Old Sep 04, 2012, 08:28 AM
maxman55 is offline
Find More Posts by maxman55
Joined Dec 2011
Originally Posted by whisperdancer View Post
I think you have to insert the stab from below and then twist it up.
How do you guys give toe in? Twist the rod below the spring or modify the slot where the screw is?
Something has to be wrong here, yes i can put the spar first in the stab and then put the stab in the fuse but look at this pic that dont align either, anyone please thanks for the help
Description:
maxman55 is offline Find More Posts by maxman55
Old Sep 05, 2012, 04:38 AM
whisperdancer is offline
Find More Posts by whisperdancer
Portugal, Porto District, Maia Municipality
Joined Aug 2008
Attachment 5132019
In my kit, in order the stab to fit, the spar couldn't go all the way into the stab.
The gluing process was made inserting the spar into stab -> stab into fuse -> adjust the spar into screw holes while holding the stab so the spar could move and adjust.
whisperdancer is offline Find More Posts by whisperdancer
Old Sep 05, 2012, 06:02 AM
Robert Belluomini is offline
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Maxman i rehaped the carbon spar. Enlarged the hole in the fuse for the carbon pins as needed. Then i sanded the fuse where the stab root mates an glued the stabs in place using a quality thickend epoxy. The model flies better. ill post a photo.
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Sep 05, 2012, 07:07 AM
maxman55 is offline
Joined Dec 2011
Thanks to all for the help, whisperdancer your steps worked perfect thanks i just finished, now to continue the build.
I will install today the retracts, what type and size of screws should i get? i have read that the provided screws snap. thanks
Old Sep 05, 2012, 07:41 AM
Jetnfast is offline
Find More Posts by Jetnfast
Jetnfast's Avatar
United States, CA, Temecula
Joined Feb 2008
Use the same size screws, but you can find better quality ones at ACE hardware or a similar store. Also I recommend using a small amount of dish soap as a lubricator for the scews. Another tip is to work the 4 screws in evenly as you go, this minimizes the chance one will snap. Go slowly and take your time. This was the most frustrating part of the whole build for me. I spent alot of time trying to get out broken screws!!
Jetnfast is offline Find More Posts by Jetnfast
Old Sep 06, 2012, 02:09 AM
Quandry is offline
Find More Posts by Quandry
Ireland, Co. Dublin, Dublin
Joined Feb 2012
Recently I bought a FOD for my P20 Habu...
I was at my buddies place last night doing some build on his new Habu and we took a look at the FOD close up, compared to the DeltaV 80mm it turns out the P20 is actually pretty small!
I wonder could you squeeze a bigger turbine in the Habu 32?
Quandry is offline Find More Posts by Quandry
Old Sep 06, 2012, 02:30 AM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
I used #4 x 5/8" Phillips flat head wood screws.
Also, drill the pilot holes to a larger dia, so that such excessive torque is not required.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Sep 06, 2012, 04:38 AM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
So I drill the hole 7/8" ??
jayb1rdz is offline Find More Posts by jayb1rdz
Old Sep 06, 2012, 08:05 AM
Jetnfast is offline
Jetnfast's Avatar
Joined Feb 2008
That FOD screen does look alot smaller than the stock fan! Geez, I didnt realize that P-20 was so tiny!
Old Sep 06, 2012, 06:41 PM
evo101 is offline
Find More Posts by evo101
evo101's Avatar
Australia
Joined Jun 2009
The p20 blades are tiny, but dont let that fool you the p20's eflux is crazzy vs the EDF's
evo101 is offline Find More Posts by evo101
Old Sep 06, 2012, 08:46 PM
Friedclutch is offline
Find More Posts by Friedclutch
Got Brushless?
Friedclutch's Avatar
Sacramento
Joined Sep 2007
Indeed it is.. Abgasgeschwindigkeit (km/h) 1674 <----- Exhaust gas speed.
Translation.. ---> emission gas velocity of a P-20 at full throttle is 1040 mph.
The speed of sound is... 768 mph.
Chalk that up to pure awesomness folks. All this, at 245,000 rpm. Heck yes, mate.
Don't forget about how awesome the smell and sound of a turbine is too.
Friedclutch is offline Find More Posts by Friedclutch
Old Sep 06, 2012, 10:01 PM
evo101 is offline
evo101's Avatar
Australia
Joined Jun 2009
its so so true, mine has 40min of run time already and hasnt even been up in the air yet lol
Old Sep 06, 2012, 10:31 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
all this may be true but the p20 will never be as fast as a 9,10,11,12s edf the p20 in this airframe is 150mph and you can just about get their on 8s edf
jcdfrd is offline Find More Posts by jcdfrd
Old Sep 07, 2012, 03:17 AM
Quandry is offline
Joined Feb 2012
Specs on the Wren44:
Thrust : 45N / 4.5kg / 10lbs
Weight : 600g / 21oz
Overall Size : 215mm x 75mm (8.5" x 3")
Ancillaries weight (inc battery) : 340g / 12oz
Max RPM : 195,000
Idle RPM : 55,000
Idle Thrust : 1.5N / 0.15kg / 0.3lbs
Fuel Consumption @ max thrust : 176ml per minute / 5.8oz per minute
The Overall diameter is still smaller than the Eflite Delta V 80mm so it could be made to physically fit. It is double the weight of the P20 though, given there's already weights in the nose of my P20 Habu I guess the whole plane would become pretty much a speeding bullet. Still 10lbs of turbine thrust in the Habu would be epic to watch
Old Sep 07, 2012, 05:58 AM
jayb1rdz is offline
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
After reading the MAAA rules about certifying all turbines, any chance of one soiling my car has been relegated to the can.
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
