Old Oct 18, 2012, 07:52 PM
RCflyerCT is offline
Find More Posts by RCflyerCT
RCflyerCT's Avatar
United States, CT, Southbury
Joined Aug 2011
Sick!!!!
QUOTE=efflux RC;23027711]Here's our latest demo video:
Habu 32 flying with the Mach All Alloy 80mm EDF on 10s.
No doors on the mains yet.
Las Vegas 2012 Habu 32 demo (4 min 30 sec)
[/QUOTE]
RCflyerCT is offline Find More Posts by RCflyerCT
Old Oct 18, 2012, 11:14 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
Originally Posted by Extreme_RC View Post
So 4200 watts, and 162mph, doesnt that seem like a lot of watts? The wemo based habus seem to all get into the 150's with less than 3000 watts. I am not bashing anything, just curious to know if I am missing something here??
Maybe the true speed of Gary's jet is over 162 MPH.
4-5 pages back Gary reported 28mm 16/45 at 159 MPH...I assume stock fan with balanced rotor.
I guess 5S (not sure).
Monster size HET on 10S and fancy fan is worth over 2-3 MPH.
……and/or maybe some of the power or speed data from Wemo setups are off a little.
Edit: One more thing. See Gary's screen shot again. To me it appears that the 4.2KW is peak spike which is displayed before start of play back and again at end of file. So that means it draws less when the motor is spooled up.....unless he gradually raised throttle each time during the entire file.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Oct 19, 2012, 02:07 AM
NR11 pete is offline
Find More Posts by NR11 pete
pete05
sydney australia
Joined Apr 2006
Has anyone seen a fuselage in stock for this jet, I can find them anywhere not even horizon.
NR11 pete is offline Find More Posts by NR11 pete
Old Oct 19, 2012, 03:13 PM
Quandry is offline
Find More Posts by Quandry
Ireland, Co. Dublin, Dublin
Joined Feb 2012
Originally Posted by Quandry View Post
Will do. Are both threaded rods the same diameter? is it only the brass gear that's a different size?
edit: I took a solid look at the photos they both look the same, its just the shaft end for the brass gear that is turned out to a different size.
Ordering now!!
Well I got those worm gear in and they don't fit
I tried taking the cross piece off and putting that on the eflite worm gear but it's a different size thread so that doesn't work either
Why the F does eflite not sell the right part?
Quandry is offline Find More Posts by Quandry
Old Oct 20, 2012, 12:51 PM
Jetnfast is offline
Find More Posts by Jetnfast
Jetnfast's Avatar
United States, CA, Temecula
Joined Feb 2008
Have you tried calling horizon hobby support? They will probably replace the defective unit for you if you ask.
Jetnfast is offline Find More Posts by Jetnfast
Old Oct 20, 2012, 02:19 PM
goforit is online now
Find More Posts by goforit
United States, WI, De Pere
Joined Aug 2010
I upgraded my Hau with Jet fan 80mm v2 fan, ARC 36-65-1 motor. I have a Castle 100 amp speed controller and bec. Battery is 6s xps 5000. System worked fine with stock eflite set up.
With the new fan motor combo soon as I advance past 1/2 throttle motor shuts down.
No idea where to start trouble shooting. Suggestions?
Dennis
goforit is online now Find More Posts by goforit
Old Oct 20, 2012, 02:45 PM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
The CC ESC will have a data log. Download it and it will tell you the problem.
jayb1rdz is offline Find More Posts by jayb1rdz
Old Oct 20, 2012, 03:02 PM
Quandry is offline
Joined Feb 2012
Strictly speaking it is not defective but damaged due to my own hard landing. I contacted Horizon and they will only sell a whole retract and not just the worm gear piece. I fly from a grass strip so will have future hard landings also. If I could I would buy a bag of ten of those parts and keep them to hand for field repairs.
Old Oct 20, 2012, 08:03 PM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Just send it in with a receipt and they will replace it. i keep a spare set in the field box.
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Oct 20, 2012, 08:10 PM
Jetsom is offline
Find More Posts by Jetsom
Formerly "Heli Copter"
Jetsom's Avatar
United States, CA, Watsonville
Joined Apr 2009
Dennis
It sounds like the voltage is dropping to 3.2 per cell and tripping the auto cutoff on the ESC. Your motor is 2080kv which is very close to the stock 2150kv. The load of the 9 blade JetFan could be higher than the stock 5 blade rotor. Your battery can't keep up. I would try a higher C rated battery.
Jetsom is offline Find More Posts by Jetsom
Old Oct 21, 2012, 02:38 PM
Downwind3Zero is offline
Find More Posts by Downwind3Zero
It's like an addiction!
Downwind3Zero's Avatar
NY, Rochester
Joined Oct 2003
My modified Habu32, Jetfan 80, 8S 4500 on board camera in HD.
HABU 32 Modified onboard HD Cam (4 min 18 sec)
Downwind3Zero is offline Find More Posts by Downwind3Zero
Old Oct 21, 2012, 05:50 PM
Jetnfast is offline
Jetnfast's Avatar
Joined Feb 2008
great vid DW30! Looks like you have a nice place to fly too!
Old Oct 21, 2012, 07:23 PM
dennisjm is offline
Find More Posts by dennisjm
Proud RC Addict
United States, UT, American Fork
Joined Nov 2009
The bearing on my nose retract seems to have fallen apart. Caused not a good connection between the worm gear and the gear the motor is connected to. Result was motor would spin but worm gear stayed stationary.. = no retract up/down.
So... I need a replacement bearing. Any ideas where to get one?
I measured 5mm outside diameter, 2.6mm inside diameter and 2.4mm bearing height.
dennisjm is offline Find More Posts by dennisjm
Old Oct 21, 2012, 07:28 PM
NY, Rochester
Joined Oct 2003
Thanks Jetnfast! It is a great place to fly-all we need to watch out for a re skydivers and an occasional plane
Old Oct 22, 2012, 09:06 AM
dennisjm is offline
Proud RC Addict
Joined Nov 2009
Searched hi and low but only found one other site that seems to sell a gear for the retracts:
http://rc-castle.com/shop/product_in...roducts_id=785
i have no idea if that is even close though. Likely not. Difficult to find a bearing that is the right size too.
@Quandry.. you figure something out for your problem?
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 03:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 09:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 21, 2010 12:15 AM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 10:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 08:39 PM
