Old Sep 20, 2011, 07:16 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
Originally Posted by skydve76 View Post
6 pole motor.
Yes I run wot alot becauze its slow.
btw, altitude would affect both habus.
whats the kv?
keep in mind that speed is relative to size of the aircraft. the 32 is bigger and thus will seem like its going slower but it isn't and conversly the smaller Habu going 100 will seem the same as the bigger 32 doing 115. take the two videos I posted the PZ Habu looks faster in the video than the 32 video but its 20mph slower bottom line is you need to doppler it, radar it, or gps it before you really know whats going on
jcdfrd is offline Find More Posts by jcdfrd
Old Sep 20, 2011, 07:17 PM
skydve76 is offline
Find More Posts by skydve76
More jets than a carburetor
skydve76's Avatar
United States, NE, Omaha
Joined Sep 2008
2150
skydve76 is offline Find More Posts by skydve76
Old Sep 20, 2011, 07:21 PM
bri6672 is offline
Find More Posts by bri6672
bri6672's Avatar
San Diego
Joined Jul 2009
Originally Posted by jcdfrd View Post
whats the kv?
I agree but something is not right! It is such a noticable difference in mine that something has to be off! I am think its at least 20-30mph faster, I also have the stock foam habu system in an HET F-20 and it is a bit faster than the foam habu but still no comparison to the 32!
bri6672 is offline Find More Posts by bri6672
Old Sep 20, 2011, 07:29 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
well after looking at the data I think its altitude, no retracts (drag) and perception
by the way Bob rpm is 43k peak dropping to 39k and peak amps are 80 dropping to 70 and voltage is holding above 3.7 throughout the flight
Old Sep 20, 2011, 07:33 PM
skydve76 is offline
skydve76's Avatar
Joined Sep 2008
by the way Bob rpm is 43k peak dropping to 39k and peak amps are 80 dropping to 65 and voltage is holding above 3.7 throughout the flight
Is this good or bad?
Old Sep 20, 2011, 07:35 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
seems right in line too me
Old Sep 20, 2011, 07:39 PM
skydve76 is offline
skydve76's Avatar
Joined Sep 2008
Ok well atleast that is sorted out. When I flew with the foamy he kept cutting inside the circuit but on the straight legs I wasnt pullling away much.
Perception perhaps but I have the e-flite pogo and that blows this this thing away.
I think I will give it another try, let someone fly my foamie and try to keep the curcuits clean.
Old Sep 20, 2011, 07:41 PM
rvincent is online now
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
A Pogo? Man something is whack for sure
rvincent is online now Find More Posts by rvincent
Old Sep 20, 2011, 07:44 PM
tulz43 is offline
Find More Posts by tulz43
tulz43's Avatar
Los Angeles, CA
Joined Sep 2007
It would be easier and more accurate to get a video of each and have someone on here doppler it. The planes are a different size... it would be hard to keep them in the same circuit. You might think you are but the bigger habu 32 could be going out further.
tulz43 is offline Find More Posts by tulz43
skydve76 is offline
skydve76's Avatar
Joined Sep 2008
My pogo is about 110 mph and I can tell in flight its way faster.
Old Sep 20, 2011, 07:49 PM
smaze17 is offline
Find More Posts by smaze17
smaze17's Avatar
Joined Dec 2009
Originally Posted by tulz43 View Post
Nope. I just have a little one from Garmin. Records max speed among other things. Come to the basin and we can see what the mega does!
Ok I'm coming out Friday. Will you be there?
S
smaze17 is offline Find More Posts by smaze17
Old Sep 20, 2011, 07:55 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
you mean it seems faster
do you have a smart phone? if you do then download RC Speedo its a Doppler app that works very good, other wise take some video and make passes at wot of at least 4sec entry straight and level and 4sec exit, hold the throttle thru the entire pass and I can doppler it for you or anyone else for that matter
I would bet your pogo and PZ habu are slower than you think and your Habu32 is faster than you think, just a friendly bet of course this happens all the time small planes look faster than they actually are and bigger planes look slower than they actually are
Old Sep 20, 2011, 08:19 PM
bdelapen is offline
Find More Posts by bdelapen
Sponsored by Team de la Peņa
bdelapen's Avatar
United States, FL, Pembroke Pines
Joined Aug 2008
Wow, 4s each way, that's a pretty ambitious pass, at 120MPH (176fps) you are talking about 700ft towards you and 700ft away from you. Certainly doable but the plane will be small on final turn and on pull out. A couple of seconds each way is probably enough for a good doppler pass.
- Birger
bdelapen is offline Find More Posts by bdelapen
Old Sep 20, 2011, 08:24 PM
rvincent's Avatar
Joined Jul 2004
Yes 1 1/2 seconds will work as long as the throttle is not touched but 2 seconds is ideal.
Old Sep 20, 2011, 08:26 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
yes but if you tell them 4 sec you'll get two
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
