Old Feb 20, 2012, 07:37 AM
jwilliamsrc is offline
Find More Posts by jwilliamsrc
Team Extreme Flight, JR, BandE
Georgetown, IN
Joined Dec 2003
Originally Posted by TG43 View Post
Question...Airtronics 94809's would be a good choice for servo for this plane right? Is the 94809 loose in the servo cut out for the elevator?
I am running the Airtronics 94809's on my Extra and MXS EXP's. They are excellent servos but pricey, if you can afford it I doubt you will find better. I am using the 94809 on the MXS elevator and it works but is the minimum. Also Hercdriver and Chris Hinson have used the 94809's if you need additional testimony.
Jeff Williams
jwilliamsrc is offline Find More Posts by jwilliamsrc
Old Feb 20, 2012, 07:10 PM
Irg is online now
Irg
Find More Posts by Irg
Irg
ol' yellow eyes is back
Irg's Avatar
United States, NY, Alfred
Joined Apr 2009
are you guys with the DM 2820-750 using any spacers or just bolt it right to the firewall?
Irg is online now Find More Posts by Irg
Old Feb 21, 2012, 10:06 AM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
mine is right to the firewall..
Manta1 is offline Find More Posts by Manta1
Old Feb 21, 2012, 10:23 AM
bryansifsof44 is offline
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
How is your spinner gap?
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Feb 21, 2012, 11:25 AM
Irg is online now
Irg
Irg
Irg's Avatar
Joined Apr 2009
thanks Manta
Old Feb 21, 2012, 12:35 PM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Bought 2mm on mine, maybe more.
stgdz is offline Find More Posts by stgdz
Old Feb 21, 2012, 02:44 PM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Very nice thank you.. see attached.
This is the DM2820 in the Edge, I assume the MXS will fit up much the same. Cowl is at it's most forward position.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Feb 25, 2012, 11:29 PM
Joined Oct 2011
Posted this in the Owners Thread, but here is a is the video of the MXS with the Motrolfly 2820-750 and a Castle ICE 75 lite spinning a 14x7 APC e prop running on a Gens Ace 4s 2500mAh 25C.
Extreme Flight MXS 2/25/12 (4 min 23 sec)
Old Feb 26, 2012, 08:38 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
it was ok till i let Losi fly it hehehehehe.
i think the msx is a bit shorter in the motor box area? My spinner gap is out there some but my plane got crashed the first weekend it was ran so it is a bit beat up.I just fly the punk out of it now.
Old Feb 26, 2012, 09:03 PM
aerosheldon is offline
Find More Posts by aerosheldon
No one has more fun than me
aerosheldon's Avatar
United States, CO, Denver
Joined Sep 2003
What are the ultimate servos for the MXS?
aerosheldon is offline Find More Posts by aerosheldon
Old Feb 26, 2012, 09:06 PM
Joined Oct 2011
I vote for the digital versions of the recomended hitecs, but make sure you have enough power to them. Others run Savox with success.
Old Feb 27, 2012, 07:32 AM
cbriggs11 is offline
Find More Posts by cbriggs11
Team Twisted!
cbriggs11's Avatar
United States, SC, Greenville
Joined Nov 2009
mxs (3 min 8 sec)
Last video of my mxs before it gets sold.
cbriggs11 is offline Find More Posts by cbriggs11
Old Feb 27, 2012, 10:36 AM
-= GYRO =- is offline
Find More Posts by -= GYRO =-
RC Pilot / Photographer
-= GYRO =-'s Avatar
Joined Nov 2010
At first, I installed the Savox SH-0255MG in the tails, and SH-0257MG in the ailerons. Everything worked great, tons of deflection, fast movement, etc. Flew her this way for 12 flights, with ZERO problems. However, I just ordered a slightly larger airplane that needed the more powerful servos so last night I pulled them out and replaced them with HS-65MGs all around except the elevator, which got a HS-85MG. This is the "factory" recommended setup. Haven't flown with this config yet, however I suspect it'll do just fine.
Originally Posted by cbriggs11 View Post
http://vimeo.com/37520473
Nice video Coty!
-= GYRO =- is offline Find More Posts by -= GYRO =-
Old Feb 27, 2012, 11:26 AM
Team Twisted!
cbriggs11's Avatar
Joined Nov 2009
Old Feb 27, 2012, 11:48 AM
Doc Austin is online now
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
I ran that set up in my original MXS for about 250 flights before a transmitter failure took that plane out, then transferred them into my project blue MXS beater, and put about 200 flights on them in that before a brain glitch trashed that one.
Right now those servos are at Hi Tec getting checked over. I figure 450 flights is probably too much to ask from a set of servos, especially as hard as we push these little things. Hi Tec should probably tell me to stuff it because I got my money out of them, but I am betting they will fix the scored potentiometers in some, and the damaged amplifiers in others. In servos that have both, I am betting they just replace them. This has been the pattern I've seen from their service department for the last five years.
One humorous note is a few weeks ago I actually got a phone call from Hi Tec service. The guy says "Sir, what the heck are you doing to these things?" Seems I have sent so many back with stripped gears they had to put a stop to it, because gears are not covered under warranty. In the past they just fixed them anyway, but I guess when the number hit 50 it set off a few alarms there! Hi Tec generoulsy fixed that one last batch of servos for me anyway, but suggested that I learn how to swap out gears on my own.
So, now I have to learn how to change gears, but in the long run that will be a positive. A set of gears for a 65HB servo are about $4, and it includes the little plastic idler gear that is identical to the one that you usually strip in the MG servos. It costs more than that to send a servo back, so I will just need to get some better magnifier glasses and start swapping out gears.
Here's the last video of my beloved project blue MXS. These servos have close to 450 flights on them, but you can see there's no stalling, blowback or delay in response. It would be impossibgle to be more pleased wih a set of servos. The best part is I will be without them for a week, and then they will either be brand new or good as new.
Doc Austin is online now Find More Posts by Doc Austin
Video Extreme flight rc mxs-exp EXTREME FLIGHT Electric Plane Talk 12 Jul 21, 2014 06:24 PM
Discussion EXTREME FLIGHT MXS EXP part 2-First prototype assembly and evaluation process EXTREME FLIGHT 3D Flying 2178 May 13, 2012 10:51 PM
Sold 48" Extreme Flight Edge 540T-EXP red white blue -$320 ARTF AirRaider_2009 Aircraft - Electric - Airplanes (FS/W) 5 Nov 07, 2010 10:50 PM
Sold 48" Edge EXP Extreme Flight, make offer crazyflyin Aircraft - Electric - Airplanes (FS/W) 9 Sep 14, 2010 06:45 AM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 02:48 PM
