This is the number you had ran the fan without install on mid timing and I had verify with you is correct. After installl spool up the fan full power and sucking FOD. You had done some repair your own and ran the fan again. The watts you had post is way out of spec and there should be send back for inspection if the motor got damage. Hope this data clear the air and stop blame the fan problem.
I just flew my stocker on 7S 3200s.
3S+4SIt was definitely faster with better vertical but I need to fix up a better series connector this one I bought for cheap and the 3 fake deans connectors were getting pretty warm. So I'm losing some power there plus the connectors won't last long. Anyhow, ran it up pre-flight to get some numbers. 2000W @ 77A A nice jump from my stock 1600W 70A Flew several hi-speed passes with under 1/2 throttle passes inbetween. 4 minute timer went off so I landed (hardpack rocky dirt field)and something broke in the nosegear retract and it partially folded under. Took it apart, the part the worm drive moves back and forth had snapped one ear off. The trunnion is fine, removed snapped off piece and reassembled. Retract works normal again but don't know for how long! |
Latest blog entry: Durafly Vampire 70mm
Canada, AB, Spruce Grove
Joined Nov 2006
on another note i maidened my habu today...straight down the grass runway and into the tall grass...the canopy stands out pretty good against the green ![]() i got going good and thought i heard the motor hick-up twice so i aborted, minor rash and straightened out nose gear. did a test taxi same hick-up. when i played with it in the pits it died. all servos/functions work and i didn't see any magic smoke. damn good thing i didn't get it up in the air....woulda had to paint another canopy
Bruce,
I confess broke the nose gear on saturday maiden too. Coming to slow and drop the nose first. The trunion broke. But lucky had plenty of parts in stock after cranking out so many Habu. Yesterday on my third landing. Everything is perfect and smooth. My main gear broke off and tear the wood rail off. I roll my eye and said what that all about. That is nice landing. This might be the result on saturday and I blame on me. But tonight I goes over what cause the gear broke off and I inspect the glue join on the wing rail. Barely any glue was use and pull the rail out so easy. I suggest every one check gear mounting rail and add medium CA around the join. If you had loose rail and can easy damage the main gear. I'm more mad that had perfect flying plane with new TJ80SE hauling mail. Now had to repair and redo the maiden again. |
It's happened to me. If you use Deans. Be sure EVERYTHING is genuine Deans. |
rod22, sounds like one motor wire came loose, if you kept applying throttle with it hick upping like that, chances are the ESC burned up. Don't ask me how I know!
Tam, I wish the trunnion broke on mine! Then I would've had an excuse to upgrade to your struts! btw, When my nose gear folded, the nose hit the ground and stopped the plane quickly, Now my perfect jets got a couple small stress cracks on the fuse and the canopy latch unglued itself.
Joined May 2011
Theres hardly any tension left to hold the connection together. I wonder what kind of crappy metal they use on those things! |
It melt and the connector came loose. Why the hell you guys using copy Dean? I caught my friends using it and I give them hell. Pack of real Dean only $5 and crappy copy dean many few buck. But the risk taking is huge. I had maiden a plane with copy dean. After take off and go around for 30sec. No power. After dead stick landing. The copy dean kept off completely. Lucky no short the wire. I give Al, John and Dave hell every time see them with copy Dean. I rather throw them a bags of real Dean and charge them double to save them from crashing a plane for stupid copy Dean. |
Santa Rosa, CA
Joined Nov 2008
Tamjets Struts
If you have Tams struts and your landings are like mine, then you need to purchase some spare springs for the struts. They work as designed so if you come in hard, the struts will do the job, but the springs may be stretched.
As there is little room in the wheel wells, if the springs stretch, the wheels can be mis-aligned and therefore not retract correctly. So, get a few extra sets of springs for the struts from Tam, I am. |
| Thread Tools | |
| Discussion Fiberglass Habu Airframe | Calvin_220 | Electric Ducted Fan Jet Talk | 92 | Nov 10, 2012 02:53 AM |
| Sold New in box Habu EDF PNP | flyboy1945 | Aircraft - Electric - Jets (FS/W) | 2 | Aug 01, 2010 08:24 PM |
| Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread | SalamSyed | Foamy EDFs | 0 | Mar 20, 2010 11:15 PM |
| New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer | nitroplanes | Nitro Planes | 0 | Jan 24, 2009 09:58 AM |
| Discussion Baja SS Speculation and hopup thread. | DaveESPI | Large Scale Cars | 3 | Feb 03, 2008 07:39 PM |
