Old Dec 18, 2012, 08:26 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Southpaw7890,
We stock the SAPAC gear as well. They are good for up a 5lb aircraft.
The Habu 32 is 7.5+ lbs depending on the set up.
I suggest Tams trailing link struts. They will be back in stock by the end of the week.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Dec 18, 2012, 08:30 PM
jimmy34256 is online now
Find More Posts by jimmy34256
Destructive Tester
jimmy34256's Avatar
Tampa, FL
Joined Apr 2008
Originally Posted by efflux RC View Post
Southpaw7890,
Mine is coming in at 9lbs.....
Jetfan 80 with HET, ICE 120HV, 2x 5s 3300mah and the Tam struts....
jimmy34256 is online now Find More Posts by jimmy34256
Old Dec 18, 2012, 09:33 PM
efflux RC's Avatar
Joined Aug 2009
Why so heavy?
My 10s Habu has a Mach 80 ALL ALLOY EDF, 10s, 40c,4000's, ICE 120HV, a dedicated 800mAh, 30c Lipo and CC BEC for rx power, and full gear doors. No Tam's struts on this one yet.
AUW: 8.5 lbs
Top speed: 161 mph
Site Sponsor
Old Dec 18, 2012, 10:03 PM
Castel101 is offline
Find More Posts by Castel101
Castel101's Avatar
United States, OR, Portland
Joined Sep 2011
Those might work although they are $99. I would check with Don @ Shulman aviation, the retract kit for the Habu is $175 but the struts alone are around $55 I think. i would email him for the exact strut kit for the Habu-32... Worth a try?
shulmanaviation.com/product_info.php?cPath=311_312_319&products_id=279 6
Another option is Tam's of course, but pricier.
Castel101 is offline Find More Posts by Castel101
Old Dec 18, 2012, 11:28 PM
ZACATTACK is offline
Find More Posts by ZACATTACK
ZACATTACK's Avatar
Canada, ON, Hamilton
Joined May 2011
9 Pound Habu!! Wish my wife could have one of those...I would help in the delivery too!! Thats one FAT Habu...Gotta get that weight down!!
ZACATTACK is offline Find More Posts by ZACATTACK
Old Dec 18, 2012, 11:43 PM
kchen95 is online now
Find More Posts by kchen95
Taiwan, 北市
Joined Dec 2008
Sorry might be another very dumb question - if I use a separate RX battery (6.6V,1100mah LiFe), how can I tell when I've run out of battery? Is it like the main LiPo pack where you would stop at a certain voltage level (around 3.7V or 3.8V)? If so, what's the level for an RX LiFe pack?
Kevin
kchen95 is online now Find More Posts by kchen95
Old Dec 19, 2012, 12:08 AM
ZACATTACK's Avatar
Joined May 2011
Kevin
Fly your Jet for 3 Flights....Charge the pack...determine how many Mah you put back in...You now know how many Mah you use each flight. Life packs drop to 6.6 v and stay there until they fall dead.... Like a cliff.... http://manuals.hobbico.com/hca/lifesource-manual-v2.pdf Read!!
Old Dec 19, 2012, 12:15 AM
Taiwan, 北市
Joined Dec 2008
OK tks! I guess the question is, is there a general rule on WHEN the LiFe falls from 6 6V to dead? Like how many Mah can I safely burn up without risking getting this point?
Kevin
Old Dec 19, 2012, 05:27 AM
bdelapen is offline
Find More Posts by bdelapen
Sponsored by Team de la Peņa
bdelapen's Avatar
United States, FL, Pembroke Pines
Joined Aug 2008
Kevin
As this is the lifeblood of your plane I never take LiFe beyond 50% of their capacity before re-charging. As stated above, you don't want to hit that cliff.
Example, If I have a 2300mAh LiFe and I take about 200 per flight I will do no more than 5-6 flights before re-charging.
- Birger
bdelapen is offline Find More Posts by bdelapen
Old Dec 19, 2012, 06:57 AM
Taiwan, 北市
Joined Dec 2008
- Birger
Got it tks!
Kevin
Old Dec 19, 2012, 09:50 AM
Southpaw7890 is offline
Find More Posts by Southpaw7890
Southpaw7890's Avatar
Joined Dec 2012
Thanks for the suggestions !
Any major modifications needed or do these just kinda drop right in? I figure a littl finessing and widening may be nessecary, but other than that?
Southpaw7890 is offline Find More Posts by Southpaw7890
Old Dec 20, 2012, 04:42 PM
420flyboy is offline
Find More Posts by 420flyboy
Mile High EDF
420flyboy's Avatar
United States, CO, Denver
Joined Jul 2011
Latest Habu coming along
Jetfan 80
HET 1680kv
Castle 120hv
Going for 8s to start again and then 10s. Fully closing front gear door and Gary's carbon fiber doors for the mains.
I have telemtry running, so no guess work while flying
420flyboy is offline Find More Posts by 420flyboy
Old Dec 20, 2012, 06:13 PM
Destructive Tester
jimmy34256's Avatar
Tampa, FL
Joined Apr 2008
What is your weight with battery on the setup?
Jetfan 80
HET 1680kv
Castle 120hv
Old Dec 20, 2012, 06:19 PM
Mile High EDF
420flyboy's Avatar
Joined Jul 2011
Not fully built yet ,
I'm waiting on motor and lipos
I'm running Tams gear also , but with 8s and 10s it's the same . The 8s is 5000mah and the 10s is 4000mah . My last 8s was around 8 1/4 lbs , I think
When this one is fully put together I'll weight it and post results .
Old Dec 21, 2012, 01:05 AM
ellzy_21 is offline
Find More Posts by ellzy_21
United States, TX, Wichita Falls
Joined Nov 2011
Hey guys,
For those of you using the jetfan 80 systems, does ejets balance the fan unit w/motor for you or do you have to do that on your own? If so what does it entail? I'm new to this, but really want the jetfan....just wondering if I'd be able to pull it off or not. I know tam and stu do with their units if you buy the combo, but was curious about the jetfan.
ellzy_21 is offline Find More Posts by ellzy_21
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
