Old Jun 15, 2011, 07:30 AM
flemsus is online now
Find More Posts by flemsus
Denmark, Nordjylland, Gistrup
Joined Aug 2005
Originally Posted by Tamjets View Post
Here is my old dog trick how to do nose gear door pulling by the piano wire.
This is old school set up. If anyone of you remember the old days building balsa plan kit.
What a nice "trick" What do you fix the piano to opposit the hinges?
flemsus is online now Find More Posts by flemsus
Old Jun 15, 2011, 07:36 AM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Habu Nose door.
Hi Flemming.
Have you seen the hair bungy to clsoe the door?
I'm sure it will work with Tams struts too.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Old Jun 15, 2011, 08:19 AM
50mph is offline
Find More Posts by 50mph
50mph's Avatar
Tacoma, Washington
Joined Jul 2007
Originally Posted by efflux RC View Post
Hi Flemming.
What a great idea. I was thinking of this but didnt know how to go about making it work. I now see a way..
50mph is offline Find More Posts by 50mph
Old Jun 15, 2011, 11:47 AM
bri6672 is offline
Find More Posts by bri6672
bri6672's Avatar
San Diego
Joined Jul 2009
Thank you to whoever changed the name of the thread! I think we all agree we are definitly past speculation!
bri6672 is offline Find More Posts by bri6672
Old Jun 15, 2011, 12:07 PM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Well heck Tam, Ya got us beat. We only got 163 max in a 20mph crosswind, level, on video and RADAR.
Got the shipment. Thanks.
I think your struts with the E-Flite 15-25's are the way to go.
LOL....
Maybe you thinks want to be in the race. But I never was. Just doing my job fine tuning get the best result.
Yes is not $75 upgrade....
Tamjets is offline Find More Posts by Tamjets
Old Jun 15, 2011, 12:10 PM
ZACATTACK is offline
Find More Posts by ZACATTACK
ZACATTACK's Avatar
Canada, ON, Hamilton
Joined May 2011
Foam
Foam padding?? Is that for shock absobtion?? First I heard of that one..does it make a difference on landings...
I too used the stock retract screws with out issue but I did as the manual said and used a 5/64th drill bit. and I also used the foam square from the packaging worked pretty good but the wing is definitly very soft I made marks in mine just removing the stickers.(Quote)
ZACATTACK is offline Find More Posts by ZACATTACK
Old Jun 15, 2011, 12:16 PM
ZACATTACK's Avatar
Joined May 2011
QUOTE=Tamjets;18507719]LOL....
Yes is not $75 upgrade....[/QUOTE]
Tam, there is going to be a custom motor made by Steve especially for the TJ80SE?? 9S or 10S . Maybe 2 weeks for completion Tam??
Old Jun 15, 2011, 12:22 PM
rcjets12 is offline
Find More Posts by rcjets12
Joined Aug 2006
Hi Flemming.
Could we see more pictures of this setup if you don't mind
rcjets12 is offline Find More Posts by rcjets12
Old Jun 15, 2011, 12:50 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Tam, there is going to be a custom motor made by Steve especially for the TJ80SE?? 9S or 10S . Maybe 2 weeks for completion Tam??[/QUOTE]
The motor not be a week or two.
Test motor we goes through good trial test before production was made.
Yes the design of the motor to be run from 8s-10s.
Depend how customers want to use the power.
8s around 2.2kw for light weight set up.
9s around 2.7kw is where we had been doing.
10s is for hot rod for speed freak.
The ICE HV120 custom made heat sink from us to kept the ESC cool and light.
TJ80SE is really special. A lot custom works to kept it light and right KV motor to be works in many different application.
Whom know what the future hold.
80mm size jets might be the ticket and I had the power plant can push to the limit.
Old Jun 15, 2011, 01:03 PM
efflux RC's Avatar
Joined Aug 2009
LOL....
No Tam...it's not a race at all. It's just a bit more power from the stock setup.
A 6 minute flight with 9s, 3200's ? Very nice. What was the amp draw at WOT? How much did you put back in the packs?
Not everything is about speed.
For the guys who want the stock setup, we have the stock motors and fans coming next week. We now have just about everything to need to outfit the Habu...... Including Habus.
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Jun 15, 2011, 01:18 PM
ZACATTACK's Avatar
Joined May 2011
Originally Posted by Friedclutch View Post
quote: Has no one else tried 7S with the stock motor/fan?
I am going to run 8 cells on the stock motor and fan later on in the season. With a heat sink installed. The guy on youtube did it and finally burned up the stock motor after 4 laps of full throttle. (no heat sink) I'm thinking I will get away with full throttle passes. Just don't do laps with it pinned. Haha.
That dont sound like a good plan??? To each his own...but why risk it?
Old Jun 15, 2011, 01:33 PM
efflux RC's Avatar
Joined Aug 2009
Here's some shots of the gear doors.
The nose wheel bungy is tied to the gear wire, between the spring and the retract. The other end is epoxied into a hole on the gear door.
I used lengths of drilled tie wraps as "straps" for the mains, instead of the wood blocks supplied with the kit.
Site Sponsor
Old Jun 15, 2011, 01:42 PM
hotdog1 is offline
Find More Posts by hotdog1
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
oh I like that hair bungee where do you find those ?
hotdog1 is offline Find More Posts by hotdog1
Old Jun 15, 2011, 02:44 PM
efflux RC's Avatar
Joined Aug 2009
In the womens Hair products aisle at department stores like Wal Mart, K-Mart, Target.
They are for tying ponytails, and are very small.
Site Sponsor
Old Jun 15, 2011, 02:52 PM
SCALEFAN is offline
Find More Posts by SCALEFAN
Done it all
United States, CA, Corona
Joined Feb 2006
You Habu guys are sick (I mean this in a bad way)
You Habu guys are sick (I mean this in a good way)
Confused? Yes.
The other day I saw a Habu32 fly. Well, I think it was a Habu, someone said it was a Habu32, could not prove it until it landed and went off the end of the runway (no brakes). It really was a Habu, the problem is that it was very blurry when it was flying.
Is this what RC jets are becoming now a day? Chit, at least having a stamp collection my not be thrilling, but the stamps don't move very fast and licking them could be a turn on. Slow down the Habus, make them nice to look at. Please.
Two Margaritas for lunch today, can you tell?
SCALEFAN is offline Find More Posts by SCALEFAN
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
