Old Dec 28, 2011, 06:14 AM
lrb75 is online now
Find More Posts by lrb75
United States, VA, Springfield
Upgrading the gear later would be easy. The stock fixed gear are the eflite retracts without the jackscrew and electronics. As to the second bec I had to use the outboard bec. I have a v1 eflite 80 amp esc which has a bad bec in it. The cc bec is rated at 10 amps v 5 on the on board bec. The voltage is also adjustable. Finally if the esc burns up there is a chance that the external bec will give me control power. It only costs $20 and it is some peace of mind.
lrb75 is online now Find More Posts by lrb75
Old Dec 28, 2011, 11:37 AM
tclaridge is offline
Find More Posts by tclaridge
United States, VA, Clifton
Joined Nov 2005
A note on the v1 Eflite Pro 80. On my six flight the throttle "snuffed out" like a thermal lockout. But I have checked the ESC, and it does not run hotter than 150-170 deg F. So I sent back and got a v2. Since then I have had no issues.
So they say the v1 was just a BEC issue, but I am not so sure. I would not recommend using a v1 Eflite Pro ESC, and the replacement is free if you ship it to Horizon.
PS I am not using the BEC on the ESC, so that is not what caused the throttle cut out.
tclaridge is offline Find More Posts by tclaridge
Old Dec 28, 2011, 04:44 PM
lrb75 is online now
Tony it is a free replacement if you have a receipt. I bought the Habu as a package from someone off of RCU. No receipts. My throttle never waivered just the servos. See you at the BOX tonight? Ross
Old Dec 28, 2011, 10:54 PM
FresnoJay is offline
Find More Posts by FresnoJay
To drive or to fly......BOTH!!
FresnoJay's Avatar
USA, CA, Clovis
Joined Apr 2007
Here is video from today of A4SpeedJunkie's Habu. Enjoy.
Jason
A4SpeedJunkie's Habu 32 Post Re-paint (3 min 52 sec)
FresnoJay is offline Find More Posts by FresnoJay
Old Dec 28, 2011, 11:01 PM
tulz43 is offline
Find More Posts by tulz43
tulz43's Avatar
Los Angeles, CA
Joined Sep 2007
Man that thing looks awesome. Thanks for sharing the vid!
tulz43 is offline Find More Posts by tulz43
Old Dec 29, 2011, 12:55 AM
setxws6 is offline
Find More Posts by setxws6
Hemi pilot
setxws6's Avatar
USA, TX, Lumberton
Joined Oct 2005
Hi all Habu 32 people. I am considering getting this jet, using the flaps and eflite retracts. I have a Futaba 7cap radio with a 7ch fasst receiver. I would basically have to Y everything together except for the rudder/steering (I could use the 7th ch).
Would I run into any issues using a Y harness on basically all the control surfaces, flaps, and retracts? May seem like a silly question to some, but I've alway simply used 4ch's for all my previous planes...
setxws6 is offline Find More Posts by setxws6
Old Dec 29, 2011, 06:58 AM
Robert Belluomini is offline
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
No problem. Download the manual
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Dec 29, 2011, 08:23 AM
Jetsom is online now
Find More Posts by Jetsom
Formerly "Heli Copter"
Jetsom's Avatar
United States, CA, Watsonville
Joined Apr 2009
No Problem! I would split the ailerons so you can program in a little crow with full flaps. It makes a big difference on landing speed.
Jetsom is online now Find More Posts by Jetsom
Old Dec 29, 2011, 09:39 AM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
If you build the 32 absolutely standard, your TX and RX will be fine. It will even land ok in the stock lightweight configuration. Add any weight though for a faster set up and you will need to consider the crow settings. It is cleverly designed to not need reversed servos or high level programming as a stock build.
jayb1rdz is offline Find More Posts by jayb1rdz
Old Dec 29, 2011, 09:54 AM
setxws6 is offline
Hemi pilot
setxws6's Avatar
USA, TX, Lumberton
Joined Oct 2005
That's probably how I'd build it, stock fan and motor with eflite retracts. Looks like stock it'll still do 120+, which is plenty for where I fly at.
Old Dec 29, 2011, 10:48 AM
tulz43 is offline
tulz43's Avatar
Los Angeles, CA
Joined Sep 2007
No way. Split rudder and steering servo. It's a much easier setup. Crow is nice but def not needed.
Old Dec 29, 2011, 10:53 AM
Snowbird One is offline
Find More Posts by Snowbird One
True North Strong and Free
Canada, BC, Greater Vancouver Regional District
Joined Dec 2011
I think that with the very affordable price of this jet, there are going to be quite a few of us (myself included), who have never had such a fast, high quality, and high performance jet. There are bound to be a LOT of questions that most of these guys would normally take for granted. They may be shaking their heads with how basic some of our questions are. I hope they remain patient with us!
Not that our skills of piloting are insufficient, but building for these speeds becomes much more critical; and these nuances of construction are very new to us. For example, when the manual suggests using epoxy, with a jet like this I start to question whether the hardware store epoxy that I've used on so many aircraft will be completely sufficient, or if I should be going for something put out by modelling companies, such as BVM. And I hear the mention of Hysol, well, I've never heard of such a product before, and I understand that some are using it on the control horns, but is it greatly superior to epoxy, or is epoxy just as good? Is Hysol suitable for spars, etc, and other high-stress, critical structural components, etc.
I have Z-Poxy PT-39 30 minute epoxy. Is that good for all of the epoxy requests in the manual, or should I look into these other adhesives? Should I go for thixotropic or not (a la BVM). So may questions!
Snowbird One is offline Find More Posts by Snowbird One
Old Dec 29, 2011, 11:07 AM
keithtsr is offline
Find More Posts by keithtsr
Keith Thomas
keithtsr's Avatar
United States, NM, Portales
Joined Feb 2010
I have used Hysol on one of my Habu's and regular 5 minute on the other 2.
I think regular epoxy is fine for the control horns, just make sure you sand the horn down a little. I cleaned mine with alcohol before I sand the horn, just to remove any mold release. I stuffed my first Habu and high speed into a metal fence, it probably hit at close to 100mph. The control horns on the stab ripped out taking a bunch of the wood with it. The rest of the horns stayed in place.
Don't over think this little jet, yes we must take care during construction but it's pretty straight forward in it's build.
keithtsr is offline Find More Posts by keithtsr
Old Dec 29, 2011, 12:39 PM
tallyho is offline
Find More Posts by tallyho
Epping, Essex
Joined Nov 2002
Don't know if it's been posted but Wemotec are going to release a 80mm Midi fan.
http://www.wemotec.com/jtl-shop/index.php?a=148
Happy New Year
Matthew
tallyho is offline Find More Posts by tallyho
Old Dec 29, 2011, 02:11 PM
Jetnfast is offline
Find More Posts by Jetnfast
Jetnfast's Avatar
United States, CA, Temecula
Joined Feb 2008
Fellas - working on the wing spar installation right now....I just took the fuse our of the packaging, my jaw dropped on the quality of the paint and glasswork! Regardless, I can't believe that only the pinch of the two Allen bolts is all that holds the wing spar into position! Crazy!
Jetnfast is offline Find More Posts by Jetnfast
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
