Old Oct 08, 2012, 05:38 PM
pavlos is offline
Find More Posts by pavlos
Joined Oct 2012
yeap
it will be lifted tomorrow so I will be back on my normal account
pavlos is offline Find More Posts by pavlos
Reply With Quote  (Disabled)
Old Oct 10, 2012, 02:32 AM
Quandry is offline
Find More Posts by Quandry
Ireland, Co. Dublin, Dublin
Joined Feb 2012
Originally Posted by swps View Post
I'd try this one:
http://www.pw-rc.com/product_info.ph...oducts_id/2772
Or this one:
http://www.pw-rc.com/product_info.ph...oducts_id/2773
But then again, it's possible neither would work.
Very useful links - thanks I will give that a try and report back.
Quandry is offline Find More Posts by Quandry
Old Oct 10, 2012, 06:38 AM
STEVEAIR2 is offline
Find More Posts by STEVEAIR2
STEVEAIR2's Avatar
Dublin Ireland
Joined Aug 2005
hi Geoff
I think in the original posts for these units the threaded rod was longer but the part you want is the same thread as the eflite one.
cheers
Steve.
PS.If you are going to order these will you get me one?
STEVEAIR2 is offline Find More Posts by STEVEAIR2
Old Oct 10, 2012, 08:14 AM
Quandry is offline
Joined Feb 2012
Will do. Are both threaded rods the same diameter? is it only the brass gear that's a different size?
edit: I took a solid look at the photos they both look the same, its just the shaft end for the brass gear that is turned out to a different size.
Ordering now!!
Old Oct 11, 2012, 06:43 PM
maxman55 is offline
Find More Posts by maxman55
Joined Dec 2011
what screws should I use for holding the fan unit to the fuse, I have a jetfan 80mm.
thanks
maxman55 is offline Find More Posts by maxman55
Old Oct 11, 2012, 07:32 PM
Jetnfast is offline
Find More Posts by Jetnfast
Jetnfast's Avatar
United States, CA, Temecula
Joined Feb 2008
thanks
I imagine the stock 3mm x 10mm self tapping screws should work, at least that is what the stock fan calls for. The JF should take the same, if not very similar screws.
Jetnfast is offline Find More Posts by Jetnfast
Old Oct 11, 2012, 11:18 PM
420flyboy is offline
Find More Posts by 420flyboy
Mile High EDF
420flyboy's Avatar
United States, CO, Denver
Joined Jul 2011
thanks
I don't use screws on my jetfans , I use metal ducting tape , looks like aluminum foil , but is tape , holds great ,just wrap it around the fan . Hopes this helps, I haven't had one come loose yet , I've used it on a 90mm jetfan on 12s over 4000 watts and it holds fine
420flyboy is offline Find More Posts by 420flyboy
Old Oct 12, 2012, 12:28 AM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
What does the tape stick to to hold down the fan?
Michael Paxton is offline Find More Posts by Michael Paxton
Old Oct 12, 2012, 06:45 AM
moparmyway is offline
Find More Posts by moparmyway
Why the dirt on the wings?
moparmyway's Avatar
New York
Joined Jan 2009
+1
moparmyway is offline Find More Posts by moparmyway
Old Oct 12, 2012, 06:55 AM
KentF is offline
Find More Posts by KentF
FunkMaster
KentF's Avatar
United States, OH, Mason
Joined Jan 2011
I have to think that 420flyboy was talking about attaching the thrust tube to the fan, not the fan to the fuselage.
KentF is offline Find More Posts by KentF
Old Oct 12, 2012, 07:03 AM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Ive use silicone to hold a fan in place just 3 or 4 dabs arround the shroud to inlet ducting connection. Helps dampen noise to.
420 flyboy, Not sure about HVAC tape though. since they have mounting rail in the plane and flanges on the shroud why not secure it with screws? I use the servo mounting screws with built in flange #2 x 1/2"
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Oct 12, 2012, 07:21 AM
Joined Dec 2000
Based on the mounting question i have to wonder
Old Oct 12, 2012, 08:03 AM
Quandry is offline
Joined Feb 2012
I used the bigger screws that are in the kit to hold in the undercarriage..... by accident.. lol then I had to go off and raid an old screw collection to get the undercarriage mounted
Old Oct 12, 2012, 09:31 AM
Mile High EDF
420flyboy's Avatar
Joined Jul 2011
The tape sticks to the shroud and the plane ducting , haven't had one come loose yet, at over 4000 watts holds fine , my eflite f4 is held the same way and habu. This tape is really sticky and conforms to the area .
The problem is the jetfan doesn't have the mounting tabs attached to the fan , you have to attach them , it can be easier to use tape , just my 2 cents , and it does work.
I've super glued them in before and that works great also , little dab of glue around shroud , sticks perfect, tap it just right and you can make it out and replace , this is how I've done every jetfan that I've owned from 80 to 90mm 2000 watts to 4000 watts, my 8s habu 32 is glued in.
So in conclusion , I've used HVAC tape , or glue and its works fine.
Old Oct 12, 2012, 09:51 AM
KentF is offline
FunkMaster
KentF's Avatar
Joined Jan 2011
Doing it that way I would think would put a lot of force on the inlet ducting which may not be designed to handle the forward force on it but......practice speaks louder than theory so at least for the Habu 32, it must be strong enough to handle it.
My TJ80 had to have the mounting tabs glued on also. I was sceptical that they would hold with just CA glue but they've been just fine.
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
