Old Jun 13, 2011, 03:38 AM
Jetnfast is offline
Find More Posts by Jetnfast
Jetnfast's Avatar
United States, CA, Temecula
Joined Feb 2008
Originally Posted by Sunbather View Post
All is good. 2 Flights today. It is trimmed perfect thanks to Tam.
It must be nice living close to Tam!
Jetnfast is offline Find More Posts by Jetnfast
Old Jun 13, 2011, 07:03 AM
tclaridge is online now
Find More Posts by tclaridge
United States, VA, Clifton
Joined Nov 2005
dbgood, sorry for your crash. Did you have it on high rates per the manual?
Mine did the same thing in a turn. Nose dropped and straight into the ground. I was doing at least 90 mph at 1/2 throttle and a graceful turn. My guess is the dreaded accelerated stall.
My second "first flight" will be this Thursday, but I will be flying with wing twist and flight modes set to the flap setting: high rates on full flaps, mid rates on half flaps, and low rates with no flaps.
tclaridge is online now Find More Posts by tclaridge
Old Jun 13, 2011, 08:00 AM
like2fly! is offline
Find More Posts by like2fly!
who dares wins
like2fly!'s Avatar
London,England
Joined Apr 2005
Hi,
Why would you want high rates on full flaps?
like2fly! is offline Find More Posts by like2fly!
Old Jun 13, 2011, 08:16 AM
ZACATTACK is offline
Find More Posts by ZACATTACK
ZACATTACK's Avatar
Canada, ON, Hamilton
Joined May 2011
I dont undrstand what your trying to do??
ZACATTACK is offline Find More Posts by ZACATTACK
Old Jun 13, 2011, 08:55 AM
bdelapen is offline
Find More Posts by bdelapen
Sponsored by Team de la Peņa
bdelapen's Avatar
United States, FL, Pembroke Pines
Joined Aug 2008
Originally Posted by dbgood View Post
Hi,
Did a power test on the Tj-80 1509 2y..I noticed on the ground while holding on the nose of the plane,the speed controller was pulsating and the motor cutting out.So i plugged in the ICE 100,and it had motor timing of normal,but the reason it was cutting out on datalogging it said 155 amps max,and 4891 watts,good thing i checked befor flying...so i had to put a throttle curve set to only 81 to get it to 97 amps,and 3102 watts...
Cant understand why 155amps on a NEU 1509 2y,set at mid timing..
I hope you realize that setting a throttle curve on your radio to curb the amount of amps a watt meter is seeing is only good for the motor (and of course, the watt meter or data logger or whatever). Running an ESC at 80% throttle is probably the worst thing you can do to it as far as generating heat is concerned. If your ESC is seeing 155amps at full throttle it is also seeing 155A at 80% throttle except only part of the time. On top of that it is in PWM and seeing many many more transistor switches per given second, each one of them generating additional heat.
I wouldn't be surprised if your "lock out" was induced by either some kind of thermal overload protection or even by a burnt component in the ESC.
For your given solution to have worked you would have needed an ESC that could take at least 160A continuous, preferably more.
The moral in most cases (though not necessarily here... yet) is that you can't use throttle curves to curb current consumption, that only helps the motor, not the ESC.
- Birger
bdelapen is offline Find More Posts by bdelapen
Old Jun 13, 2011, 01:36 PM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Hi,
i just used the stock thrust tube on there.
I just dont understand i did a watt test and i didnt touch the timing or nothing and got 155 amps..
Strange,hope its the 1509 2y in there and not some other higher kv neu motor.
And locked up i mean the 3rd turn with plenty enough speed as i was pulling out of the turn,the nose just dropped and as it was coming down, i pulled plenty of up elevator and no response came crashing nose down.
Planes ,jets are very easy to fly for me...I fly a Trex 700 E, 12 cell
We had verify this few page back.
You got 1800 watts testing on mid timing without install.
That is exactly correct. Install will be 2800 watts.
So there is no faulty with the fan or incorrect motor.
I'm very care full putting this unit together and spend up to an hour make sure it running smooth before ship.
Try to explain to me how you re-install the rotor back in after you got FOD and did you tested to make it running smooth.
Hope it not out of balance and cause the damage.
BTW,
If you notice something are not right. Don't fly it.
You should make the phone call for assistance and even send back to me to check it out.
Once you crashing it.
Nothing I can do.
Tamjets is offline Find More Posts by Tamjets
Old Jun 13, 2011, 01:47 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
I got 3 flight with TJ80SE yesterday.
2.9kw at 90A on 9s 3600mAh pack.
It was little faster than standard TJ80 on the same watts. I like it.
Now wait for the right KV motor to do on 10s 3.5kw.
Old Jun 13, 2011, 01:51 PM
rvincent is online now
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
What rpm's Tam? You must be near 50k with 3kw?
rvincent is online now Find More Posts by rvincent
Old Jun 13, 2011, 01:54 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
53k....
Old Jun 13, 2011, 01:59 PM
bri6672 is offline
Find More Posts by bri6672
bri6672's Avatar
San Diego
Joined Jul 2009
[QUOTE=tclaridge;18486222
QUOTE]
Ok whats the story on this???? How are we stalling the airplane in a 90mph gracefull turn?? That does not sound right.. Can you clarify the "accelerated stall"
bri6672 is offline Find More Posts by bri6672
Old Jun 13, 2011, 02:02 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
[QUOTE=bri6672;18489851]
QUOTE
I don't how many Habu I had maiden and never once notice any stall in flight.
I only drop the plane on landing if coming to slow.
Old Jun 13, 2011, 02:19 PM
rvincent's Avatar
Joined Jul 2004
Originally Posted by Tamjets View Post
53k....
NICE!!! Is this the TJ-100 rotor cut down?
Old Jun 13, 2011, 02:25 PM
tulz43 is offline
Find More Posts by tulz43
tulz43's Avatar
Los Angeles, CA
Joined Sep 2007
Tam - what kind of flight times on the 9s setup?
tulz43 is offline Find More Posts by tulz43
Old Jun 13, 2011, 03:33 PM
super kupfer is offline
Find More Posts by super kupfer
Anything that gives me a High
super kupfer's Avatar
Canada, BC, Richmond
Joined Jan 2010
With the aircraft weight being over 7lbs (depends on the setup) and the retract only able to handle up to 7lbs, Does Tam's upgrade struts/trunion help with that? does it make a diffrence?
They do look a bit heavy duty compare to the wire struts.
super kupfer is offline Find More Posts by super kupfer
Old Jun 13, 2011, 03:42 PM
gambok is offline
Find More Posts by gambok
FlyRCJets
gambok's Avatar
United States, CA, Roseville
Joined Mar 2007
We have a troll
gambok is offline Find More Posts by gambok
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
