Old Jul 10, 2012, 06:29 PM
Mannyman535 is online now
Find More Posts by Mannyman535
edf flyer
Mannyman535's Avatar
United States, CA, Marina
Joined Feb 2009
Originally Posted by stmbike View Post
Speaking of upgrading, I'm leaning towards trying 7s on the stock set up. I've heard of some doing this. I'm using a castle 75 amp ice in the fuse and really don't plan on putting it in the thrust tube. How do you Jet Jocks feel about using 7s with trottle management and maybe bursts of 10-15 seconds. Would there really be much speed difference? thanks for the input. btw 5 away from my 200th. stephan
I'm running mines on 7s with a heat sink on the motor with no problems.
I have a ice 100.
Mannyman535 is online now Find More Posts by Mannyman535
Old Jul 10, 2012, 07:35 PM
bmiller is offline
Find More Posts by bmiller
SoCal, Year Round Flying!
bmiller's Avatar
Newport Beach, CA
Joined May 2002
Bruce, that's good info to hear. Mine on 6s has an output of 1640 watts and around 60-65 amps. Can you run this 7s set up wide open for any length of time? Seems like it would get too hot. Also, the 7s 5000's must put the bird nere 8 lbs, but I guess with that much more thrust it's probably OK. Stephan
I've run WOT for well over a minute doing laps around the field then back off to half throttle to cool it off.
Theres a youtube video of a guy flying 8S at WOT continuously.
It took over 3 minutes to fry that motor!
After watching that wild video I knew 7S woul;d be okay.
The weight of the extra cell is pretty much unnoticable as long as your CG is at the same point as using 6S.
bmiller is offline Find More Posts by bmiller
Old Jul 10, 2012, 09:59 PM
evo101 is online now
Find More Posts by evo101
evo101's Avatar
Australia
Joined Jun 2009
That’s an impressive video
he ran 8s on the stock motor for a good few minutes, its really moving along as well
Habu 32 EDF Stock Motor 8S (3 min 25 sec)
evo101 is online now Find More Posts by evo101
Old Jul 11, 2012, 10:59 AM
Quandry is offline
Find More Posts by Quandry
Ireland, Co. Dublin, Dublin
Joined Feb 2012
Tried getting my Habu32 airborne last weekend but it was a mess. Could not get up to speed on our grass runway (too short, grass too long, ground very soft/moist). Then me and my buddies shifted to a local park with a pavement, unfortunately the width was poor and the wheel tracking even worse so I could not get anywhere near enough take off.
Since then I have watched some youtube vids and it seems like the Habu needs quite a long run up (on grass or pavement). I don't have access to that here so I am going bungee and have today bought a Jepe bungee launch system.
Anyone using bungee with their Habu32? If I can get in the air in 10 metres I'll be in business
Quandry is offline Find More Posts by Quandry
Old Jul 11, 2012, 12:14 PM
vasek is offline
Find More Posts by vasek
Joined Nov 2003
I thought the best way is to use some kind of ramp. It gets faster up to seed + the proper incidence @ the end of the ramp. But I could be wrong
vasek is offline Find More Posts by vasek
Old Jul 11, 2012, 02:18 PM
Quandry is offline
Joined Feb 2012
That particular dolly is not designed for a Habu 32 but for a Mig. There might be some experimentation/modifications required!
I will have to install a tow hook on the CG to get it to work for starters...
Old Jul 11, 2012, 02:28 PM
Madmax1965 is offline
Find More Posts by Madmax1965
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
Why would it make a difference on the make of plane...........??
Subscribed...I like not having to install landing gear.............low wing loading is a plus.
We want video!!
Madmax1965 is offline Find More Posts by Madmax1965
Old Jul 11, 2012, 02:36 PM
Robert Belluomini is offline
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
You want the tow in front of the cg.
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Jul 11, 2012, 02:51 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
Quandry
listen to Robert, hook goes in front of the cg. he just saved you a Habu32
jcdfrd is offline Find More Posts by jcdfrd
Old Jul 11, 2012, 03:32 PM
Quandry is offline
Joined Feb 2012
Originally Posted by jcdfrd View Post
Quandry
Cool, will give that a try.
BTW the idea is launch with retracts up and then land with retracts down. When the dolly gets here I will try to figure out if the low tail plane is going to need some kind of a skid or maybe padding on the dolly.
Only other question that comes to mind is - bungee with flaps on or off?
Old Jul 11, 2012, 03:54 PM
DeeCee 57 is offline
Find More Posts by DeeCee 57
Life's short - Enjoy!
DeeCee 57's Avatar
Zurich, Switzerland
Joined Nov 2009
Quandry
... old stuff indeed... 1/3:2/3rd for the hook position
For more info:
http://www.rcgroups.com/forums/showthread.php?t=1219087
DeeCee 57 is offline Find More Posts by DeeCee 57
Old Jul 11, 2012, 03:58 PM
DeeCee 57's Avatar
Zurich, Switzerland
Joined Nov 2009
and flaps up. The bungee will give all the speed you need
PS
Though if you bungee take-off, you might as well save the gear for some other project and slide her in. Way easier
Old Jul 11, 2012, 04:19 PM
cquian is online now
Find More Posts by cquian
USA, TX, The Colony
Joined Dec 2005
PS
Concur, skip the retracts. Landing on a rough grass field will put the highest stress on retracts, which means you will have to invest in upgraded struts at a minimum, which will still require some maintenance after x number of landings.
For 7-8lbs, just get a good bungee cord, you will need 25-30 lb of pull, going by the measure 3-5 lbs of pull per lb of plane.
cquian is online now Find More Posts by cquian
Old Jul 11, 2012, 07:23 PM
jamnbec is offline
Find More Posts by jamnbec
Jamie
alaska
Joined Sep 2006
I think belly landing this plane will be a problem. The not so horizontal Stabs stick down lower than the belly. They would sure take a beating.
jamnbec is offline Find More Posts by jamnbec
Old Jul 11, 2012, 07:25 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
yep!!! not to mention the flap and aileron pushrods and horns
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
