Old Nov 23, 2012, 12:35 AM
Boston Bob is online now
Find More Posts by Boston Bob
United States, MA, Salem
Joined Jul 2011
What's the best way to tint?
Boston Bob is online now Find More Posts by Boston Bob
Old Nov 23, 2012, 02:59 AM
vasek is offline
Find More Posts by vasek
Joined Nov 2003
Dip it in hot water with dye! make some tests with a scrap piece as to the ideal temp & dip duration.
You could also use the spray tint used in RC cars (from the inside).
Both work well.
Cheers, V.
vasek is offline Find More Posts by vasek
Old Nov 23, 2012, 07:17 AM
HP^Matt is offline
Find More Posts by HP^Matt
United States, IL, Oquawka
Joined Nov 2003
What affordable options are available for the stock E-flite retracts in the brake deptartment?
Matt
HP^Matt is offline Find More Posts by HP^Matt
Old Nov 23, 2012, 09:37 AM
nippaero is offline
Find More Posts by nippaero
nippaero's Avatar
United States, ID, Nampa
Joined Oct 2009
Use RC car tint. It's made to spray on the inside of car bodies.
http://www.testors.com/products/573707
nippaero is offline Find More Posts by nippaero
Old Nov 23, 2012, 12:01 PM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
Matt
Added toe in.
You may have seen some advice from others to me to help tame the squirelling on the takeoff roll. The adding of toe in also helps slow the model on landing.
jayb1rdz is offline Find More Posts by jayb1rdz
Old Nov 23, 2012, 12:15 PM
HP^Matt is offline
Joined Nov 2003
Originally Posted by jayb1rdz View Post
Added toe in.
Ahhhh, makes good sence! Thanks
Old Nov 24, 2012, 12:42 PM
raptor30se is offline
Find More Posts by raptor30se
United States, WV, Huntington
Joined Nov 2005
Elevator alignment
Are you guys measuring from the top of the verticle stab to the edge of the horizontal stab to get correct alignment? There is wiggle room in both and too hard to eyeball off the wing.
raptor30se is offline Find More Posts by raptor30se
Old Nov 24, 2012, 05:16 PM
gsm026 is offline
Find More Posts by gsm026
United States, CO, Loveland
Joined May 2008
raptor30,
Yes, I used a piece of string (non-stretching) to match the distance from the stab tips to the top of the vertical. I had to drift both pin holes on one side to get the alignment pins to match the holes.
gsm026 is offline Find More Posts by gsm026
Old Nov 26, 2012, 08:19 PM
Tealc is offline
Find More Posts by Tealc
United States, OR, Portland
Joined Aug 2011
What is the mAh rating of the batteries you guys have been using.? I have been planning on using stock motor and fan but with 7s and Tams heatsink. Just trying to see what size batteries to get since I am in need of batteries. Is 5000mAh to large or should I look at something around 4400mAh? What flight time can I expect with 4400mAh vs 5000mAh? Thanks, Todd
Tealc is offline Find More Posts by Tealc
Old Nov 26, 2012, 09:42 PM
Jetnfast is offline
Find More Posts by Jetnfast
Jetnfast's Avatar
United States, CA, Temecula
Joined Feb 2008
I'm running a 6s 5300 30C gens ace pack on my stock habu. With decent throttle management I can fly 5 min and still have 40% capacity left in the pack. A 4000-5500 mah pack Would probably work best for a 6-7s battery.
I have a tams heatsink and tail cone I plan on dropping in my habu for next summer so I can fly in the heat of the day since the ice lite will be in the tailcone. I might even pick up a 7s pack like you and push the stock setup a little more just for fun.
Have you flown yours on 7s? How is the run time? Supposedly it also helps out with the CG by placing tams tailcone and the ESC further aft behind the motor. That makes sense because right now I have about 1.5oz in the tail to keep it balanced, and I still think it flies a touch nose heavy.
Jetnfast is offline Find More Posts by Jetnfast
Old Nov 26, 2012, 11:09 PM
Tealc is offline
Joined Aug 2011
No have not flown on 7s. Still in the building/gathering parts stage and waiting on some parts to come in. I have read that many here recommend flying stock with 6s first. But with our field and the not so smooth surface, I thought the extra go go power would help to get it in the air quicker. Looking to get Tams struts as well since I have regularly bent wire struts on planes. For planes with more weight it just makes sense to go to good struts with the lumps that plague our landing strip. Todd
Old Nov 27, 2012, 07:39 AM
Jetnfast is offline
Jetnfast's Avatar
Joined Feb 2008
All valid concerns you have...I would say 7s with the upgraded struts would be your best bet, or a light 6s setup with upgraded struts. Bottom line, either less weight or more thrust to help deal with less than ideal field conditions.
Old Nov 27, 2012, 06:24 PM
Tealc is offline
Joined Aug 2011
Jetnfast, thanks for the input. I was planning on building as light as possible. Thinking of doing the S-Bus setup with wires to see if that would save some weight instead of having all the extentions. But the cost is what is keeping me from that setup at this time. Once I get the time to start building I will make the decision then. I already have all the extentions, so that is what I might do. I just don't like seeing the bundle of wires in the fuse like I have seen in some of the pictures. Just looks like a bunch of weight that could be reduced. Anyway, I just need to get struts coming. Wife says I have to wait on the batteries and struts. Hoping to have it completed for spring.
Old Nov 27, 2012, 08:03 PM
Jetnfast is offline
Jetnfast's Avatar
Joined Feb 2008
I bundle my wires with zip ties, then I have one bundle that is routed through one of the two openings towards the front where I have the reciever. It looks fairly neat and tidy. I know, I am the same way!
I am not too familiar with an S-bus setup, but I think the added weight of the wires would be negligable. If you can run Tam's tailcone and ESC setup, that should save you a few ounces and help the CG, and if you ran on 6s, be nice and light. I need to do that mod before next summer, hopefully I get to it in the next few months, but honestly, my Habu is flying so well right now I dont want to touch anything!!
Old Nov 30, 2012, 10:51 AM
kchen95 is offline
Find More Posts by kchen95
Taiwan, 北市
Joined Dec 2008
Sorry if I'm missing something extremely obvious, but on the E-Flite Habu page where there's a link to download the DX8 setup for the Habu, I can't seem to figure out how to download successfully. All I get when I download is the following text:
Fly the Habu 32 with E-flite's very own David Payne's settings. The setting includes a separate nose gear steering channel on the Aux 3 knob that also has a dual rate on the mix channel.
Works for item:
EFL8075
Can someone show me how to actually acccess the setup? Thanks so much!
Best,
Kevin
kchen95 is offline Find More Posts by kchen95
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
