ok, i am selling ALL my heli stuff.. i was a sponsored field rep for Rcer for a while and my dragonus is my baby. it's the best flying heli i've ever flown. but i recently lost my right hand in an accident and now i cant fly.
this heli has the best parts i could get for it. you couldnt really upgrade it anymore if you wanted to!!!
this is set up to be a hard core 3d machine but can be changed in seconds to be a beginner or intermediate heli.
the electronics are-
3 hs65 servos (some have a few metal gears i believe)
1 futaba 9650 servo on the tail
futaba 401 gyro
Scorpion hk2221-6 v2 motor (biggest and badest motor you will find)
45amp rc-tek esc
external rc-tek bec
spectrum ar6000 receiver
also it has the dual silver/black carbon fiber thicker frames, hardened main shaft, doubled rear tail fin, new ms composite CF blades, and slanted silver cf battery mount.
i will also include my transmitter, it's custom made(not by myself and is very reliable). it's a hitec optic 6 with a spectrum module from a dx6 with a tenergy 2500mah tx lipo...if you have ever used hitec radios then you know that they are amazing radios and are the easiest to program, with this one you get all that and the reassurance and reliability of a 2.4ghz system..and it has a scorpion motor neck strap
this heli comes with TONS OF SPARE PARTS!!!!!!! pretty much every main part you will need is included and much much more.
here is a brief list of parts (just listing some main ones, see pics for everything) :
4 flybars
4 tail shafts
3 hardened main shafts (they are almost indestructible so they will really last you)
1 standard main shaft
7 aluminum tail booms
13 feathering shafts
1 long CF tail boom/ XL belt
1 silver cf lower frame set
1 silver cf upper frame set
1 silver horizontal stabilizer
1 hi-quality belt
1 set of light-weight hardened balls
1 set of hard anodized balls
1 tail boom support
1 tail basemount
1 main belt drive gear
1 motor basemount
1 landing skids
well those are the main ones. others inlude about 15 packs of screws, nuts, and rods (pretty much every screw rod or nut you will ever need) and a ton of other misc parts
also, i am including tons of used aluminum head and tail parts. also a bunch of other misc. used parts.
4 lipos are included- 2 flight power evo25's (kinda old but they work well) and two kong powers(both are almost new, but one is slightly crunched but works well)
the charger is a cellpro 4s (best charger ever made imo)
and a gimp lipo charger that i used to charge the tx
it includes a 12v power supply(case was torn up to access insides, works very well)
the tools are:
ball link pliers
align pitch gauge
blade balancer
one-way changing tool
ccpm head tool
ball link sizer
m2 nut wrench
and a custom rod tool thing i made to help change the main grip bearings
ok, that's all im going to list...theres some more stuff that's in the pics.
ok, now to list some of the bad things... one hs65 has a stripped gear, and the landing gear and the mount that are on the heli are broke (replacements included but it's too hard for me to change them now.
) thats all that's wrong with it.
also, i will only sell large items separate, ie- the heli(with or without electronics), the tx, etc... i dont want to sell individual little parts and pieces.
i am asking $425 shipped for everything!!!!
you could probably only buy the heli with the upgrades for that price new.
