Old Oct 12, 2012, 08:46 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Its not hard to drop the housing in place then sit the brackets in on the rails and tack them on, then remove and glue fully, same with my alloy housing, drop it in and silicon the brackets down in the right spot, let cure then lift it all out to finish off if needed.
I am going to remove 10mm from the front of all the 80mm housings from now on, with the new jetfan rotor having no adapter hub sticking out the back I dont need the extra housing length, will make it easier for installs into the tight area of the Habu.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Oct 12, 2012, 09:05 PM
maxman55 is offline
Find More Posts by maxman55
Joined Dec 2011
Thanks to all for the replies
maxman55 is offline Find More Posts by maxman55
Old Oct 13, 2012, 03:04 PM
maxman55 is offline
Joined Dec 2011
What are the recomended settings for the ice 100 i have a typhoon motor an jetfan. Thanks
Old Oct 13, 2012, 04:49 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
low timing, 8 or 12khz pwm
jcdfrd is offline Find More Posts by jcdfrd
Old Oct 14, 2012, 11:03 AM
maxman55 is offline
Joined Dec 2011
ok thanks
Old Oct 17, 2012, 03:10 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Here's our latest demo video:
Habu 32 flying with the Mach All Alloy 80mm EDF on 10s.
No doors on the mains yet.
Las Vegas 2012 Habu 32 demo (4 min 30 sec)
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Oct 17, 2012, 04:17 PM
imodel is online now
Find More Posts by imodel
USA, CT, Farmington
Joined Nov 2003
Sa-weet!!!!
R
imodel is online now Find More Posts by imodel
Old Oct 17, 2012, 04:25 PM
dennisjm is offline
Find More Posts by dennisjm
Proud RC Addict
United States, UT, American Fork
Joined Nov 2009
Do you have CG issues when putting 10S in there?
dennisjm is offline Find More Posts by dennisjm
Old Oct 17, 2012, 05:10 PM
efflux RC's Avatar
Joined Aug 2009
No. The batteries used are Sky Lipo, 5s, 40c, 4000's. they weigh 2lbs, 4.3 oz for the both of them with 6mm bullets attached.
Compare this to our 8s, Mega/Eflite setup which runs (2 ea) XPS 4s, 65c, 5000's at 2lb 5.7 oz for the both of them with the same connectors.
This additional weight is only 1.4 oz
The batteries are shorter and keep the weight aft. But this is not really a concern either, as the batteries need to placed father forward than "all the way back'.....so, there's room for CG adustment. by just placing the batts according. you could probably run 10s, 5000's for longer flight time, and more speed (less voltage drop)
Anothe reason for ease of CG'ing is that were using a 39mm dia HET 700-68-1680 motor. This adds wieght to aft end of the jet.
36mm Mega and Neu motors are an option, as well.
The jet flies with a 9ch rx (with 2 satallites), a 900mA, 30c rx lipo, a CCBEC, and a CC ICE 120HV
Site Sponsor
Old Oct 17, 2012, 05:34 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
Gary
looks like a nice setup you have there, what was your auw and total watts?
Old Oct 17, 2012, 05:55 PM
efflux RC's Avatar
Joined Aug 2009
Originally Posted by jcdfrd View Post
Gary
Hi John,
Uuut ooooh, here comes the competition.
Not too heavy, and lotsa watts.
You not gonna make me build a fast one are you? If you play nice, I'll post the Eagle Tree Data from when I bench tested it.
Let me dig it up for ya.
Site Sponsor
Old Oct 17, 2012, 06:06 PM
efflux RC's Avatar
Joined Aug 2009
John,
I don't have a proper scale to weight it with. My bathroom scale says about 8 1/2 lbs.
Our 8s Mega motored Habus were about 8lbs on the same scale.
  • The added weight would be 1.4 oz more for the lipos
  • The difference in weight between the E-flite and the Mach fan.
  • The difference in the weight between the 28mm MEGA motor and the 39mm HET 700-68-1680 motor.
Here's the ET data.
Site Sponsor
Old Oct 17, 2012, 08:54 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
lmao!!!!.......thanks for posting the data. it sure didnt look like 8.5lbs on the landing man Brent set her down like a gentle flower
hey nice build Gary
Old Oct 17, 2012, 10:03 PM
efflux RC's Avatar
Joined Aug 2009
Thanks john!
Site Sponsor
Old Oct 18, 2012, 07:32 PM
Extreme_RC's Avatar
Australia
Joined Mar 2006
So 4200 watts, and 162mph, doesnt that seem like a lot of watts? The wemo based habus seem to all get into the 150's with less than 3000 watts. I am not bashing anything, just curious to know if I am missing something here??
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 03:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 09:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 21, 2010 12:15 AM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 10:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 08:39 PM
