Old Nov 07, 2012, 04:55 PM
Castel101 is offline
Find More Posts by Castel101
Castel101's Avatar
United States, OR, Portland
Joined Sep 2011
That looked really good Maxman, and it sounds great too. I don't have a Habu (building an eflite F-4 now) but I can see that it doesn't slow down at all! Looks like a great flier. Good thing you have that awesome looong runway!
Castel101 is offline Find More Posts by Castel101
Old Nov 07, 2012, 06:01 PM
maxman55 is offline
Find More Posts by maxman55
Joined Dec 2011
Thanks for the coment. I thinking to build a f-4 if i can dominate this red moster first. Haha
maxman55 is offline Find More Posts by maxman55
Old Nov 07, 2012, 06:45 PM
Jetnfast is offline
Find More Posts by Jetnfast
Jetnfast's Avatar
United States, CA, Temecula
Joined Feb 2008
Nice Maxman! The sound of your jet is awesome. Nice job on the maiden, but it will slow down much more than that for landing..looks like you came in HOT!! Good thing you have a huge place to fly. You'll get the hang of it, the more you fly it!!
Jetnfast is offline Find More Posts by Jetnfast
Old Nov 07, 2012, 06:49 PM
jgalexander is offline
Find More Posts by jgalexander
Flying Full Size & Fun Size :)
jgalexander's Avatar
United States, CA, Calabasas
Joined Apr 2010
Yep to the above Maxman, on your next flight you might try extending your final approach by 150-200 meters, so that you can get the plane stabilized and slowed down for landing. A nice nose-high, power-on (but just a little bit of power) approach works great. Nice runway!
-J
jgalexander is offline Find More Posts by jgalexander
Old Nov 07, 2012, 06:59 PM
Jetnfast is offline
Jetnfast's Avatar
Joined Feb 2008
JG makes some great points, a longer, flatter approach is always best to bleed the speed. Some of my best landings in the Habu have resulted in a 100 foot roll out or less. Its very satisfying when I can do that.
JG, did you get the Habu32 you bought on RCG flying yet?
Old Nov 07, 2012, 07:06 PM
Joined Apr 2010
Heck no! Been too busy blasting around in my Sundowner 50, beater foamy 5s Habu, and FJ Ultra. I think this weekend I'll get it going. Just bought a few extra batts off here, and I've got the extra long weekend. Should be some fast fun. Hopefully it'll be windy and no one will show up at the flying field
Josh
Old Nov 07, 2012, 09:46 PM
gsm026 is offline
Find More Posts by gsm026
United States, CO, Loveland
Joined May 2008
Maxmann,
I agree wtih your strategy to conquer the Habu first. I have both planes ... the F-4 really looks neat both on the air and on the ground (the Phantom has always been one of my favorite fighters), but it flies like a scale plane. It's not nearly as precise and smooth as the Habu. It's also harder to see in the sky and harder to land nicely (IMHO).
Greg
gsm026 is offline Find More Posts by gsm026
Old Nov 07, 2012, 10:54 PM
Sit-N-Fly is offline
Find More Posts by Sit-N-Fly
Joined May 2004
Originally Posted by Jetnfast View Post
Also I would consider adding some expo (if its a futaba radio) or dialing in some negative expo (if you run JR, or most others), to help nulify the center position
Actually, negative expo on JR will make it more sensitive around neutral. Dial in some positive if you want to soften it up.
Sit-N-Fly is offline Find More Posts by Sit-N-Fly
Old Nov 07, 2012, 11:07 PM
Jetnfast is offline
Jetnfast's Avatar
Joined Feb 2008
I think I got them backwards, I would have to go check on my Futaba to make sure, but thanks for clarifying.
Old Nov 08, 2012, 05:12 AM
ellzy_21 is offline
Find More Posts by ellzy_21
United States, TX, Wichita Falls
Joined Nov 2011
Hey guys seeing as how I'm new to the EDF world and I'd love to pull the trigger on one of these, I have a quick question about altitude. I fly at/or around 5000' and I imagine that there is a significant performance drop compared to sea level flying. To keep performance would I need to upgrade the motor, or is it something I could take care of with batteries (i.e. 7s/8s instead of 6s?). Thanks!
ellzy_21 is offline Find More Posts by ellzy_21
Old Nov 08, 2012, 09:31 AM
420flyboy is offline
Find More Posts by 420flyboy
Mile High EDF
420flyboy's Avatar
United States, CO, Denver
Joined Jul 2011
I live at 5300 feet, still works great. Stock will fly it fine at this elevation , but you can add a cell to 7s for greater power and faster takeoff. Lots have run the stock motor on 7s and it lasts just fine. You could add a heatsink to help on 7s
http://www.tamjets.com/original/prod...4362dd2dbc08c9
Or you could go jetfan 80 with 2080kv arc motor or het motor , stay on 6s , get better performance and speed.
http://www.performance-edf.biz/newjetfan80jetfan90.html
Hope this helps.
420flyboy is offline Find More Posts by 420flyboy
Old Nov 08, 2012, 09:36 AM
Mile High EDF
420flyboy's Avatar
Joined Jul 2011
Habu 32 Maiden April (4 min 56 sec)
Here's some flying on the maiden, with flaps it slows right down .
Old Nov 08, 2012, 09:42 AM
swps is offline
Find More Posts by swps
Some Girls r Bigger thn Others
swps's Avatar
USA, UT, Cedar Hills
Joined Jun 2010
I'm at 4800' and I second what 420Flyboy said. If you are building new, it's an opportunity for an upgraded bird if your budget allows. I would consider 8s, 10s, or even 12s systems. My latest is an 11s system on a Jetfan.
swps is offline Find More Posts by swps
Old Nov 08, 2012, 09:56 AM
Mile High EDF
420flyboy's Avatar
Joined Jul 2011
Nice , on the 11s. Thinking of building a 12s one , I can fit 4000mah 6s packs in to make 12s , use jetfan 80 and het 700-68-1400kv , ice120hv and tams struts
I'm thinking this motor on 12s
http://www.highendrc.com/index_eprod...roducts_id=316
650-68-1340kv
Maybe around 100amps and 4500 watts, that should get it going
Old Nov 08, 2012, 10:18 AM
swps is offline
swps's Avatar
Joined Jun 2010
I like the 700-68-1400kv better on 12s than the 650-68-1340kv on a Jetfan just because it's 39mm rather than 36mm and I think that extra diameter size will help with heat and because it's heavier it will help with balancing the 2 4000s. But on the other hand....lighter is better when going for top end speed.... so the 650 with 3300's would make for short but fast flights!
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 03:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 09:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 21, 2010 12:15 AM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 10:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 08:39 PM
