Espritmodel.com Heli Air
Old Jun 16, 2011, 02:51 PM
efflux RC's Avatar
Valencia, CA. USA
Joined Aug 2009
Originally Posted by tulz43 View Post
I'm at the basin every weekend and I'm the only 32 flying. Could sure use some company
Saturday is Karens Biirthday, Sunday is fathers day. So this weekend is ify. I might sneak up to Canyon Crosswinds for a short while.
I better get out soon cause one of the rarcels of motors from MEGA has cleared customs in New York, and will be here in a few days. A second larger parcel with motors is in transit from Cz.
Many of these will need shaft mods, and/or complete fan balance/assy.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Old Jun 16, 2011, 03:06 PM
efflux RC's Avatar
Valencia, CA. USA
Joined Aug 2009
Originally Posted by carguy1994ca View Post
Hope I won't sound too dumb, but how do you balance it ? I have a dubro prop balancer.
Either the Dubro, or the magentic type will work fine.
Add some "earthquake hold" putty, to the "light" side. (outside the hub)
Keep adding putty until the rotor stays wherever you position it radially.
Then move the putty to the inside and lightly cover it with 5 min epoxy.
Site Sponsor
Old Jun 16, 2011, 03:11 PM
efflux RC's Avatar
Valencia, CA. USA
Joined Aug 2009
Originally Posted by like2fly! View Post
Hi,
You guys who are using a separate receiver pack, how many mAh are you using per flight approx?
Alex
I've been using a 2s, 850mAh lipo that plugs into a Castle BEC, then into the batt port of the rx, in a number of 70-90mm EDFs. With up to 8 servos (2 of them digital).
I've never looked at what I put back into them, but generlly make 2, (4-5 min) flights, before recharging.
Site Sponsor
Old Jun 16, 2011, 03:38 PM
balistc1000's Avatar
Chandler, AZ
Joined Nov 2008
I hope one of mine is in there!
balistc1000 is offline Find More Posts by balistc1000
Old Jun 16, 2011, 03:46 PM
Tumbler's Avatar
New Jersey
Joined Feb 2003
Hey,
Nice little trick. So what keeps the door open and away from the strut in the down position?
Brian
Here's some shots of the gear doors.
The nose wheel bungy is tied to the gear wire, between the spring and the retract. The other end is epoxied into a hole on the gear door.
I used lengths of drilled tie wraps as "straps" for the mains, instead of the wood blocks supplied with the kit.
Tumbler is offline Find More Posts by Tumbler
Old Jun 16, 2011, 04:20 PM
I tell her RC is cheap !
carguy1994ca's Avatar
Quebec, Canada
Joined Sep 2006
Thanks a lot !
carguy1994ca is offline Find More Posts by carguy1994ca
Latest blog entry: Mystery summit FPV adventures
Old Jun 16, 2011, 04:23 PM
efflux RC's Avatar
Valencia, CA. USA
Joined Aug 2009
Originally Posted by Tumbler View Post
Hey,
Brian
Just the contrary. The contact of the door to fuse at the hinge point holds the door against the wire strut when open, and the door slides on the strut as it opens and closes.
It just worked out that it works very smoothly (every time)
On other jets I've had to add a "glide bump" to the inside of the door to prevent hang ups....but not this one.
Using Tams's struts may need the "glide". I'll put them on the next Habu.
Site Sponsor
Old Jun 16, 2011, 04:39 PM
Quebec, Canada
Joined Sep 2006
Looking back at the pic previously posted, the little cord gets pulled by the strut when the gear goes up and that closes the door ? So when up, the cord doesn't pull on the door, it appears loose ?
Old Jun 16, 2011, 05:03 PM
hypstar's Avatar
Sweden
Joined Sep 2008
Originally Posted by 50mph View Post
Good question. Also would those of you running a separate rcvr pack mind telling us the size.
I`m going to use 2S 800mAh (45g)into a Hobbywing 8/15A UBEC.
hypstar is offline Find More Posts by hypstar
Old Jun 16, 2011, 05:50 PM
marell01's Avatar
Sweden
Joined May 2006
Originally Posted by marell01 View Post
Hi all,
Iīve started my built last weekend and found some problems. Some are old some new to this thread...
Altough I sanded the base for the mainwings on the fuse they still rock some millimeters back and forth. Noticed that there are some heavy flex in the fuse where the trailing edge meets the fuse. Has anyone reinforced that area?
Same thing with the stab. My left one didnīt sit tight to the fuse. Had to sand away some color and spackle from the fuse. At stabs leading edge the fuse is to weak with flex as a result.
Is this anything to worry about. My easy fix will be to tape the wings to the fuse.
Sincerely
Marcus
ANYONE ??? Please...
marell01 is online now Find More Posts by marell01
Old Jun 16, 2011, 07:30 PM
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
mine were that way too the stab more so than the main wing.
I just used some rtv silicone in between the wings and stab and fuse then bolted them on let it dry. They are rock solid now
Also I just maiden mine tonight and WOW am i impressed she flys great.very fast for a stock setup also.
However I did not extend the canopy bolt as suggested and it flew of just 60sec into the flight
so here is my fix and a pic of my habu after i removed the stickers and tinted the canopy
hotdog1 is offline Find More Posts by hotdog1
Old Jun 16, 2011, 07:31 PM
Joined May 2011
Some guys are using a rubber washer on the rear alignment Pin,Some guys are using Silicone and clear tape..Some guys are glueing the wings directly to the fusealage...You have to read some of the prior threads in here..spend 30-40 minutes of reading in here and %90 of your build problems will be aswered..some of the best building techniques and construction have been discussed in here..excellent stuff in here I must say!!Read and spend some time...you'll be happy you did!!
ZACATTACK is offline Find More Posts by ZACATTACK
Old Jun 16, 2011, 07:33 PM
Quebec, Canada
Joined Sep 2006
Nice shop
Old Jun 16, 2011, 07:58 PM
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Just let you guys know.
I ran up the E-Flite fan for the customer. It was horrible sound and vibration.
So put the E-Flite rotor on my dynamic balance machine to find out how far off it is out of balance.
Wow....is was so out of balance and hope you guys take time to balancing it well if want to run high power.
I try to balance one and let see what the different it would make.
Tamjets is offline Find More Posts by Tamjets
Old Jun 16, 2011, 08:11 PM
More jets than a carburetor
skydve76's Avatar
Omaha, Ne
Joined Sep 2008
210 pages akes longer than 30-40 minutes. I hate it when people say that.
skydve76 is offline Find More Posts by skydve76
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
