Old Jan 08, 2012, 10:53 PM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
Now we need more than two airframes to put them all in!!
Originally Posted by spyda00 View Post
I just started to think of all the motor and fan setups possible for the Habu32 (not considering the cell setups )
There is a lot of options lol, where to start ? probably more out there i dont know about
- Eflight fan / eflight motor (stock)
- Eflight fan / Mega motor
- Eflight fan / nu motor
- Efflux alloy / mega motor
- Tamjet tj80 / ??
- Jetfan80 / ??
- Extreme Rc 12blade / ??
- Stumax / ??
- RC lander / 3660 2120kv
- Jetcat p20 turbine
- Wemo 80mm (heard its in development )
Michael Paxton is offline Find More Posts by Michael Paxton
Old Jan 08, 2012, 10:54 PM
tulz43 is online now
Find More Posts by tulz43
tulz43's Avatar
Los Angeles, CA
Joined Sep 2007
Originally Posted by stoneenforcer View Post
stalled. Thats the 3rd stall crash i've seen on a 32. Keep telling them to stop flying it like its foam.
+1...
tulz43 is online now Find More Posts by tulz43
Old Jan 08, 2012, 11:10 PM
420flyboy is offline
Find More Posts by 420flyboy
Mile High EDF
420flyboy's Avatar
United States, CO, Denver
Joined Jul 2011
The wemo is available at their website, comes with motor , costs about $200
420flyboy is offline Find More Posts by 420flyboy
Old Jan 09, 2012, 02:23 AM
vasek is offline
Find More Posts by vasek
Joined Nov 2003
spyda, you forgot one
jetfan 80 great on the 2080kv arc motor
http://shop.ejets.at/OShop/ViewProdu...a&OShopLANG=en
- Tamjet tj80 / ??
- Jetfan80 / ??
- Stumax / ??
vasek is offline Find More Posts by vasek
Old Jan 09, 2012, 07:07 AM
tclaridge is offline
Find More Posts by tclaridge
United States, VA, Clifton
Joined Nov 2005
You guys are good! Yes the washout is 1 deg as verified by Horizon, and yes I think 2-3 would have been better, but it is not going to get changed for the Habu 32. I was just hoping to make folks aware of the issue and offer a choice to "fake" the extra twist with the controls to make it more stable.
tclaridge is offline Find More Posts by tclaridge
Old Jan 09, 2012, 08:43 AM
Madmax1965 is offline
Find More Posts by Madmax1965
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
Maybe you pilots are trying to make the Habu more than what it is....a very fine sport plane. I have maybe 50 flights on my 32 now and with the exception of buggering up a front retract on landing the plane has flown flawless. I am sure that Horizon designed the 32 to fit a niche and so far from what I can see they hit the nail on the head.
As for those who have not flown EDF very much(or are new to EDF)....or for those old people like me......I suggest you build the plane in the stock form and save yourself lots of problems. You can have fun doing 100+ with this plane.....then once you have it dialed in go to the "hot" stuff if you want. The way I figure is if you cannot take-off and land this plane in stock form with stock setup using flaps only then you surely don't need a heavy wing-loading hot rod.....least not yet. Just saying.
Madmax1965 is offline Find More Posts by Madmax1965
Old Jan 09, 2012, 02:03 PM
STEVEAIR2 is offline
Find More Posts by STEVEAIR2
STEVEAIR2's Avatar
Dublin Ireland
Joined Aug 2005
Madmax
Could you tell me the throws you dialled in to your HABU ?
I see on a previous post you reduced the recomended throws.
Also
When some one says they have put in 1.5 degrees washout on the ailerons and flaps
what does that equate to in MM/inches
Cheers
Steve.
STEVEAIR2 is offline Find More Posts by STEVEAIR2
Old Jan 09, 2012, 03:54 PM
Joined Nov 2005
See post #2431 for wing twist simulation with control settings. It is just 1/16" on each flight surface creating a 1/8" space between the two surfaces where they meet in the middle of the wing. Not as efficient as wing twist, but it works.
By the way, I think some folks are doing a disservice to this thread by dismissing issues to rookie mistakes or "flying like a foamie." This is a real issue that has been explained in previous posts. Please don't make assumptions without at least going through the information already provided.
Old Jan 09, 2012, 07:42 PM
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
Steve:
Madmax
Steve i will measure them tomorrow for you.....I forgot what I put in them......not much less on low but I did bring down the high throws. I use the high throws most times for take-off then switch over to low for flying unless I want to get wild. I suppose some of the more hot pilots use the high rates but they can get you in trouble if you don't pay attention. I crashed a few EDFs before I understood some of the flying characteristics of the planes. I learned lots flying my Fox BlackHawk but to tell the truth I like this little Habu as much as any EDF I have owned.
Old Jan 10, 2012, 06:15 PM
Mile High EDF
420flyboy's Avatar
Joined Jul 2011
The habu reborn from the fire
Habu 32 flying (4 min 33 sec)
Old Jan 10, 2012, 07:53 PM
Jetsom is online now
Find More Posts by Jetsom
Formerly "Heli Copter"
Jetsom's Avatar
United States, CA, Watsonville
Joined Apr 2009
http://youtu.be/Bv8rezmlwlw
Well done Flyboy!
Jetsom is online now Find More Posts by Jetsom
Old Jan 10, 2012, 10:26 PM
Mile High EDF
420flyboy's Avatar
Joined Jul 2011
Originally Posted by Heli Copter View Post
Well done Flyboy!
Cool , thank you, glad to fly it again . Put back in my 80mm jetfan with HK 1900kv , pulled 82 amps and 1800 watts.
Old Jan 10, 2012, 11:28 PM
mavdriver is offline
Find More Posts by mavdriver
mavdriver's Avatar
United States, CA, Apple Valley
Joined May 2002
6s ?
mavdriver is offline Find More Posts by mavdriver
Old Jan 10, 2012, 11:39 PM
Mile High EDF
420flyboy's Avatar
Joined Jul 2011
Yep 6s , 5000 mah nano tech 35-70c, 100 amp castle esc.
I'm using a 9 blade fan in a carbon fiber shroud , made by jetfan in Germany . It can take up to 42mm motors, letting you go up in size and use more efficient designs, then you have easy option of going 7-8s.
Old Jan 11, 2012, 01:28 AM
Mannyman535 is offline
Find More Posts by Mannyman535
edf flyer
Mannyman535's Avatar
United States, CA, Marina
Joined Feb 2009
Habu parts
Can anyone tell me where I should look to get some parts that
Isn't listed from horizon hobby. I need some of the wood pieces.
Mannyman535 is offline Find More Posts by Mannyman535
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
