Old Oct 01, 2012, 06:41 PM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
Servo or air Nippaero?
If servo controlled, most radios now have delay built in. No need for sequencer.
Michael Paxton is offline Find More Posts by Michael Paxton
Old Oct 01, 2012, 08:33 PM
Double E is offline
Find More Posts by Double E
Double E's Avatar
Atlanta, GA
Joined Mar 2009
I use this sequencer from HK on my 90mm JTM Viperjet and it works great. Programming is a little tricky at first but once you get it set up properly it works great. I didn't use a sequencer on my Habu32 because I used Tam's old school wire trick to close the nose gear door. If you have a spare channel you can just program a delay for the gear door servo.
http://www.hobbyking.com/hobbyking/s...dProduct=11258
Double E is offline Find More Posts by Double E
Old Oct 01, 2012, 09:44 PM
bdelapen is offline
Find More Posts by bdelapen
Sponsored by Team de la Peņa
bdelapen's Avatar
United States, FL, Pembroke Pines
Joined Aug 2008
This one is a little more expensive but it has been used with great success by many pilots that I know:
http://shulmanaviation.com/product_i...5fc7de2851b010
- Birger
bdelapen is offline Find More Posts by bdelapen
Old Oct 02, 2012, 08:29 AM
dennisjm is online now
Find More Posts by dennisjm
Proud RC Addict
United States, UT, American Fork
Joined Nov 2009
Thinking about maybe upgrading retracts when I get a habu.
What is the difference between buying Tam's struts alone:
http://www.tamjets.com/original/prod...roducts_id=609
and buying the complete kit with retracts:
http://www.tamjets.com/original/prod...roducts_id=610
The price difference seems to suggest you're getting something more than just struts/retracts with the second option but I can't see clearly what the benefit is.
Do the stock wheels work fine on the upgraded struts?
dennisjm is online now Find More Posts by dennisjm
Old Oct 02, 2012, 08:34 AM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
The stock wheels work great. and wear very well. I highly recomend the heavy duty steering assembly too.
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Oct 02, 2012, 08:53 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
the shulman I think it's the Jetlegends sequencer..
ok I don't think. I'm sure
pavcon is offline Find More Posts by pavcon
Old Oct 02, 2012, 09:10 AM
bdelapen is offline
bdelapen's Avatar
Joined Aug 2008
Yes, Schulman sells the Jetlegend or also called the RCBEE gear door sequencer. I was just providing an option where he could purchase it locally (i.e. in the US).
There are a lot of videos on YouTube that explain how to set it up and it's very flexible.
- Birger
Old Oct 02, 2012, 09:31 AM
pavcon is offline
Joined Jan 2010
A friend has it in he pre built JL Hawk.. and it works flawlessly so far.thyat's how I recognised it..... it is indeed a good option..
Old Oct 02, 2012, 09:33 AM
pavcon is offline
Joined Jan 2010
a friend is also using this one ..
but it's currently back ordered.. it also works very good ..
Old Oct 02, 2012, 09:44 AM
Double E is offline
Double E's Avatar
Atlanta, GA
Joined Mar 2009
Be sure to buy a fully programmable sequencer. I originally bought one designed for air retracts and it didn't give me the ability to program the amount of servo travel because it was designed to actuate an air valve rather than open and close gear doors. Being able to adjust servo travel on gear doors will be incredibly helpful. The HK sequencer I provided the link to is fully programmable including direction, speed, servo throw, and delays.
Old Oct 02, 2012, 09:49 AM
pavcon is offline
Joined Jan 2010
the cheap hobbyking one also feutures end point adjustments.. it's a good choice.. if it was in stock.. but I think this one stocks regurarly.. .
Old Oct 02, 2012, 10:10 AM
Proud RC Addict
Joined Nov 2009
Is the heavy duty steering something that comes with the more expensive setup or is that an additional item you were referring too?
Old Oct 02, 2012, 10:14 AM
Nashville TN.
Joined Mar 2006
Mulicheng. The first item is the struts only. The second is for the whole 15-25 retract with upgraded trunion AND the struts..
Does that help?
Essentially, the second one is for people who don't already have the 15-25 Eflite retracts....Or don't want to go thru the process
of rebuilding the ones they have. (Took me about an hour to upgrade mine) But some are not comfortable opening up electronic
devices.
No. The second comes with plastic steering assembly that is stock on 15-25 retract.
With the second item, you are paying for: Retract, Strut and for Tam to assemble it for you.
Old Oct 02, 2012, 10:25 AM
Proud RC Addict
Joined Nov 2009
And the upgraded Trunion right? Seems like a good deal if you're starting from scratch then.
Edit: Actually those come with just the struts too it looks like... so basically just paying for assembly time then I guess.
Old Oct 02, 2012, 12:27 PM
Nashville TN.
Joined Mar 2006
Assembly, retract and assembly time yes. Same parts with retract added and labor.
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
