Old Aug 02, 2011, 07:21 PM
stmbike is offline
Find More Posts by stmbike
United States, CA, Palm Desert
Joined Jan 2009
Life battery for futaba fasst rx
Just got and e-mail from Futaba stating they do not recommend lithium batteries for their receivers. And if you do so at your own risk, a regulator is necessary to reduce it to 6.0 volts. So how many of you Futaba guys are using these new Life batteries with no regulators and having good results. I went for this install after following this thread. Sounded good. Hope it is. Stephan
stmbike is offline Find More Posts by stmbike
Old Aug 02, 2011, 07:29 PM
Boothcj is offline
Find More Posts by Boothcj
Joined Jun 2011
Originally Posted by efflux RC View Post
The thrust tube sits between the fan housing and the former on far side. I don't know if it actually gets clamped (sandwiched ) between them, when you screw the fan down, but I've taped it just at the exposed half and not had a problem with it moving.
I have about a 1/8" clearance around the fan and the rear former. The easiest way I see is to pull the tube tight and tape it on the exposed part. Just wondering if it would be better to some how seal it all the way around? There has to be some pressure in there at full throttle? Do you think it would leak around the untaped side? Thanks for your response
Boothcj is offline Find More Posts by Boothcj
Old Aug 02, 2011, 08:30 PM
danamania is offline
Find More Posts by danamania
Advocating for RC Aviation
USA, NJ, Phillipsburg
Joined Jul 2010
OK, dumb question from the noob, but how important really is the fit between the intakes and the fan housing? I get wanting a tight fit for feeling really right about one's EDF model, but is any performance lost if I just go with the duct tape in the instructions?
Just askin' Dana
danamania is offline Find More Posts by danamania
Old Aug 02, 2011, 08:47 PM
ZACATTACK is offline
Find More Posts by ZACATTACK
ZACATTACK's Avatar
Canada, ON, Hamilton
Joined May 2011
Just askin' Dana
No..I use Duct Tape at the intake side and 3M Blenderm at the exhaust tube..Perfect...a friend of mine used Tuck Tape and worked out good aswell.You do want a good seal..
ZACATTACK is offline Find More Posts by ZACATTACK
Old Aug 02, 2011, 09:11 PM
skydve76 is offline
Find More Posts by skydve76
More jets than a carburetor
skydve76's Avatar
United States, NE, Omaha
Joined Sep 2008
Got two new flights on on my new setup:
Ice 100 heavy (instead of 75 light)
Hyperion life pack (instead of BEC)
30C lipo (instead of 20)
It flies ok, not a huge speed increase but some. My twin 90mm mig flies circles around this.
Current pull did not change, still pulling 82 amps. However, the lipo held 1V higher so I could tell there was a higher RPM. But as expected, a stronger lipo will not reduce amp pull. The lipo V just help up as expected.
Temp hit 177F. Do you guys think this is too hot? The temp decrease is not due to the stronger lipo, it is due to the heatsink.
skydve76 is offline Find More Posts by skydve76
Old Aug 02, 2011, 09:40 PM
bri6672 is offline
Find More Posts by bri6672
bri6672's Avatar
San Diego
Joined Jul 2009
Yeah thats weird! Whats interesting is the new DSM "X" recievers coming out are rated to 9.6volts which is impressive, they are obviously thinking ahead about new power sources for rx...
bri6672 is offline Find More Posts by bri6672
Old Aug 02, 2011, 09:58 PM
ZACATTACK's Avatar
Joined May 2011
My R921 is rated at 3.5V-9.6V. input...that 9.6V rating is nothing new...the only new thing is the DSMX..I just had my TX serviced and upgraded to DSMX($75)...Cant Tell The Difference!!!
Futaba on the other hand is coming out with lots of new ground breaking technology....very impressive.If I were starting fresh..the Futaba path,I would be waliking!!
Old Aug 02, 2011, 10:05 PM
ZACATTACK's Avatar
Joined May 2011
You need a TJ 80 SE with a 9S set-up...Then you'll see a noticable speed jump in your system..Start getting some High Power systems SkyDVE..you can handle it..
Old Aug 02, 2011, 10:33 PM
efflux RC is online now
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
I'll have to see if mine has that gap.
It would be best if you can get tape around the hole fan.
efflux RC is online now Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Aug 02, 2011, 10:34 PM
Boothcj is offline
Joined Jun 2011
Yes, just remember your only duct taping a 3" section on top. It would be a chore to get all the way around.
skydve76 is offline
skydve76's Avatar
Joined Sep 2008
would 8s 6600 30c be too heavy?
Old Aug 02, 2011, 11:10 PM
ZACATTACK's Avatar
Joined May 2011
Thats a big battery..I dont know much it weighs? That is the biggest 8S
battery someone has introduced in this Forum.. Suprised it will fit in the Habu!
Old Aug 02, 2011, 11:15 PM
skydve76 is offline
skydve76's Avatar
Joined Sep 2008
I have a stock of 4s 3300s. I'm sorry, it would not be an 8 6600. It would be an 8s 3300. Is an 8s 3300 too small?
Old Aug 02, 2011, 11:21 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
I think it would fit no problem two 4s 3300 nano's 35c no problem
they would need to be 35c or greater tho
jcdfrd is offline Find More Posts by jcdfrd
Old Aug 03, 2011, 12:26 AM
tulz43 is offline
Find More Posts by tulz43
tulz43's Avatar
Los Angeles, CA
Joined Sep 2007
Giving more volts to the same more is always going to increase amps. High c rating, high voltage held under load, means more amps when everyhting else stays the same. The reason Efflux can do an 8s motor is because it's "geared" toward higher voltage setups.
177 is pretty hot. Where do you have it mounted? I actually put my ice 100 in the spot e-flite recommends and it stays much cooler.
tulz43 is offline Find More Posts by tulz43
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
