Stock Fan can handle 8S.
Sounds like you didn't balance the rotor. Mine was off, Balanced it sounds good... |
Latest blog entry: Durafly Vampire 70mm
Latest blog entry: Mystery summit FPV adventures
i am using a 750mah nimh pack for my rx, also using the stock esc with the bec still enabled, i just ran the esc(throttle)lead to the throttle channel and ran the rx battery lead into a switch with built in led meter then to the battery channel on the spektrum rx. basically running them in parallel so if the bec failed or voltage dropped below min on the bec the battery acts as a backup and barely adds any weight. when i get ready to fly i plug in the lipo, wait for the tones, turn on the bec switch on the stock esc, making sure it still works and powers all the servos, then turn on the switch from the rx pack.
Joined Nov 2005
My second Habu maiden was a great success. The wing twist did not shown any signs of performance hit to speed, but it seemed to handle very solid in high speed turns.
BTW full flaps on grass makes for a shorter TO, and linking the rates to the flap switch via flight modes really reduced pilot work load. It is fly and forget (except for dropping flaps and raising gear, but that's the fun stuff.) |
Denmark, Nordjylland, Gistrup
Joined Aug 2005
Where did you CG and how much "Twist"
Livonia, Mi
Joined May 2010
e-flite sabre vs habu 32
I fly both..(F86 uses sapac retracts) and I have about 30 flights on each. First, the F86 is a good flying plane with ok speed on stock fan/motor, but lacks the power and preciseness of the habu. I look forward to flying the habu more due to the landing characteristics. The habu lands at about half of the speed and is not prone to wing tip grinding or flipping over like the F86.
However, I love the looks of the F86! Also, I use a 900mah lip for the Rx and only use 50-100mah per flight. |
| Thread Tools | |
| Discussion Fiberglass Habu Airframe | Calvin_220 | Electric Ducted Fan Jet Talk | 92 | Nov 10, 2012 02:53 AM |
| Sold New in box Habu EDF PNP | flyboy1945 | Aircraft - Electric - Jets (FS/W) | 2 | Aug 01, 2010 08:24 PM |
| Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread | SalamSyed | Foamy EDFs | 0 | Mar 20, 2010 11:15 PM |
| New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer | nitroplanes | Nitro Planes | 0 | Jan 24, 2009 09:58 AM |
| Discussion Baja SS Speculation and hopup thread. | DaveESPI | Large Scale Cars | 3 | Feb 03, 2008 07:39 PM |
