Old Oct 02, 2012, 01:58 PM
Team Futaba
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Originally Posted by mulicheng View Post
Is the heavy duty steering something that comes with the more expensive setup or is that an additional item you were referring too?
It is extra but worth the money as it is sized for the nose strut pin that Tam upgrades to 5/32" wire. I have 75+ flights on mine without any issue.
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Oct 07, 2012, 02:36 PM
Proud RC Addict
United States, UT, American Fork
Joined Nov 2009
3 questions after getting my habu in the mail, assembling things, programming the radio.
1) Should I adjust the ESC settings, specifically motor timing? Ice 100 in there.
2) Tamjets nose strut/wheel slightly bump into fuse when retracted. During testing the retract stalled once and wouldn't operate until I power cycled again. Anyone have suggestions on how to fix/avoid problems.
3) Will run on stock motor/fan w/ 6s until I decide to upgrade in the future perhaps. For amp draw do you think running w/ deans on battery OK. I wonder if I hadn't ought to upgrade to bigger bullet connectors.
dennisjm is offline Find More Posts by dennisjm
Old Oct 07, 2012, 02:52 PM
Team Futaba
Joined Dec 2000
Did you add the 1/4" ply spacer?
Deans are fine. ec5 are a good choice
Old Oct 07, 2012, 03:18 PM
SoCal, Year Round Flying!
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Tight clearance with the strut, I shaved a few mm off the fuse opening where it needed it.
I run the default setting on my ice100. no issues.
Also using deans with 7S 5000s on stock fan/motor, Use genuine deans, not the cheap copys, they fail. But bullet connectors(EC5)) are much better should you choose that route.
bmiller is offline Find More Posts by bmiller
Latest blog entry: Durafly Vampire 70mm
Old Oct 08, 2012, 03:41 AM
Ireland, Co. Dublin, Dublin
Joined Feb 2012
Got a few more flights on my Habu32 yesterday, on the last flight my ESC low voltage cut hit on finals and I landed in the rough just short of the runway. No damage to the airframe but I damaged a retract.
The two arrows indicate that the plastic piece and the brass collar should be one piece. The brass gets pulled out of the plastic piece with the weight of the impact which is fine as it saves the retract and the model/wing etc etc, however does anyone know where to buy just that piece?
This is the second time I've had this problem, last time I had to buy a whole retract which kind of defeats the purpose of 'saving the retract' if you have to buy one anyway...
If I could I would buy a bag of 10 of those little suckers - Horizon told me that they don't sell that piece seperately
Quandry is offline Find More Posts by Quandry
Old Oct 08, 2012, 04:23 AM
Joined Oct 2012
there are a bunch of chinese cheapos that work flawlessly and are a direct drop in.. get those.. I don't see why you shouldn't
pavlos is offline Find More Posts by pavlos
Reply With Quote  (Disabled)
Old Oct 08, 2012, 04:50 AM
Team Futaba
Joined Dec 2000
Send it in and they will replace the gear. keep a spare unit in your flight box
Old Oct 08, 2012, 07:25 AM
Proud RC Addict
Joined Nov 2009
I'll have to check. I didn't assemble it. Got here off rcgroups.
Old Oct 08, 2012, 09:45 AM
Joined Feb 2012
Hey cool Pavlos, I don't know what it is called so I don't know where to start searching. Have you got a link on where I can find them?? will be ordering asap.
Old Oct 08, 2012, 10:35 AM
Life's short - Enjoy!
DeeCee 57's Avatar
Zurich, Switzerland
Joined Nov 2009
pav... los?
DeeCee 57 is online now Find More Posts by DeeCee 57
Old Oct 08, 2012, 11:53 AM
Joined Oct 2012
it's my name in Greek... .. you can call me Paul... same thing
Old Oct 08, 2012, 02:07 PM
Joined Feb 2012
Sorry... Paul... can you let me know where I can buy those plastic retract pieces, or what they are called so I can search for them?
cheers,
Geoff.
Old Oct 08, 2012, 03:10 PM
Some Girls r Bigger thn Others
swps's Avatar
USA, UT, Cedar Hills
Joined Jun 2010
I'd try this one:
http://www.pw-rc.com/product_info.ph...oducts_id/2772
Or this one:
http://www.pw-rc.com/product_info.ph...oducts_id/2773
But then again, it's possible neither would work.
swps is online now Find More Posts by swps
Old Oct 08, 2012, 05:26 PM
Joined Oct 2012
actually those are the upgrade for the changesun retracts to be converted with metal trunion.. a complete retract will also work and they are cheap as chips..
I have them in 3.3 and 4kg planes and they work juuust fine.
Old Oct 08, 2012, 05:33 PM
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Joined Mar 2006
Originally Posted by DeeCee 57 View Post
pav... los?
Pavcon got banned in the naughty corner so appears to have registered a new account...
Extreme_RC is offline Find More Posts by Extreme_RC
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
