Old Nov 08, 2012, 09:28 AM
420flyboy is offline
Find More Posts by 420flyboy
Mile High EDF
420flyboy's Avatar
United States, CO, Denver
Joined Jul 2011
Thinking your right on the 1400kv and bigger motor , better balance .
Here it is on 8s jetfan80 1680kv . Cg still too far forward , much better at 115mm.
habu 32 jetfan80 8s (6 min 52 sec)
Just skip to 1:27, lol
420flyboy is offline Find More Posts by 420flyboy
Old Nov 08, 2012, 10:10 AM
dennisjm is offline
Find More Posts by dennisjm
Proud RC Addict
United States, UT, American Fork
Joined Nov 2009
I have an issue with my tamjet mains. The angle of the spring connection seems to loose tension just about 1mm before the wheel has straightened all the way. It seems the spring is still tight but it's not pulling any more as the tensioner hole is now rotating perpendicular to the spring. Hope that makes sense. Anyway, the net effect is that they lack about 1mm to fully straighten and that causes them to bind sometimes with the wheel well when they retract. Annoying at the least if not harmful to the retract over time.
Any suggestions?
dennisjm is offline Find More Posts by dennisjm
Old Nov 08, 2012, 11:35 AM
Mile High EDF
420flyboy's Avatar
Joined Jul 2011
Any suggestions?
Any pics , here's what mine looks like .
Old Nov 08, 2012, 11:57 AM
dennisjm is offline
Proud RC Addict
Joined Nov 2009
OK, pic 1.. how the strut ends up
pic 2, how I wish it would end up.
with the slight angle in pic1 the wheel hits the wheel well and the retract buzzes then gives up. Just ever so slightly but enough to catch.
Old Nov 08, 2012, 12:00 PM
Mile High EDF
420flyboy's Avatar
Joined Jul 2011
I think your spring has weakened , I would try to bend it slightly or replace. Mine pulls tight against the strut.
See how tight they are new.
Old Nov 08, 2012, 12:02 PM
Castel101 is offline
Find More Posts by Castel101
Castel101's Avatar
United States, OR, Portland
Joined Sep 2011
It seems all you need to do is replace the springs. I bet if you contact Tam with the pictures he will supply you with a new one to try. Maybe the plane was sitting on the wheels for a looong time?
Castel101 is offline Find More Posts by Castel101
Old Nov 08, 2012, 12:03 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
remove 1 or 2 coils from the spring if you want to correct that issue. easier said than done those springs are strong!
jcdfrd is offline Find More Posts by jcdfrd
Old Nov 08, 2012, 12:04 PM
swps is offline
Find More Posts by swps
Some Girls r Bigger thn Others
swps's Avatar
USA, UT, Cedar Hills
Joined Jun 2010
Any suggestions?
Dennis,
I think this is a known issue with Tam's Struts and he makes a maintenance kit for them.
Aaron
swps is offline Find More Posts by swps
dennisjm is offline
Proud RC Addict
Joined Nov 2009
Perhaps I just order the maintenance kit??
http://www.tamjets.com/original/prod...roducts_id=579
Old Nov 08, 2012, 12:05 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
+1
Tam will take care of you, but it would be quicker/easier to just remove a coil or two to get the tension you desire
Old Nov 08, 2012, 12:08 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
always a good idea to have spare parts
Old Nov 08, 2012, 05:12 PM
pollster is offline
Find More Posts by pollster
pollster's Avatar
United Kingdom
Joined Aug 2011
http://youtu.be/4vkkDPog9hw
Hello gents,
Just a thought how about staying with your 1680 kv motor and run it on 10s?
pollster is offline Find More Posts by pollster
Old Nov 08, 2012, 07:21 PM
Mile High EDF
420flyboy's Avatar
Joined Jul 2011
Originally Posted by pollster View Post
Hello gents,
I want more speed
Old Nov 08, 2012, 08:21 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Here ya go.
Las Vegas 2012 Habu 32 demo (4 min 30 sec)
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Nov 08, 2012, 10:30 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
thats really good Gary but you need to put your big boy pants on and do a 12s Mach Alloy
then you could play with the big boys
Team Habu Burners 65C Speed Run #2 (3 min 36 sec)
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
