Old Sep 14, 2010, 11:11 AM
bastian74 is offline
Find More Posts by bastian74
Eagan, MN
Joined Sep 2010
Calculate speed from sound recordings using Doppler shift
Of course there is a program that does this fairly automatically: WaveOScope.
UltimaSound II (freeware) has a sound spectrograph which looks similar to WaveOScope.
If your curious this is the math:
Speed of object = Speed of Sound * (High Frequency Low Frequency) / (High Frequency + Low Frequency)
346 * (3768 3122) / (3768 + 3122) = 22 m/s = 50mph
Note that for accurate results you need to take a reading of the object moving DIRECTLY towards you, then DIRECTLY away from you. So on a high speed pass there should be a gentle turn (to avoid smashing you)
You should also be flying fairly level, because if you're in a dive (accelerating) you will be increasing the pitch of the motor with faster and faster rpms which will screw up the whole speed calculation which is Dependant on a constant pitch from the source as it moves by. In other words, you need a constant speed and rpm from the inbound and outbound sound samples.
Also, the speed of sound is dependent on the air temperature, though the accuracy doesn't affect the calculations very much.
bastian74 is offline Find More Posts by bastian74
Doppler Frequency shift speed measurement? guilartec DIY Electronics 17 Jun 14, 2011 07:37 AM
Question How to shoot/calculate doppler speed? meteor Electric Ducted Fan Jet Talk 5 Sep 10, 2004 09:11 AM
Doppler shift speed analysis realdeal Power Systems 5 May 01, 2002 12:28 AM
Measuring speed by using the Doppler effect? Mikael Pedersen Power Systems 51 Jun 26, 2001 02:48 PM
