Old Jun 13, 2011, 04:51 PM
ZACATTACK is offline
Find More Posts by ZACATTACK
ZACATTACK's Avatar
Canada, ON, Hamilton
Joined May 2011
Originally Posted by super kupfer View Post
With the aircraft weight being over 7lbs (depends on the setup) and the retract only able to handle up to 7lbs, Does Tam's upgrade struts/trunion help with that? does it make a diffrence?
They do look a bit heavy duty compare to the wire struts.
I'm told one bad landing with those wire struts and plastic trunions and your repairing the landing gear. With Tam's set-ups,(1409-1509-2Y-8S batteries)your increasing the weight of the Habu..that's why he developed the upgrades for the landing gear.I'm not in the air yet,and have'nt even tried the stock landing gear out,but,from all the great feedback on the Tam-Struts I have read in here,I purchased the upgrade,no questions asked.. Some in here even deem this upgrade a necessaty!!
ZACATTACK is offline Find More Posts by ZACATTACK
Old Jun 13, 2011, 05:06 PM
bdelapen is online now
Find More Posts by bdelapen
Sponsored by Team de la Peņa
bdelapen's Avatar
United States, FL, Pembroke Pines
Joined Aug 2008
Originally Posted by bdelapen View Post
I hope you realize that setting a throttle curve on your radio to curb the amount of amps a watt meter is seeing is only good for the motor (and of course, the watt meter or data logger or whatever). Running an ESC at 80% throttle is probably the worst thing you can do to it as far as generating heat is concerned. If your ESC is seeing 155amps at full throttle it is also seeing 155A at 80% throttle except only part of the time. On top of that it is in PWM and seeing many many more transistor switches per given second, each one of them generating additional heat.
I wouldn't be surprised if your "lock out" was induced by either some kind of thermal overload protection or even by a burnt component in the ESC.
For your given solution to have worked you would have needed an ESC that could take at least 160A continuous, preferably more.
The moral in most cases (though not necessarily here... yet) is that you can't use throttle curves to curb current consumption, that only helps the motor, not the ESC.
- Birger
BTW, some more information on this, you don't have to take it from me.
Look at the last FAQ at the bottom of the page on this CC web pae:
http://www.castlecreations.com/suppo...eral.html#gen6
- Birger
bdelapen is online now Find More Posts by bdelapen
Old Jun 13, 2011, 05:30 PM
tulz43 is offline
Find More Posts by tulz43
tulz43's Avatar
Los Angeles, CA
Joined Sep 2007
I would think the land would have to be REALLY bad then. I have dozens on my stock setup and they are holding up just fine. Sometimes I have to bend them just slightly but that takes a few seconds. I'm sure flying off of grass is a different story though...
tulz43 is offline Find More Posts by tulz43
Old Jun 13, 2011, 05:40 PM
super kupfer is offline
Find More Posts by super kupfer
Anything that gives me a High
super kupfer's Avatar
Canada, BC, Richmond
Joined Jan 2010
Thanks a bunch, I didn't make up my mind yet on the motor/fan setup I'm going to use (So far I'm thinking about the DS-44 or Tams sweet ass TJ80 or Putting a Mega in the stock fan, One things for sure, I am going 8s).
I know I'm going to be close to 8lbs and I'm concern whether the eflite retracts can handle the weight + I'm going to fly mostly from grass.
But your reply pretty much cleared that part, Not so used to see the spring on the outside but if it works, who am I to say anything (Will have to get used to it)
super kupfer is offline Find More Posts by super kupfer
Old Jun 13, 2011, 05:45 PM
Joined Jan 2010
Originally Posted by gambok View Post
We have a troll
Sounds like somebody's Viagra pill didn't work this morning.
Old Jun 13, 2011, 05:54 PM
gambok is online now
Find More Posts by gambok
FlyRCJets
gambok's Avatar
United States, CA, Roseville
Joined Mar 2007
Sounds like somebody was born stupid.
gambok is online now Find More Posts by gambok
Old Jun 13, 2011, 05:57 PM
FlyRCJets
gambok's Avatar
Joined Mar 2007
Originally Posted by Tamjets View Post
I got 3 flight with TJ80SE yesterday.
2.9kw at 90A on 9s 3600mAh pack.
It was little faster than standard TJ80 on the same watts. I like it.
Now wait for the right KV motor to do on 10s 3.5kw.
Tam, if you have a 6volt reg in stock, I'll stop by. thanks KG
Old Jun 13, 2011, 06:06 PM
ZACATTACK's Avatar
Joined May 2011
Stock Retract Verification of Weakness
Originally Posted by Da ROOK View Post
Guys,
my nose gear retracts gave up after about 10 landings, crack in the housing and the main just gave up the other day after app 15 flights (Crack in the housing, its plastic). I have the 8cell setup with tams fan and prolinks upgrade (its a rocket) fan screams. my jet weighs close to 8 lbs. So for those of us on 8 cell, we need stronger retracts. I talked to mr. walton at spring air he has 600 series set with flat mount nose gear that would be drop in with wires. but with tams prolinks, it doesnt completely close. I have asked him to look at trunion block and see if there is anyway I can modify to make it work and the retract may need to be installed lower in the wing mounts. Anyway, WE NEED STRONG AIR RETRACTS for habu 32 (or possibly better trained pilots...lool). TAM WINK WINK, otherwise I ll start my own retract business...lool
any other suggestions.
jason
I think I ordered the Tam Struts after I read this one!! There's a few more threads Guys are speaking of disappointment in concern to stock retracts,..
Old Jun 13, 2011, 06:08 PM
Joined Jan 2010
I might sound stupid to you or some, but that is because I'm new to EDF and electric flying.
At least I'm not ignorant and rude to others, I don't know what kind of a bug hit you today.
You are on a world web and with comments like the one you posted, you make yourself and other americans look bad.
Not professional at all.
Peace
Old Jun 13, 2011, 06:34 PM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Originally Posted by tulz43 View Post
Tam - what kind of flight times on the 9s setup?
I flew hard for 4 miniutes and pretty much empty the 3600mAh when I taxi back in. It only show 10% left on meter.
I fly normal for 4 minutes and still had 36% left.
I fly gentle with only few high speed pass for 4 minute and still had 46% left.
So it all depend on your speed you want to goes.
Tamjets is offline Find More Posts by Tamjets
Old Jun 13, 2011, 06:38 PM View Post
gambok
A moderator felt this post violated the following rule: Trolling (Provocation). It is temporarily hidden while gambok edits it. Show it to me anyway.
Old Jun 13, 2011, 06:41 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Yes stock plastic retract you got to be landing gentle with it.
If you stalling the plane few feets off the ground.
Two things can happen. You eigther broke the wing mouting rail or bust the gear frame.
My mini air retract can retrofit in the Habu 32 and it very tough gear.
But now you talking about plumping air lines, air tanks, retract valve and know how to trace for leak if there any.
It strong..but there is otherside is little more works.
Even I don't use it because want it simple E-Flite retract. There is days I can do 40 landing not a single problem. But I do have bad landing bust the gear once in a while if don't fly often. Just like this weeken. I had flow for months and get little rusty on landing.
No one is perfect....
BTW,
My computer is online and now time to works.
Old Jun 13, 2011, 06:43 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Originally Posted by rvincent View Post
NICE!!! Is this the TJ-100 rotor cut down?
You got it....what else out there can running so effecient like TJ100 rotor.
Old Jun 13, 2011, 07:08 PM
hole digger is offline
Find More Posts by hole digger
hole digger
hole digger's Avatar
USA, CA, Los Angeles
Joined Aug 2002
Tam,
If yorr works computer is working I could really use a picture of the K&A Mig nose gear door.
If scratching my head right now.
Pete
hole digger is offline Find More Posts by hole digger
Old Jun 13, 2011, 07:11 PM
carguy1994ca is offline
Find More Posts by carguy1994ca
I tell her RC is cheap !
carguy1994ca's Avatar
Quebec, Canada
Joined Sep 2006
Rounding off main doors
Someone mentionned rounding the bottom of the main landing gear doors so they don't catch grass or the runway on landing. What is the best way to do that without chipping the paint ?
carguy1994ca is offline Find More Posts by carguy1994ca
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
