Old Feb 21, 2012, 09:23 PM
jamesbuckley is offline
Find More Posts by jamesbuckley
jamesbuckley's Avatar
United States, MI, St Clair Shores
Joined Sep 2010
Originally Posted by Tamjets View Post
That what I got in the oven. The machine shop should had my heat sink to fit stock fan by end the week.
Also with my CF tailcone for install ESC behide the motor.
Now we can had stock E-Flite fan able to run on 7s.
Hi Tam,
Do You have a CF tail cone for a 28mm 8S mega motor/stock Eflite v32 fan
that i can use to put the ICE 100 (w/green heat sink) behind the fan?
Jim
jamesbuckley is offline Find More Posts by jamesbuckley
Old Feb 21, 2012, 10:01 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Jim,
The MEGA motor is a hot set up and requires a heat sink with big fins on it. I would not recommend putting the motor in a fairing.
Just put the Castle ICE 100 esc (with green heat sink) between the ducts where they come together. There is a big slotted opening that pulls tons of air directly from the fan.
We've built quite a few of these with the ESC placed as above, and had not problems with the ESC temperature at all. If you ESC goes south, it's bcacuse you got a bad one (that happens).
You will only need to extend the motor wires about 6" from the motor to the ESC with 12GA wire.
This will also save you from having to add 10GA wire on the battery side, as well as not needing a Cap Pack. or a big buky harness if you 6mm bullets instead Deans connnectors.
JMO.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Feb 21, 2012, 10:45 PM
bradenj is offline
Find More Posts by bradenj
United States, OK, Oklahoma City
Joined Jan 2012
I ordered the stock servos called out in the manual and I was going to install but realized the the servo arms are diff then the one in the picture. do you have to buy these separate?
bradenj is offline Find More Posts by bradenj
Old Feb 21, 2012, 11:13 PM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
James, you should go one way or the other....
the ICE 100 with green heatsink is a very large ESC and would really disrupt the airflow. The ESC that Tam uses are the smaller ones that fit neatly behind the motor.
I use the Ice 120 HV and have it between the ducts. I provided "extra air" for it by dremelling some grooved slots into the canopy right on the black edge. you can really feel it drawing the extra air but the mod is almost invisible.....and very easy to do.. I decided to do this since I have opted for a tight sealing nose gear door and I'm not a good enough modeller to trust myself with more complicated naca duct mods.
Ciao J
jayb1rdz is offline Find More Posts by jayb1rdz
Old Feb 22, 2012, 04:38 AM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Originally Posted by jamesbuckley View Post
Hi Tam,
Jim
Jim,
The CF tailcone only can fit our heat sink.
Beside the standard heat sink not go to cut the cake. It just not area to cover the motor for cooling.
The 28mm motor need all the cooling it can get. One of our friend his 28mm motor was running the standard heat sink and it start show the motor loosing power.
So my suggestion is to wait for my heat sink to finish and get the whole things to the job.
It works so well for TJ fan and now with same design can adapt to stock E-Flite fan.
Here is 50% is done. One more set up tomorrow to finish the job.
Tamjets is offline Find More Posts by Tamjets
Old Feb 22, 2012, 09:58 AM
Mike Freas is offline
Find More Posts by Mike Freas
KK4NOP
Mike Freas's Avatar
United States, MD, Lusby
Joined Aug 2005
Is it possible to remove both positive and negative leads in the ESC connector so I can use the leads from my external BEC in this connector?
The reason I ask is I have a 9 channel RX and the CC BEC Pro has two power output leads and I'd really like to use both. I know it's way overkill in this application but it would make me fell better. I'm also feeding direct power to the receivers SPC port.
I've never tried this so I figured I'd ask.
Mike Freas is offline Find More Posts by Mike Freas
Old Feb 22, 2012, 10:18 AM
jwjohnson is offline
Find More Posts by jwjohnson
Hit Me! Please!
jwjohnson's Avatar
Provo, UT
Joined Jan 2005
If you remove them both you won't have throttle control.
If you want to use both leads off the CC BEC Pro just put a y-connector on the receiver ports you want to power. I just do one on channel 1 and one on channel 8 or 9. I avoid using the lightweight connectors for this.
jwjohnson is offline Find More Posts by jwjohnson
Old Feb 22, 2012, 10:49 AM
KK4NOP
Mike Freas's Avatar
Joined Aug 2005
I was thinking that the ESC only needed a signal from the RX as it receives it's power from the main battery. I already have the red lead removed so the internal BEC doesn't power the RX also. So you are saying I need a signal and ground for the ESC to work?
I'm out of channels on my RX and would rather keep the Y's to a min as it makes adjusting things more difficult.
Old Feb 22, 2012, 11:03 AM
bdelapen is offline
Find More Posts by bdelapen
Sponsored by Team de la Peņa
bdelapen's Avatar
United States, FL, Pembroke Pines
Joined Aug 2008
The signal to the ESC is worth nothing without a reference point, that's what the ground is for.
Short version, without signal and ground the ESC will not work, you can ONLY remove the red wire.
- Birger
bdelapen is offline Find More Posts by bdelapen
Old Feb 22, 2012, 11:26 AM
KK4NOP
Mike Freas's Avatar
Joined Aug 2005
- Birger
Got it.
Now to find plan B
Should I just use one of the BEC's power leads and get over being anal or Y another set of servos to free up another pinset?
Old Feb 22, 2012, 11:34 AM
bdelapen is offline
bdelapen's Avatar
Joined Aug 2008
Got it.
Now to find plan B
Y your ESC and one of your BEC leads, that way you don't give up any programmability on your other channels. This gives you the added bonus of being able to clip the red wire on the Y harness (on the path to the ESC) and not having to mess with the ESC connector to disable the internal BEC.
- Birger
Old Feb 22, 2012, 11:57 AM
KK4NOP
Mike Freas's Avatar
Joined Aug 2005
- Birger
I was just thinking about doing this. Basically I'll only be using a Y for the ESC and BEC to share the ground. Doing this will allow me to power my servos from two pinsets and the Rx off the SPC.
Old Feb 22, 2012, 12:39 PM
vasek is offline
Find More Posts by vasek
Joined Nov 2003
Is there a sketch of that hook-up ? would love to see it. Thanks
vasek is offline Find More Posts by vasek
Old Feb 22, 2012, 02:58 PM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
The dual output wires from the BEC Pro are because one servo connector is not rated above 5 amps.
Y'ing them together serves no purpose at all. You're down to one connector again.
Just use one and check to make sure you don't pull too many amps for that connector.
Michael Paxton is offline Find More Posts by Michael Paxton
Old Feb 22, 2012, 03:16 PM
bdelapen is offline
bdelapen's Avatar
Joined Aug 2008
What you do is you put a short Y-Harness with thicker gauge wire into each end port of your receiver (i.e. first and last). One end of each Y-Harness gets one of the BEC outputs and the other end get's whatever was plugged in to the receiver in the corresponding port. If what you are plugging in is the ESC then you can also use the Y harness to isolate the ESC internal BEC by clipping the red wire on the Y-Harness at the end that the ESC plugs into (NOT the end that plugs into the receiver).
- Birger
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 03:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 09:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 21, 2010 12:15 AM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 10:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 08:39 PM
