Old May 13, 2012, 04:31 PM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
Made it out for four quick flights this morning, man since going to the 14x7 prop I really really love this plane. It's running a close second to my 60" Edge and is by far the best 48" plane I've had. Might need to order some more batts now. Hmmm, 10% off at Hobbypartz.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old May 13, 2012, 05:01 PM
Motojunk is online now
Find More Posts by Motojunk
Fly it 'till it breaks.
Motojunk's Avatar
Joined May 2011
Originally Posted by stgdz View Post
Just out of curiosity what are you travel %'s
115% on ailerons, 120% for elevator on the servo end-points with my Futaba. Triple rates are all set at 100% for high. Not sure what my mid & low rates are at the moment and I haven't measured the deflection angles, just eyeballed it.
Motojunk is online now Find More Posts by Motojunk
Old May 13, 2012, 06:50 PM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
You could set your rates to 150 and drop a hole size and gain resolution.
That's what I do.
stgdz is offline Find More Posts by stgdz
Old May 13, 2012, 09:49 PM
Motojunk's Avatar
Joined May 2011
That's what I do.
Are you using Futaba? I've heard people doing that with the Spektrums but on my Futaba I don't seem to notice any additional movement past 135. Maybe I'm doing something wrong? I'm fairly happy with the way my controls are set up at this point.
Old May 13, 2012, 09:50 PM
stgdz is offline
Volts>amps
stgdz's Avatar
Joined Jul 2011
Talk to doc austin about rates then, he is one of the futaba guys around here.
Also nice flying
Old May 14, 2012, 07:07 AM
propchief is online now
Find More Posts by propchief
JKasprak
propchief's Avatar
Fayetteville, NC 28304
Joined Jan 2010
If you're happy with the way it's set-up and given the flying in the video I wouldn't change anything.
propchief is online now Find More Posts by propchief
Old May 14, 2012, 09:28 AM
-= GYRO =- is offline
Find More Posts by -= GYRO =-
United States, NV, Las Vegas
Joined Nov 2010
Disagree.
-= GYRO =- is offline Find More Posts by -= GYRO =-
Reply With Quote  (Disabled)
Old May 14, 2012, 09:34 AM
JKasprak
propchief's Avatar
Joined Jan 2010
Care to explain why your would change the set up?
Old May 14, 2012, 09:46 AM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Agree
7oneWo1f is offline Find More Posts by 7oneWo1f
Old May 14, 2012, 10:00 AM
Joined Nov 2010
Sure! I don't like when my planes crash and it isn't my fault. Read below:
Originally Posted by -= GYRO =- View Post
Had another crash with mine today due to loss of control (brownout). However, I suspect the culprit was a Savox servo failure (AGAIN). This is the 2nd time I've had my Edge lock me out in flight, and the second time I noticed a servo issue when retrieving the plane post-crash. Unfortunately, this crash did a little more damage than the last:
Completely caved in the landing gear, bent one of the SFG, collapsed the balsa ply in the left wing in 3 places, demolished the former (i think its a former) just aft of the vent hole, broke the 2 bottom CF stringers free in the tail, and punctured the fuse where the trailing edge of the wing meets the fuse.
Funny, my MXS on Hitecs hasn't had this issue. Cue Doc comment about Hitec... Maybe he's right?
Giving some serious thought to changing out these SH-0255MG servos... but man the plane flies so nice when they're working right!
-Gary
Thanks E. But as you saw when you were here, she's been repaired once, and will be repaired again! Speaking of, it looks like I'll get to completely rebuild one of the landing gear formers! Guess this is my opportunity to make the gear even more bulletproof.
As for the Savox SH-0255MG servo... I have confirmed 100% that the elevator servo was my problem today. Here is how: I reconnected power to the plane on the bench, and the elevator was completely unresponsive again. Swapped channels with the rudder, and the rudder moved fine with elevator inputs. I then removed the servo and put it on my Hitec HFP-10 servo tester. It would move a little, but was abnormally jittery and then the servo tester started flashing "low batt". I know the tester had a full battery because I fully charged it last weekend and have not used it for more than 2 minutes since. I interpreted the "low batt" indication as an excessive current draw. Cause for crash isolated, mishap investigation closed.
Unfortunately, this is the second elevator servo to fail on this airplane, and I feel like a butt head for trying to advocate for Savox, when (at least in MY case,) they aren't performing, and are causing damaging crashes to my awesome plane!
I will be returning the failed servo to Savox, and selling the rest. I'll put some Hitecs back in, (including a HS-85mg on the elevator) and see if I can feel a difference when flying.
After all the time repairing this plane from crashes that weren't my fault, I just want some reliable electronics in there.
Gary
Old May 14, 2012, 10:27 AM
JKasprak
propchief's Avatar
Joined Jan 2010
OK - I see the reason behind going to a better servo on the elevator ... makes sense. However, I don't see the need to change radio settings. Thanks.
John
Old May 14, 2012, 10:29 AM
Joined Nov 2010
John
I think we crossed paths... I misread your post and thought it was in regards to leaving "everything" alone if flies well.
That being said, proper radio setup can extend servo life. The farther out on the arm that a servo rod is attached, the harder the servo has to work to move the arm. By doing as was suggested, and moving the link in one hole, while increasing end points, you'll get better resolution and better mechanical advantage.
Old May 14, 2012, 10:33 AM
Doc Austin is online now
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
I don't guess there is any right or wrong to set up work as long as you can get the plane to fly the way you want it to. After seeing Motojunk's video I'de say there's nothing wrong with that plane, but I probably couldn't fly it that way.
However, I deal with this kind of stuff all time time helping out students and new 3D pilots. I generally like to get them over to my shop and go through the plane first, because they usually have most of their set up fubared and it's too much work to correct at the field. I usually have to change the linkage set up, seal the controls, and every time I have to format the radio program and start from scratch. You can't believe some of the things I have seen people do with their set ups.
On the Extreme Flight planes, it's all figured out for you. Use the servo arms they show in the manual, max your end points, set the expo at 75% and let it rip. That's exactly how I set up every plane I own. I played around with set up on these planes for the better part of a year, and I ended up with what was in the manual anyway. The only deviation I make is that I use a long Dubro arm on the elevator servo so I can get 88 degrees of deflection. I find this especially useful on the MXS.
But in general terms, set your high rate at 100% and leave it there for the rest of your life. If you want more or less throw, make the adjustments mechanically, or if it is a small adjustment, use your end point controls. I also like to have my end points as high as I can get them. If I have to go below 120% on the end points, I would rather move the ball link in a hole and turn the end points back up.
In the end, if you just use the set up from the manual and fly the crap out of it, you'll make more progess than constantly tinkering with the plane.
Doc Austin is online now Find More Posts by Doc Austin
Old May 16, 2012, 09:26 PM
Joined Nov 2010
if any of you fellas need a red rebuild kit, I just listed one for sale: http://www.rcgroups.com/forums/showt...0#post21634463
Old May 17, 2012, 11:45 AM
Chuck is offline
Find More Posts by Chuck
Balsa to the Wall
Chuck's Avatar
Deep in the East Texas Piney Woods
Joined Dec 2001
Well, I built mine with the recommended setup and flew it for the first time Monday. Boy, was I impressed. I have a 47" SHP that I love, but this is a whole 'nother animal. With max throws, she just gets plain stupid. I love it.
Good job EF, this one's a keeper fer sure.
Chuck
Chuck is offline Find More Posts by Chuck
Video Extreme flight rc mxs-exp EXTREME FLIGHT Electric Plane Talk 12 Jul 21, 2014 06:24 PM
Discussion EXTREME FLIGHT MXS EXP part 2-First prototype assembly and evaluation process EXTREME FLIGHT 3D Flying 2178 May 13, 2012 10:51 PM
Sold 48" Extreme Flight Edge 540T-EXP red white blue -$320 ARTF AirRaider_2009 Aircraft - Electric - Airplanes (FS/W) 5 Nov 07, 2010 10:50 PM
Sold 48" Edge EXP Extreme Flight, make offer crazyflyin Aircraft - Electric - Airplanes (FS/W) 9 Sep 14, 2010 06:45 AM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 02:48 PM
