Old Mar 28, 2012, 04:48 PM
ZACATTACK is offline
Find More Posts by ZACATTACK
ZACATTACK's Avatar
Canada, ON, Hamilton
Joined May 2011
Originally Posted by jcdfrd View Post
well you can Doppler that just for fun but that one is an unofficial run Tams was still shaking things out and it was really cold so the speeds were up a little.....Tam was the pilot in that video and was really hungover from the party the night before lol!!!
That's the video I was talking about John..you can hear the Wave Scope electronically going off twice saying 182.5.then 180.5.Thing is I am going to upgrade eventually and I'm just trying to confirm the numbers..I have a Doppler program but cannot do it rite now.Someone will do it..that Habu is moving...especially in the first high speed turn around...man that looked great!!
ZACATTACK is offline Find More Posts by ZACATTACK
Old Mar 28, 2012, 04:49 PM
hypstar is offline
Find More Posts by hypstar
hypstar's Avatar
Sweden
Joined Sep 2008
Originally Posted by Tamjets View Post
"I fly faster than John when I had hangover".
Tam!...,always the worse one ..right?,I thought you were the proud and calm leader of the H 32 speed contest
//Andy.
hypstar is offline Find More Posts by hypstar
Old Mar 29, 2012, 04:48 AM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
The only excuse left is the weather.
The CG is set at 107 mm from the LE on the fuse. My best packs are only 8s 3300 mah 50c. They are right up against the steering servo for balance. Directly behind the main pack is the 1100 mah LiFe RX pack and the ET Logger on top of that.
My 5000s are only 25 c and the voltage sags too quickly. Ok for a cruise but not a challenge.
Good luck to all fellow entrants. j
jayb1rdz is offline Find More Posts by jayb1rdz
Old Mar 29, 2012, 07:39 AM
houstonderk is offline
Find More Posts by houstonderk
United States, MD, Clinton
Joined Oct 2010
My excuse has been that for some reason it has been taking almost 2 months just to get 1 wing bolt that I was missing. Had to order online and for some reason this bolt has been the hardest thing to get... :/ Hopefully it will be here this weekend.
houstonderk is offline Find More Posts by houstonderk
Old Mar 29, 2012, 08:06 AM
flemsus is offline
Find More Posts by flemsus
Denmark, Nordjylland, Gistrup
Joined Aug 2005
I hope it goes well. I have seen a lot of people in here having the CG at 115 mm.
flemsus is offline Find More Posts by flemsus
Old Mar 29, 2012, 10:19 AM
whisperdancer is offline
Find More Posts by whisperdancer
Portugal, Porto District, Maia Municipality
Joined Aug 2008
Does any air pass through the ESC? Where is the best place to mount it in order to get maximum cooling? I noticed there is a gap between the intake ducts...
I will use the stock motor and fan with an 80A ESC (YGE, in this case), but the ESC manufacturer stated it should have a good cooling. Also refered if I wanted to use the internal BEC, I should use a buffer pack (4x Enellop 800mAh) only for safety.
whisperdancer is offline Find More Posts by whisperdancer
Old Mar 29, 2012, 10:49 AM
tclaridge is offline
Find More Posts by tclaridge
United States, VA, Clifton
Joined Nov 2005
The ESC gets good air if you stick it on the side of the intake right in front of the intake "gap." Also, I would go with an external BEC like a Castle Pro. The BEC will not get warm, so I stuck it under the battery tray.
tclaridge is offline Find More Posts by tclaridge
Old Mar 29, 2012, 06:01 PM
Joined Aug 2008
But a buffer pack gives safety as it's a redudant system. Most BECs don't seem to allow a buffer pack as it will damage the BEC.
I'm really considering one connected to the battery port of the receiver with a switch and a led to catch my attention if it's connected or not.
Old Mar 29, 2012, 06:29 PM
Friedclutch is offline
Find More Posts by Friedclutch
Got Brushless?
Friedclutch's Avatar
Sacramento
Joined Sep 2007
A castle pro bec is way, way, overkill but a lot of guys have them. 20 amps guys? On a small edf? hehe
I am using the castle 10 amp on a couple planes including the Habu 32. Even a 10 amp reg is quite overkill. It's about the size of a piece of gum. Programmable. Cheap. Light. Small.
http://www.rcdude.com/servlet/the-70...10A-BEC/Detail
Friedclutch is offline Find More Posts by Friedclutch
Old Mar 29, 2012, 09:31 PM
nippaero is offline
Find More Posts by nippaero
nippaero's Avatar
United States, ID, Nampa
Joined Oct 2009
+1 for rcdude
nippaero is offline Find More Posts by nippaero
Old Mar 29, 2012, 09:39 PM
ZACATTACK's Avatar
Joined May 2011
I gotta disagree..us guys on 8S and above are recommended by CC to use the Pro model ... the little blue one is only rated to 6S..I dont listen to the wife but I listen to Castle Creations!!
Old Mar 29, 2012, 11:02 PM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
CC Pro BEC is the way to go.
Just for another $15 how much reliable you get.
Tamjets is offline Find More Posts by Tamjets
Old Mar 29, 2012, 11:11 PM
keithtsr is offline
Find More Posts by keithtsr
Keith Thomas
keithtsr's Avatar
United States, NM, Portales
Joined Feb 2010
I know the Castle BEC Pro is suppose to be good to 10s but somewhere I remember something about them only being safe to use with less cells. Am I right or did I dream this up Tam?
keithtsr is offline Find More Posts by keithtsr
Old Mar 29, 2012, 11:38 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Is good for 12s and been running in my hot rod over 50 flights now.
Old Mar 29, 2012, 11:45 PM
keithtsr is offline
Keith Thomas
keithtsr's Avatar
Joined Feb 2010
That's good to know. Castle recommends only 10s for airplanes but it is good to know that It will take 12s.
I got to stop dreaming so much. You know the Hobby getting to you when you start dreaming about this stuff.....I miss my old dreams they were so much more fun.
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
