Old Nov 30, 2012, 11:39 AM
Robert Belluomini is offline
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Originally Posted by Tealc View Post
Jetnfast, thanks for the input. I was planning on building as light as possible. Thinking of doing the S-Bus setup with wires to see if that would save some weight instead of having all the extentions. But the cost is what is keeping me from that setup at this time. Once I get the time to start building I will make the decision then. I already have all the extentions, so that is what I might do. I just don't like seeing the bundle of wires in the fuse like I have seen in some of the pictures. Just looks like a bunch of weight that could be reduced. Anyway, I just need to get struts coming. Wife says I have to wait on the batteries and struts. Hoping to have it completed for spring.
S-Bus was designed to simplify the install and eliminate errors when plugging the servos in. I don't think you'll see any significant weight savings. You'll incur a bit more initial expense buying the programmer for your S-Bus servos.
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Nov 30, 2012, 11:43 AM
swps is online now
Find More Posts by swps
Some Girls r Bigger thn Others
swps's Avatar
USA, UT, Cedar Hills
Joined Jun 2010
Originally Posted by kchen95 View Post
Sorry if I'm missing something extremely obvious, but on the E-Flite Habu page where there's a link to download the DX8 setup for the Habu, I can't seem to figure out how to download successfully. All I get when I download is the following text:
Fly the Habu 32 with E-flite's very own David Payne's settings. The setting includes a separate nose gear steering channel on the Aux 3 knob that also has a dual rate on the mix channel.
Works for item:
EFL8075
Can someone show me how to actually acccess the setup? Thanks so much!
Best,
Kevin
Go to the spektrum site, log in where you registered your DX8 and you can download it there.
swps is online now Find More Posts by swps
Old Nov 30, 2012, 01:58 PM
Tealc is offline
Find More Posts by Tealc
United States, OR, Portland
Joined Aug 2011
I know...not a large weight savings. I was just thinking the cleaner setup would be nicer. One wire running from receiver out to all the servos instead of a bunch of wires that work their way back to the receiver. I am thinking of changing thing up simply because the cost of s-bus but it would take one of my small 3channel s-bus receivers and allow me to use up to 18channels or in the case of my radio 14 channels. Then I would not have to use any Y's. For now I do have an 8 channel receiver not being used. So, I will probably use that and go with all the extensions that I have currently. Ashlok connectors for the wings are in consideration, since I will have to remove wings for transporting. This was the main reason for considering S-bus. One wire going to each wing instead of three. The Ashlok connector would give me only one connection to plug and unplug for the wing. Anyway thanks for the input.
Tealc is offline Find More Posts by Tealc
Old Nov 30, 2012, 02:40 PM
Joined Dec 2000
The etracts won't work on the S-Bus. Which Tx are you using?
Old Dec 01, 2012, 03:25 AM
Tealc is offline
Joined Aug 2011
Futaba
8FG with Super upgrade. Thought I might add... I believe the etracts would work with s-bus if using one of the SBS-1 decoders. Which I was going to have to use for the Hitec servos anyway. But at about $50.00 a piece I think I will use what I have.
Old Dec 01, 2012, 09:44 AM
kchen95 is offline
Find More Posts by kchen95
Taiwan, 北市
Joined Dec 2008
Tks! That worked - it's amazing that all the settings can be automatically transferred to the transmitter via the SD card!
I just reviewed all the Horizion Hobby Habu DX8 settings and while most of them make sense, I'm not sure about two of them:
1). The elevator D/R function screen has different % expo's for the left and right side on the screen - I assume this is for different % of expo when the elevator moves up vs. down?
2). I notice that Horizon Hobby has programmed two mixes (mix 1 and mix 2), but both mixes seem to be rudder to Aux3 (nosegear), with the only difference being mix 1 is 50%, activated by the gear switch and mix 2 is 60%, activated by mix 1. Having one rudder-Aux 3(nosegear) mix makes sense to me, but what's the purpose of having two rudder-Aux 3 mixes, with mix 2 being activated by mix 1?
Thanks again for all the great advice!
Kevin
kchen95 is offline Find More Posts by kchen95
Old Dec 01, 2012, 07:45 PM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
On the nose gear mix is it a negative number? As in turning off steering while in the retracted position?
Michael Paxton is offline Find More Posts by Michael Paxton
Old Dec 01, 2012, 11:25 PM
kchen95 is offline
Taiwan, 北市
Joined Dec 2008
Both mixes are positive numbers. Here are the settings for both:
Mix 1:
rudder to aux 3 (nosegear)
rate 50% 50%
offset 0%
trim Inh
Switch: Gear0
Mix 2:
rudder to aux3 (nosegear)
rate 60% 60%
offset 0%
trim Inh
Switch: mix1
I'm not just sure why there needs to be two mixes going from rudder to aux 3/nosegear?
Kevin
Old Dec 02, 2012, 11:19 AM
Nashville TN.
Joined Mar 2006
Seems to me the first one is "steering on" and the second is a increase in steering response for maybe taxiing?
Old Dec 02, 2012, 10:19 PM
kchen95 is offline
Taiwan, 北市
Joined Dec 2008
Yeah that's my best guess at this point as well
Kevin
Old Dec 04, 2012, 08:41 AM
DamonH is offline
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
Does anyone have a DX8 file that includes a crow mix/function that they would be willing to share? Thanks.
DamonH is offline Find More Posts by DamonH
Old Dec 04, 2012, 11:42 AM
Quandry is offline
Find More Posts by Quandry
Ireland, Co. Dublin, Dublin
Joined Feb 2012
This link may help:
http://www.rcparkflying.com/radio-co...a-spektrum-dx8
Quandry is offline Find More Posts by Quandry
Old Dec 04, 2012, 03:48 PM
Joined Dec 2000
You are correct they will work with that decoder.
Use these S-Bus Servos instead of the Hitec servos then you will use std S-Bus hubs which are less expensive.
Old Dec 07, 2012, 08:27 AM
sompop is offline
Find More Posts by sompop
BelgiŽ, Vlaams Gewest, Oostende
Joined Sep 2007
first two flights with Habu 80mm Ejets on 2185KV 6S 5000mAh 45C
http://www.youtube.com/user/edfbhoor
sompop is offline Find More Posts by sompop
Old Dec 07, 2012, 08:36 AM
ysolomon is offline
Find More Posts by ysolomon
Another one on the way...
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
Just bought one.
ysolomon is offline Find More Posts by ysolomon
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
