Old Apr 15, 2012, 08:36 PM
tvessie is offline
Find More Posts by tvessie
737DRIVER
tvessie's Avatar
United States, CA, Woodbridge
Joined Mar 2008
Husafreak
Eric, that video turned out really cool! Really like the clouds reflecting off the bottom of the BU. Nice burp at the end of the vid, very nice touch! Hey, thanks for the heli book in my mailbox, reading it now! Thanks for the phone call this weekend to fly, good job!!
Tom
tvessie is offline Find More Posts by tvessie
Old Apr 16, 2012, 09:06 AM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
Here is a video taken with a small camera attached to the top of the left inlet. Plane is powered with a TJ80 fan and NeuMotors 1512/1.5Y on 10S 3300s. Flies great!
Habu 32 April 15 San Diego.mov (5 min 27 sec)
Steve Neu
sneu is offline Find More Posts by sneu
Old Apr 16, 2012, 10:40 AM
Husafreak is offline
Find More Posts by Husafreak
Husafreak's Avatar
United States, CA, Livermore
Cool videos guys, thanks for sharing, 10s, 12s !! Yo Tom! Don't you "work" weekends? As for the burp, I think the filmmaker gets credit for that, I'm just glad he didn't put a fart in there on me...
Husafreak is offline Find More Posts by Husafreak
Old Apr 16, 2012, 06:10 PM
whisperdancer is offline
Find More Posts by whisperdancer
Portugal, Porto District, Maia Municipality
Joined Aug 2008
Will a gear door cut some of the airflow that goes through the ESC (which is sucked between the duct gap)?
A door is tempting, but it will close the existing opening for the front gear and wheel.
whisperdancer is offline Find More Posts by whisperdancer
Old Apr 16, 2012, 06:23 PM
ZACATTACK is offline
Find More Posts by ZACATTACK
ZACATTACK's Avatar
Canada, ON, Hamilton
Joined May 2011
A nose gear door will eliminate air being sucked up through that space(most of it) while more concentrated air flow wil occur at the gap your refering to.If your ESC is located there...try to log the temperatures on your ESC and see if the nose door did anything postive toward cooling proporties of your electronics/batteries.Bet it makes a difference.
ZACATTACK is offline Find More Posts by ZACATTACK
Old Apr 16, 2012, 09:56 PM
tvessie is offline
737DRIVER
tvessie's Avatar
Joined Mar 2008
sneu
Great video quality. What kind of camera is that?
Old Apr 16, 2012, 10:59 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
We have 4 Habus currently flying, with Castle ESCs They all have the ESC mounted in front the opening where the ducts converge. None have had heat issues.
I remove the plastic case from thenewer ICE ESCs. glue the two heat sinks half together with Artic Silver epoxy (just a few dots on each side)
The Esc will fit above the battery tray, but I put it in a hole dremeled in the battery plate riser, down below.
The NACA duct under the nose brings in plenty of air. I cleaned up (removed)the lip at the inlet with Dremel on all of them.
There have been quite a number of instances of flying the Habu 32 with no nose gear door, where the canopy comes flying off at high speed due to the pressure build up in the cockpit.
This is a problem with the canopy latch pin being a bit too short. You can screw a 2mm screw into the end of the latch pin (as Lashmett did).
I didn't have a screw the first time, so I screwed in a CF rod and epoxied an Alum tube over it.
I do this to all Habu's, even with full gear doors.
To each his own, but there's a few ideas for you
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Apr 16, 2012, 11:35 PM
sneu is offline
sneu's Avatar
Joined Dec 1999
It is this one :http://www.hobbyking.com/hobbyking/s...dProduct=17200 -- $36 plus shipping.
Steve
Old Apr 17, 2012, 01:04 AM
houstonderk is offline
Find More Posts by houstonderk
United States, MD, Clinton
Joined Oct 2010
I have acouple of those and those go to 720p, but that first vid I was asking about I noticed went to 1080...
houstonderk is offline Find More Posts by houstonderk
Old Apr 17, 2012, 01:52 AM
Husafreak's Avatar
That is the same camera Jason used, I just bought one for myself. had to pick up a Rare Bear Fun racer too make it worthwhile.
Old Apr 17, 2012, 08:05 AM
Joined Aug 2008
The Naca duct seems small, but I have no experience on this and I didn’t knew the airflow running on it.
I hopefully will start the assembly now (servos and epoxy should arrive this week), so I want to get it right the first time.
My ESC will definitely need cooling, as I’m using a YGE 80A (stock fan and motor, external BEC). Although the YGE’s are very reliable and known to stay cool even with high currents, I don’t want to risk the entire plane.~
I don’t plan to upgrade just yet because if I like the EDF scene I will want to get a more powerful setup later (maybe 12s with two 6s in series instead of parallel).
I am planning to put the ESC exactly in the front of the duct gap (with the top and bottom being vertical, caps to the front), as it doesn’t have a hard case (just heatshrink) and air can flow through it.
Extending the latch pin is on the agenda, so is threadlocking the latch ball.
Thank you for all the ideas (I'm reading the entire thread, but I'm still on page 270... )
Old Apr 17, 2012, 11:53 AM
Husafreak's Avatar
I have a CC Pheonix 85HV sitting between the ducts with no additional cooling, full nose gear door. It is fine, many flights, that ESC has cooling fins though, If you use a "lite" type ESC w/out fins I would bring some air in there. NACA ducts are available from BVM for installation in any plane. (But the standard gear door cutout will bring plenty of air.) They do a great job. On our Henseleit TDR 700 class helis we put a tiny 10mmx20mm NACA duct in the canopy and it brings the temps down over 20 degrees on those monster 12s 5000 mah setups.
Old Apr 17, 2012, 12:39 PM
ZACATTACK's Avatar
Joined May 2011
This is a great upgrade for guys flying in hot weather with a stock set up. This will give you a heat-sink for the motor and the ability to put your esc in the tail cone.Oh Yeah..it wont break the bank!
http://www.tamjets.com/original/popup_image.php?pID=653
Old Apr 17, 2012, 01:01 PM
vasek is offline
Find More Posts by vasek
Joined Nov 2003
very nice ! if it fits the sock motor, where can I order one online?
thanks, v.
vasek is offline Find More Posts by vasek
Old Apr 17, 2012, 01:37 PM
efflux RC's Avatar
Joined Aug 2009
@ wisperdancer,
When using ESCs that don't have the big external Heat sinks, (YGE, Castle, etc.) I like to cut away the heat shrink at the cap end and the motor lead end so the air can flow thru the ESC.
There are heat sinks those ESCs as well they are just little metal plates or bars on the FETs.
Site Sponsor
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
