United States, CO, Loveland
Joined May 2008
I started with my Cg back in the neighborhood of 115-116mm (based on this thread) and so far I haven't had much problem landing. I had to do the same with my Eflite F4 - on that plane I am well behind the Cg range. I do tend to run off the end of the runway sometimes so I'm experimenting with more flap travel to see if I can get it to slow down better.
Greg |
United States, UT, Logan
Joined Nov 2011
Hey guys, I know it's kind of an obscure servo, but do you think the spektrum a5030 digitals would work in this bird? Here are the specs:
Product Specifications Size Category:Minis and Micros Type igitalApplication:25 - 32 size airplanes Torque:50 oz-in (3.6 kg-cm) @ 4.8V, 66 oz-in (4.8 kg-cm) @ 6V Speed:0.12 sec/60° @ 4.8V, 0.10 sec/60° @ 6V Length:1.3 inch (32.8mm) Width:.58 inch (14.7mm) Height:1.1 inch (27.4mm) Weight:0.7 oz (21.6g) Bushing Or Bearing:Bearing Bearing ualMotor Type:CorelessGear Type:NylonVoltage:4.8 - 6V If not, what are most using? I've heard the mc35, or hs-85mgs.... |
I just built that setup and I'm only pulling 98Amps at 3000watts on 10s. I'm not gonna fly it on 12s but 11s will be a regular thing with that motor. Unfortunately, my ESC died while taxiing out last week so it's in the process of being replaced and then I'll have some numbers on 11s. The Jetfan isn't rated for that much thrust but it will be fine IMHO. If you decide to go all alloy you'll need a motor with an 8mm shaft as I read Gary doesn't have adapters for 5mm.
108 amps max 3926 watts max 48153 rpm Very pleased indeed,just gotta wait for some fine weather now could be a long wait here in england lol. |
Now hat they are in stock, I'll generate two versions of the 90mm EDF. One with 5mm and one with 8mm, |
| Thread Tools | |
| Discussion Fiberglass Habu Airframe | Calvin_220 | Electric Ducted Fan Jet Talk | 92 | Nov 10, 2012 02:53 AM |
| Sold New in box Habu EDF PNP | flyboy1945 | Aircraft - Electric - Jets (FS/W) | 2 | Aug 01, 2010 08:24 PM |
| Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread | SalamSyed | Foamy EDFs | 0 | Mar 20, 2010 11:15 PM |
| New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer | nitroplanes | Nitro Planes | 0 | Jan 24, 2009 09:58 AM |
| Discussion Baja SS Speculation and hopup thread. | DaveESPI | Large Scale Cars | 3 | Feb 03, 2008 07:39 PM |
