Old Sep 15, 2010, 05:38 PM
Guz is offline
Guz
Find More Posts by Guz
Guz
Gutless wonder
Guz's Avatar
Tempe, AZ
Joined Dec 2005
Homemade gooseneck and vang?
Anyone have a good link or description on making an inexpensive homemade gooseneck and vang? Mainly for a IOM or 36/600 sized boat.
Currently I am eyeballing Great Planes Turnbuckle/Pushrod 4-1/2"x6-32 and some Dubro Heavy Duty Ball Links 6-32 (2). Throw in a rubber washer at the 5mm hex section, and work the threads to loosen them up for easy adjustment for the vang. But using a single ball link as the gooseneck.
But I'm open for suggestions. The biggest factor is "inexpensive" at this time
Guz is offline Find More Posts by Guz
Old Sep 15, 2010, 06:34 PM
Norman22 is offline
Find More Posts by Norman22
Norman22's Avatar
North Carolina
Joined Jan 2010
Gooseneck and Vang
Hi Guz, Attached photo of homemade goosneck and vang made by Claudio on
his prototype AC100 one meter class boat. Remember the Vang has to be
able to be adjusted for travel in and out when the Boom lifts. Looks like a
good solution. Hope this helps. Regards
Norman22
PS. Will post photo on next post
Norman22 is offline Find More Posts by Norman22
Old Sep 15, 2010, 06:38 PM
Norman22 is offline
Norman22's Avatar
North Carolina
Joined Jan 2010
Gooseneck and Vang Photo
Norman22
Old Sep 15, 2010, 07:05 PM
obses4sail is offline
Find More Posts by obses4sail
obses4sail's Avatar
Visalia, CA
Joined Sep 2010
I just used 2 cotter pins to make my gooseneck
obses4sail is offline Find More Posts by obses4sail
Old Sep 15, 2010, 07:54 PM
jaguar75 is offline
Find More Posts by jaguar75
jaguar75's Avatar
Sacramento
Joined Mar 2007
Here is a very good example.
Regards,
John
http://www.modelyachtfittings.com/
jaguar75 is offline Find More Posts by jaguar75
Old Sep 15, 2010, 11:11 PM
werlec is offline
Find More Posts by werlec
United States, DE, Lewes
Joined Dec 2005
Take a look here - I used this on my Laerke RG65
http://www.rcgroups.com/forums/attac...mentid=3104198
It's home made - 2 Dubro 4-40 ball links, a 4-40 screw, a piece of bent aluminiun
werlec is offline Find More Posts by werlec
Old Sep 16, 2010, 03:28 PM
obses4sail's Avatar
Visalia, CA
Joined Sep 2010
took a pictue of my gooseneck, I will be using a simple line for the vang.
Old Sep 16, 2010, 04:14 PM
hew565 is offline
Find More Posts by hew565
USA, LA, Mandeville
Joined Feb 2005
The DuBro ball links make good attachment points for the gooseneck and vang. I usually epoxy a brass or aluminum tube to the aft side of my mast, with a 1/8" spacer under it. Then wrap the mast and tube with glass or carbon fiber and coat with epoxy. This will keep the tube in place when there is a lot of "up" force on the end of the boom while at 90* to the mast, or that jibe in 20+ knots!
Then take two SS screws and pin the gooseneck to the top of the tube and the vang to the bottom of it, by epoxying the screws into the tube. This is how I have always done my Victoria, and there is no reason the 6/32 size shouldn't work for the larger boats.
hew565 is offline Find More Posts by hew565
Old Sep 16, 2010, 04:15 PM
seefest is online now
Find More Posts by seefest
seefest's Avatar
United States, MA, Bristol
Joined Sep 2009
I use 4-40 ball links and brass couplers for all my racing goosenecks and vangs. I epoxy the couplers into the ends of the carbon boom and carbon vang. Very cheap and reliable.
seefest is online now Find More Posts by seefest
Old Sep 17, 2010, 12:19 AM
tbarjohn is offline
Find More Posts by tbarjohn
tbarjohn's Avatar
aurora, il.
Joined Aug 2009
Here's one of my latest for a Soling 1M, you can adjust the top or bottom in or out, this will change the angle of the boom as it swings in and out.
John R.
tbarjohn is offline Find More Posts by tbarjohn
Discussion Footy sized Gooseneck and simplify your mast graham_mca Sailboats 4 Feb 08, 2008 10:33 AM
Question difference in keels and boom vang? machine Sailboats 1 Sep 05, 2006 05:25 PM
Discussion Boomvang ~ Gooseneck Questions mrfirkin Sailboats 19 Dec 29, 2005 04:23 AM
boom vang question tfbowen Sailboats 4 Jul 28, 2005 02:48 PM
Vang!?! We don't need no stinkin Vang! Do I? lost&confused Sailboats 8 Sep 19, 2004 12:43 PM
