Old Jan 06, 2012, 07:12 PM
VooDoo Child is offline
Find More Posts by VooDoo Child
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, OR, Portland
Joined Aug 2010
Originally Posted by stoneenforcer View Post
a day at the field. watched my bro stall his 32 then powerdive into the ground.
Ouch,that su#$s...seems this has happened to a few people.
VooDoo Child is offline Find More Posts by VooDoo Child
Old Jan 06, 2012, 07:19 PM
choopi is offline
Find More Posts by choopi
choopi's Avatar
New Brunswick
Joined Feb 2006
Originally Posted by RCISFUNREM View Post
Has anyone used this fan/motor from Hobby King?
http://www.hobbyking.com/hobbyking/s..._2000watt.html
What about these retracts?
http://www.hobbyking.com/hobbyking/s...ke_Small_.html
that fan look nice!
Look like the RClander
choopi is offline Find More Posts by choopi
Old Jan 06, 2012, 09:54 PM
ZACATTACK is offline
Find More Posts by ZACATTACK
ZACATTACK's Avatar
Canada, ON, Hamilton
Joined May 2011
What was the cause of this Crash??
ZACATTACK is offline Find More Posts by ZACATTACK
Old Jan 06, 2012, 09:57 PM
Joined Aug 2010
He posted that it was a tip stall....then throttled it up and chased it to the ground.
Old Jan 07, 2012, 10:03 AM
Jetnfast is offline
Find More Posts by Jetnfast
Jetnfast's Avatar
United States, CA, Temecula
Joined Feb 2008
Hey guys, question...did a search and didnt find anything on it (unless I missed it of course!) but what is the best way to bend the stock main gear doors without cracking the paint? I don't seem to be getting anywhere with this!
How many of you run the doors, and how many of you ditch them all together?
I saw the technique about rounding the doors if you fly on grass fields but thats about it!
Jetnfast is offline Find More Posts by Jetnfast
Old Jan 07, 2012, 11:30 AM
Robert Belluomini is offline
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Take a blunt exacto blade and using the thick edge score the backside of the door. Then turn the door over paint side up and use the edge of your table to slightly fold the door along the score.
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Jan 07, 2012, 12:01 PM
tclaridge is offline
Find More Posts by tclaridge
United States, VA, Clifton
Joined Nov 2005
stoneenforcer, this is what mine looked like after I hit the dirt after a tip stall. I pulled out the electronics, and put it in a new bird. I only had to replace the front nose retract.
I am convinced that the "twist" I put in the controls has kept this from happening a second time, plus beware of the high rates as they can tip stall the wing. An accelerated stall with this bird without wing twist is almost unrecoverable.
tclaridge is offline Find More Posts by tclaridge
Old Jan 07, 2012, 01:19 PM
cquian is online now
Find More Posts by cquian
USA, TX, The Colony
Joined Dec 2005
Could you elaborate on what you mean by "twist in control" or "wing twist"?
cquian is online now Find More Posts by cquian
Old Jan 07, 2012, 01:51 PM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
washout.
scatsob is offline Find More Posts by scatsob
Old Jan 07, 2012, 02:03 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
I scored them as Bob B mentioned, but I folded them in three places (first photo) to get a better seal against the wing.
Then I decided straight sides would be better, so I made my own from .040" Styrene. They seal great against the wing. The leading edge angle helps with FOD and runway cracks, but might wanna make them shorter then mine for grass operation.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Jan 07, 2012, 02:32 PM
Jetnfast is offline
Jetnfast's Avatar
Joined Feb 2008
Bob- awesome advice, thank you!
Gary - I found all your threads on your homemade gear doors and they look great! I don't plan on flying mine off grass, so I guess there is no need to round the edges, but I like the fact yours seal up better with the wings.
So it sounds like most guys are going with gear doors for limiting drag and asthetic purposes?
Old Jan 07, 2012, 02:38 PM
ZACATTACK's Avatar
Joined May 2011
There going to crack, split, loosen...then your going to fix them, then there going to crack, split, loosen... then your going to fix them. Dont bother with them..trust me..it makes no difference in speed or flight characteristics having these on or off. Just my 2 cents..but been there done it!!!
Friedclutch is offline
Find More Posts by Friedclutch
Got Brushless?
Friedclutch's Avatar
Sacramento
Joined Sep 2007
Those retract are likely not suitable. They are rated for a 5.5lb model. Your Habu will be at least 7 lbs. I would not set your 1000 dollar habu on those. I am all for running budget hardware though. I have a Turnigy ESC in mine. (not using the built in BEC though) I also looked for a cheaper gear option when building mine and I just couldn't find one. Not to mention.. the stock gear just bolt right in. The 150.00 price tag is swift punch to the groin though.
Friedclutch is offline Find More Posts by Friedclutch
Old Jan 07, 2012, 03:31 PM
efflux RC's Avatar
Joined Aug 2009
Thanks. Doors always look great, add to the uniqueness of your aircraft, and if your interested in speed they will add 5+ mph to your top speed. (especially the nose gear door)
Site Sponsor
Old Jan 07, 2012, 03:58 PM
stoneenforcer is online now
Find More Posts by stoneenforcer
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
stalled. thats the 3rd stall crash I've seen on a 32. keep telling them to stop flying it like its foam.
stoneenforcer is online now Find More Posts by stoneenforcer
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
