Old Jan 14, 2012, 08:49 AM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
Originally Posted by dgfinch View Post
My new Habu is on the build bench. While I am waiting for my Stumax powerplant to arrive I have some time to find a cradle for her.
I am looking for the soft foam cradle that I have seen around, but I can't find now. I have a hard plastic cradle (from Ernst I think), but I am looking for the one that goes together like building blocks.
Anybody know what I am talking about?
TIA
Robart makes one http://www.robart.com/store/hobby-tools/airplane-stands
Michael Paxton is offline Find More Posts by Michael Paxton
Old Jan 14, 2012, 09:03 AM
Robert Belluomini is offline
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
http://shopbvmjets.com/zencart/index...548jp0qf0vluf6
You mean this one?
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Jan 14, 2012, 09:04 AM
Joined Dec 2000
You mean this one?
Old Jan 14, 2012, 09:16 AM
Joined Dec 2000
You mean this one?
Old Jan 14, 2012, 09:19 AM
pyy1axs is offline
Find More Posts by pyy1axs
Abe
United States, IL, Chicago
Joined Nov 2007
http://www.espritmodel.com/standbox....sletter-201202
pyy1axs is offline Find More Posts by pyy1axs
Old Jan 14, 2012, 11:12 AM
bdelapen is offline
Find More Posts by bdelapen
Sponsored by Team de la Peņa
bdelapen's Avatar
United States, FL, Pembroke Pines
Joined Aug 2008
TIA
I think there are two or three different models:
This one which is probably the one you want:
http://www.nitroplanes.com/79p-8002-foamstand-blue.html
Though there is this one as well (probably smaller than you want but nonetheless):
http://www.nitroplanes.com/79p-8002-...and-green.html
Or there is this one which I believe is slightly longer (though I'm not 100% sure):
http://www.espritmodel.com/foam-field-stand.aspx
Of course, the robart styrofam and plastic tube stand (super stand II) is a good one too:
http://www3.towerhobbies.com/cgi-bin...&I=LXES03&P=FR
Hope this helps,
- Birger
bdelapen is offline Find More Posts by bdelapen
Old Jan 14, 2012, 11:39 AM
Nashville TN.
Joined Mar 2006
LOL Search is your friend!
Old Jan 14, 2012, 11:43 AM
keithtsr is offline
Find More Posts by keithtsr
Keith Thomas
keithtsr's Avatar
United States, NM, Portales
Joined Feb 2010
Does anyone know about the Jetfan 80? It looks pretty good but I wonder if it's a knock off fan? To the untrained eye, that would be me, it looks someone went out and designed it from scratch.
It looks good.
keithtsr is offline Find More Posts by keithtsr
Old Jan 14, 2012, 11:48 AM
Nashville TN.
Joined Mar 2006
If you look at the design of the blades Keith, you'll see that it was designed primarily with the sound in mind. The way the blades are shaped is not the best for efficiency or for thrust.
I would call it a "Scale" EDF.
Old Jan 14, 2012, 11:53 AM
420flyboy is offline
Find More Posts by 420flyboy
Mile High EDF
420flyboy's Avatar
United States, CO, Denver
Joined Jul 2011
I have 2 jetfan 80 and they put out more thrust than the stock setup, using a arc 2080 , about 92 amps and 6lbs of thrust. Yes they sound amazing
Habu 32 Denver (3 min 30 sec)
420flyboy is offline Find More Posts by 420flyboy
Old Jan 14, 2012, 11:59 AM
Nashville TN.
Joined Mar 2006
In comparison: an eflite 80mm puts out 5 lbs of thrust at 62 amps.
That's on 6 cell. Don't know what you're using.
Old Jan 14, 2012, 12:04 PM
Mile High EDF
420flyboy's Avatar
Joined Jul 2011
6s 5000mah nano, getting 4:30 flights. It's a personal things , isn't it ? These are all toys in a sense , for me this is a good compromise between flight time , sound and money spent. I have a 1900kv and 2150kv to play with in these fans, I feel they are a good value for your money , and if you look at the thread they are selling fast, must mean something .
Old Jan 14, 2012, 12:08 PM
Mile High EDF
420flyboy's Avatar
Joined Jul 2011
Installed Static Thrust: 4.50 lbs
RPM: 38,500
Watts: 1,400
Current: 62A
* Data measured installed in Habu 32 DF using BL32 DF Brushless Motor, 2150Kv & 6S 5000mAh 30C Battery
This is the eflite data in a habu 32, just wondering where you got 5lbs.
Old Jan 14, 2012, 12:29 PM
chevronflyer is offline
Find More Posts by chevronflyer
"Takeoffs are optional"
chevronflyer's Avatar
United States, FL, Middleburg
Joined Feb 2007
RPM: 38,500
Watts: 1,400
Current: 62A
Notice it says installed *STATIC* thrust is 4.5lbs. Once you are airborne and moving at speed the fan efficiency increases because it doesnt have to suck air in as hard, it has ram air coming in to help lesson the work load.
5 lbs sounds about right to me. if you want to know an exact thrust number in flight you can do what i do. buy an annemometer and a leaf blower and a fish scale. hook the scale to the tail of the plane to measure pounds of pull, position the leaf blower so it is blowing down the intake and adjust wind speed to obtain 100mph as measured with the annemometer.
chevronflyer is offline Find More Posts by chevronflyer
Old Jan 14, 2012, 12:31 PM
Mile High EDF
420flyboy's Avatar
Joined Jul 2011
Originally Posted by chevronflyer View Post
Notice it says installed *STATIC* thrust is 4.5lbs once you are airborne and moving at speed the fan efficiency increases because it doesnt have to suck air in as hard, it has ram air coming in to help it out.
Same goes for my setup, that's 6.4 lbs static.
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
