Joined May 2011
there is not enough air flow in that spot, even after opening up the rear battery tray former to let air go thru, if you look back in this thread Bri6672 played around with that spot and he had to make a naca duct opening to eventually get enough cooling to the esc which was an ice120 mounted underneath to the battery tray
Latest blog entry: Pan/Tilt servo mods
Hey spy, for some reason, I though you had a TJ setup. You must gave so thing else.
There is 2 stock Habus where I fly. I am sure at least one has the recommended ESC and placement under the packs. In that config, it's fine. It's as soon as you power it up with more that all the engineering needs to be changed. I have miy ICE 120 between the ducts and I have Dremel extra slots on the rear lower edge of the canopy for extra air draw. If I consider hoping up more, I will remove shelf for the packs and get them on the floor so they are less obstructed by the air flow too. |
Here's an early ice 120. But you can remove the plasitc case from any of them for the same result. I've done it with the HV2 120 and ICE 100. Just glue the two hear sink halfs together. This makes a much smaller footprint.
Just get the ESC between the battery tray and where the ducts come together. Theres plenty of airflow from the fan there, and the air gets pulled in thru the stock NACA duct (I clean it up a bit to remove the molded ridge) We've built 5 Habus with ICE 100s or 120 HVs in this area with no problems whatsoever.
| Thread Tools | |
| Discussion Fiberglass Habu Airframe | Calvin_220 | Electric Ducted Fan Jet Talk | 92 | Nov 10, 2012 02:53 AM |
| Sold New in box Habu EDF PNP | flyboy1945 | Aircraft - Electric - Jets (FS/W) | 2 | Aug 01, 2010 08:24 PM |
| Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread | SalamSyed | Foamy EDFs | 0 | Mar 20, 2010 11:15 PM |
| New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer | nitroplanes | Nitro Planes | 0 | Jan 24, 2009 09:58 AM |
| Discussion Baja SS Speculation and hopup thread. | DaveESPI | Large Scale Cars | 3 | Feb 03, 2008 07:39 PM |
