Dec 27, 2011, 01:29 AM
United States, CA, Livermore
Originally Posted by Snowbird One
I'm sorry, maybe I mis-worded it. I meant to say why use a SECOND BEC. You already have the one on the ESC, why get a second one, and cut one of the wires. Wouldn't a voltage regulator do the same thing? I really don't get it what does the SECOND BEC do that the voltage regulator wouldn't. And, yes, like I say, I'll get an A123 for redundancy, but I am just so curious about it.
I do not agree with the statement that a servo does not add to or prevent flutter. Sloppiness in any part of the linkage system CAN lead to flutter. A servo that has teeth that are not meshing nicely will certainly introduce 'slop' -no matter how little it may be; likewise, also will a shaft not firmly seated in a bushing or bearing. This CAN allow the control surface to begin to oscillate. Hit the right frequency, and you will experience flutter.
So by the predominant choice of the 85MG people are saying that it's better to have the heavier, slower 85MG because it has the ball bearing?? With so little understanding of how the ball bearing is an advantage I don't understand why they're choosing that over the 82MG. Not quite sure I understand the 'robust' statement, either. Robust because the shaft is supported by a ball bearing?
It's interesting to note that the recommended MC35s aren't anywhere near as good as any we are discussing here!
By the way, the www.servodatabase.com website is such a useful reference (as someone stated many hundreds of pages ago!). You can make your own comparison chart with just a click or two!
85HB? Is that another one? I couldn't find it in the servodatabase.com website.
Sorry i couldn't be more helpfull. By robust i just meant "bigger, stronger, more powerful, etc." Now that you mention it I guess an old worn out sloppy servo with bad bearings could allow a surface to flutter. My bad on the "HB" designation for the 85's. The non MG version of the servo has nylon gears, not Karbonite, which Hitec calls "HB". Hitec doesn't use any designation for nylon.
