:58 AM |
| Discussion Baja SS Speculation and hopup thread. | DaveESPI | Large Scale Cars | 3 | Feb 03, 2008 07:39 PM |
