Old Jun 16, 2012, 02:21 PM
RCPilot1234 is offline
Find More Posts by RCPilot1234
Joined Jan 2012
Originally Posted by alan49 View Post
yes i know what post #1457 says about prop size bing 13 * 6.5 but the manual states that the prop size should be 12 * 6 just wanted to know if using the hacker motor what the size should be used..
Thanks Alan
Hope my reply on the previous page at the bottom helps
RCPilot1234 is offline Find More Posts by RCPilot1234
Old Jun 16, 2012, 02:27 PM
alan49 is offline
Find More Posts by alan49
alan49's Avatar
Joined Jun 2010
Yes great help thanks i am using a ice lite75 so amps should not be a problem i will give the big prop a go and see what happens
Alan
alan49 is offline Find More Posts by alan49
Old Jun 16, 2012, 02:30 PM
Joined Jan 2012
Alan
Be careful not to draw too many amps on the motor though, haha! But yep, great ESC choice Make sure to set fast throttle response, really perks the plane up in my opinion
Old Jun 16, 2012, 08:49 PM
H.D. is offline
Find More Posts by H.D.
ride hard and fly low
H.D.'s Avatar
Joined Aug 2011
Got about ten flights on the MXS today and it was a blast.
H.D. is offline Find More Posts by H.D.
Old Jun 17, 2012, 05:47 PM
Joined Jan 2012
Guys,
I seem to be getting a quite a bit of blowback (I think it's that). When I'm at max throttle, the roll rate is a lot slower than if at medium speed. I'm using the inbuilt BEC on the ICE Lite 50 and running it 6V. Should I increase the voltage? Or should I get an external BEC?
Thanks!
Old Jun 17, 2012, 06:34 PM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Won't matter with analog servos
stgdz is offline Find More Posts by stgdz
Old Jun 17, 2012, 06:52 PM
Joined Jan 2012
I'm using digital at the moment, haha! They are the 5065 on ailerons + rudder and 5085 on elevator
Old Jun 17, 2012, 08:21 PM
Tom K. is offline
Find More Posts by Tom K.
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
Hmmm, Motrolfly makes a good ESC and I use them in almost all of my EXPs. You just pull a tab and it runs 6 volts to your servos. I'd check to see if you are actually getting 6 volts to your servos because normally you don't get blowback with those servos.
--Tom K.
Tom K. is offline Find More Posts by Tom K.
Old Jun 17, 2012, 08:40 PM
propchief is offline
Find More Posts by propchief
JKasprak
propchief's Avatar
Fayetteville, NC 28304
Joined Jan 2010
Is it blow back or too much throw at too fast a speed? 45 degrees of throw at high speed can induce a lot of drag.
propchief is offline Find More Posts by propchief
Old Jun 17, 2012, 09:06 PM
Joined Jan 2012
Well it maybe that but the roll slows down quite a bit so I don't think it's all that, haha!
Old Jun 17, 2012, 09:07 PM
Joined Jan 2012
--Tom K.
I've set the inbuilt BEC to 6V so hopefully I'm getting that, LOL! Would those servos take a higher voltage?
Old Jun 17, 2012, 09:12 PM
Tom K. is offline
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
Eh, I wouldn't chance it... motors and ESCs aren't the only things that make magic smoke.
--Tom K.
Old Jun 17, 2012, 09:14 PM
Tom K. is offline
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
To test for blowback a good way is to nail full aileron while going slow, then punch full throttle and increase your speed and see if the rollrate increases or decreases. It should increase. If it decreases, it's blowback. But is sounds like you already have a handle on that. How old are those servos?
--Tom K.
Old Jun 17, 2012, 09:30 PM
Joined Jan 2012
--Tom K.
Servos are brand new
I've tried this and something really weird happens... When I'm going at max throttle them apply full aileron, the roll rate is poor. But if I apply full aileron whilst going slow them speed up, it's fine, really strange, haha!
Old Jun 17, 2012, 09:31 PM
Joined Jan 2012
--Tom K.
LOL, that magic smoke is funny! It's like a little poof sound then some black dust flys around, hahaha!
Video Extreme flight rc mxs-exp EXTREME FLIGHT Electric Plane Talk 12 Jul 21, 2014 06:24 PM
Discussion EXTREME FLIGHT MXS EXP part 2-First prototype assembly and evaluation process EXTREME FLIGHT 3D Flying 2178 May 13, 2012 10:51 PM
Sold 48" Extreme Flight Edge 540T-EXP red white blue -$320 ARTF AirRaider_2009 Aircraft - Electric - Airplanes (FS/W) 5 Nov 07, 2010 10:50 PM
Sold 48" Edge EXP Extreme Flight, make offer crazyflyin Aircraft - Electric - Airplanes (FS/W) 9 Sep 14, 2010 06:45 AM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 02:48 PM
