Old Mar 31, 2011, 06:53 PM
chevronflyer is offline
Find More Posts by chevronflyer
"Takeoffs are optional"
chevronflyer's Avatar
United States, FL, Middleburg
Joined Feb 2007
Originally Posted by jonnyspeed View Post
I have 3 of the same. Now if I just had the plane... Did you enter the 10% off code I hope?
crap, %10 code?
no i didnt know about it
chevronflyer is offline Find More Posts by chevronflyer
Old Mar 31, 2011, 07:32 PM
Friedclutch is offline
Find More Posts by Friedclutch
Got Brushless?
Friedclutch's Avatar
Sacramento
Joined Sep 2007
Hey everybody. I received the HK retracts. As I was expecting they are inadequate for this weight of aircraft. Not to mention I would hate to have a failure and damage this model for that reason. However, the retracts "aren't bad". They have 3mm wire struts included and are functional and light weight. I would not hesitate to use them in a cheaper/lighter airplane knowing the risks. No way I'm putting these in an airplane that I just spent over $1000.00 on.
I will by flying by Habu this saturday or sunday and I will report back on the 5000 mah 6s 45c nano-tech pack.
Friedclutch is offline Find More Posts by Friedclutch
Old Apr 01, 2011, 01:18 AM
tulz43 is offline
Find More Posts by tulz43
tulz43's Avatar
Los Angeles, CA
Joined Sep 2007
Just finished tonight. I'll be doing the maiden tomorrow morning. Took the day off from work
What are you all liking as the cg? I'll be using xps 65cc 6s5000's.
tulz43 is offline Find More Posts by tulz43
Old Apr 01, 2011, 01:25 AM
1bwana1 is offline
Find More Posts by 1bwana1
Gotta have toys!
La Jolla, CA. USA
Joined May 2006
tulz43,
I started at 107mm, which is about the midmoint of the recommended range. It worked well for the maiden. I am about 112mm now, and it feels right to me.
Good luck with the maiden!!!
1bwana1 is offline Find More Posts by 1bwana1
Old Apr 01, 2011, 01:29 AM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
did they get the basin up and going again...???
corsair nut is offline Find More Posts by corsair nut
Old Apr 01, 2011, 04:59 AM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
James Habu
Habu 32 1509 2Y (6 min 50 sec)
Tamjets is offline Find More Posts by Tamjets
Old Apr 01, 2011, 08:37 AM
50mph is offline
Find More Posts by 50mph
50mph's Avatar
Tacoma, Washington
Joined Jul 2007
[QUOTE=Tamjets;17847557]James Habu
[QUOTE]
Everytime I see these fly brings a smile on my face. I am still waiting on weather as some have been doing. Keep the videos posting.
Love this jet
50mph is offline Find More Posts by 50mph
Old Apr 01, 2011, 09:39 AM
Got Brushless?
Sacramento
Joined Sep 2007
...I figured it out... the threaded rod was going to far thru the clevis o.............
I had the same problem with my build. As the clevis slid forward in the slide channel with gear up, the threaded push rod would hit the slide block. I just backed the push rod off like tulz43. My radio is a DX-7se. I tried setting up a mix to cancel nose gear steering with gear up but so far I have not figured out how to do it. Even though I am fairly savy with this radio.
Old Apr 01, 2011, 12:00 PM
lashmett75 is offline
Find More Posts by lashmett75
Not a Drone pilot
lashmett75's Avatar
United States, CA, Sunnyvale
Joined Jul 2008
If it is on it own channel you can. The mix would be
Gear - ( what channel you have it in ) on position 0 ( gear down ) you would have +100 and -100, on position 1 ( gear up ) you would have all 0
That should work
lashmett75 is offline Find More Posts by lashmett75
Old Apr 01, 2011, 01:38 PM
Ron101 is offline
Find More Posts by Ron101
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
That's all you do with my Futaba 12FG
Set a dual rate on the Aux channel for the nose gear. Use the retract switch to control that dual rate.
Set the rate and expo you need with gear down... when the gear switch is up set the throw rate to 0 and 0. It's won't move when the gear is up.
Ron101 is offline Find More Posts by Ron101
Old Apr 01, 2011, 04:13 PM
lyndon915 is offline
Find More Posts by lyndon915
Joined Nov 2004
I know it has been covered somewhat but has anyone found a better servo to run in these other than the JR sport MC35? I am up to modify the servo compartments to some extent but not much. Does anyone have a preference of metal gear over nylon on this particular plane?
Lyndon
lyndon915 is offline Find More Posts by lyndon915
Old Apr 01, 2011, 04:25 PM
Not a Drone pilot
lashmett75's Avatar
Joined Jul 2008
Lyndon
I have HS82mg in mine EXCEPT rudder...HS 5085MG digital version
But I have built other Habu's with HS 85mg in them..all work great.
Old Apr 01, 2011, 06:26 PM
Joined Nov 2004
Just wondering but are you using these servo's for the extra torque or simply for the metal gears? I am wondering which you feel is more important. I know in all of my Giant scale planes I use metal gear servo's but in a jet of this size and speed do you, or others, think that metal gears are required?
Old Apr 01, 2011, 06:31 PM
mpope1 is offline
Find More Posts by mpope1
mpope1's Avatar
gilbert,az
Joined Dec 2005
Nice flying James!
mpope1 is offline Find More Posts by mpope1
Old Apr 01, 2011, 06:38 PM
Joined Nov 2004
I have also considered this servo
http://www.horizonhobby.com/Products...030#quickSpecs
does anyone have any experience with it?
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 02:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Nitro Planes 0 Jan 24, 2009 09:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 07:39 PM
