Old Sep 14, 2010, 09:00 AM
paulatgis is offline
Find More Posts by paulatgis
United States, FL, Melbourne
Joined Apr 2009
Question
high kV or low kV for plane with fat fuse?
im making a halls bull dog with a 7 inch diameter fuselage, wing span about 3 foot, weight about 1 1/2 to 2 lbs. The fuse is similar to a Gee Bee fat fuse. Should i fit it with a low kV or high kV motor? Im just planning on flying it slow and easy, but i think it requires extra speed for all that wind resistance.
paulatgis is offline Find More Posts by paulatgis
Old Sep 14, 2010, 09:32 AM
Alan Hahn is offline
Find More Posts by Alan Hahn
Chicago 'burbs
Joined May 2006
It is important to know, or remember, that the actual running of a motor is dependent on both the kV AND the pack voltage. There is basically no difference in efficiency. So a 1000kV motor on a 3s pack will behave identically to a 1500kV motor on a 2s pack. In both cases I assume the same motor family (e.g. Scorpion 3020-xx) and that the battery pack capacities scale as the kV--so if the 3s pack is a 1000mAHr pack, the 2s pack is a 1500 mAHr pack. That's so you are carrying the same energy, and if the "C" is the same, the current capability will also be the same.
The only difference is the 2s system needs to have an ESC with a higher current capability-since the watts will be the same.
Alan Hahn is offline Find More Posts by Alan Hahn
Old Sep 14, 2010, 12:10 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Your logic is flawed :-) Gee Bee exampled has a Very streamlined/ sophisticated fuse/shape.. despite all shade tree opinions.
It was a successful, purpose designed race machine built for max speed.
Gee Bees don't fly slow happily... wing loading is wayyy too high. IF memory serves wasn't the Bulldog a racer?
If so it's needing a.. much.. lower weight/ wing loading to float about.
Only thing of concern is the amount of prop extending beyond the engine cowl.. as there are views that only the outer edges of props actually do the 'heavy lifting'. Size the prop accordingly, then decide what motor is indicated.
Bare is offline Find More Posts by Bare
Old Sep 14, 2010, 01:44 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
If you're looking at fitting a scale size prop, and the cowl is 7" diameter, that's one fair sized scale prop at 13.5".
For that you would need a fairly low kv outrunner, (or inrunner and a gearbox).
eflightray is offline Find More Posts by eflightray
Old Sep 14, 2010, 02:44 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
A KEDA TR2837/16 (~920Kv) swings a 13x6.5 at 21A/220W on 3s... that gets you 43oz thrust but only 37mph... you might be better with a 12x8.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Sep 14, 2010, 09:40 PM
flypaper 2 is online now
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
If I remember right, the outer third of the prop does most of the work.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Discussion which type of engine is better high kv or low kv rc-conk Power Systems 6 Oct 08, 2008 03:19 PM
Discussion High KV motor or Low KV motor? learninginverted Mini Helis 104 May 15, 2008 03:45 PM
Discussion looking for foam plane with "fat" fuse swiart2 Foamies (Scratchbuilt) 2 Nov 20, 2006 01:35 AM
high kv low kv high amp low amp what_the?! Electric Ducted Fan Jet Talk 56 Sep 23, 2005 08:35 AM
High KV or Low KV RockyTse Power Systems 2 Apr 26, 2004 09:51 AM
