Old Feb 17, 2012, 10:56 PM
RFairbairn is offline
Find More Posts by RFairbairn
RFairbairn's Avatar
United States, SC, Simpsonville
Joined Aug 2011
Thanks guys, it is a beaut and really shows up well in the air. EF did a great job on this one, the covering and fit and finish are outstanding! I did have to rework the canopy slightly to get it to fit flush, but it was no big deal.
Yeah Chis, Barn door elevator is right, that thing just looks crazy at full deflection
RFairbairn is offline Find More Posts by RFairbairn
Old Feb 18, 2012, 12:43 AM
TG43 is offline
Find More Posts by TG43
TG43's Avatar
Glens Falls, NY
Joined Apr 2010
Question...Airtronics 94809's would be a good choice for servo for this plane right? Is the 94809 loose in the servo cut out for the elevator?
TG43 is offline Find More Posts by TG43
Old Feb 18, 2012, 01:04 AM
Doc Austin is offline
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
I believe that is the Airtronics that some guys are using with good success on the the Extra and Edges, but the MXS elevator servo hole comes cut out for an HS85MG. There is a plywood piece that comes in the kit you glue in to resize back to HS65MG size.
I might have missed it, but I don't believe anyone has tried anything but an HS85MG on an MXS elevator. The MXS has such breathtaking pitch authority that I would absolutely go with an HS85MG or an HS5085MG. For one, it fits. For another, we already know the HS85MG works really, really well.
The HS5065MG might be really big overkill, so I may have to try one,
This video is full of high pitch maneuvers possible only with a plane that has this kind of authority. If you go to 4:30, you will see what I believe is the world's first parachure dive into a hover. You've gotta have confidence in your aircraft, and especially your elevator servo to try something like that.
Doc Austin is offline Find More Posts by Doc Austin
Old Feb 18, 2012, 07:52 AM
TG43 is offline
TG43's Avatar
Glens Falls, NY
Joined Apr 2010
Thanks Doc. I'd like to try digitals because I have an 8FG coming and would like to take full advantage of the HS receiver. I might go 5065's and a 5085. Didn't realize there were digital versions of the 65/85mgs.
Old Feb 18, 2012, 07:58 AM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Yeah but some of us are looking at the savox digitals for 33 a piece and then using the hitec 5085 since the savox mini os so expensive.
stgdz is offline Find More Posts by stgdz
Old Feb 18, 2012, 08:01 AM
Irg is offline
Irg
Find More Posts by Irg
Irg
ol' yellow eyes is back
Irg's Avatar
United States, NY, Alfred
Joined Apr 2009
there's been some anecdotal evidence that the 5065s are not as robust as the 65mgs.
if I were starting from scratch I would likely go the savox x3, and the 5085x1.
Irg is offline Find More Posts by Irg
Old Feb 18, 2012, 08:18 AM
TG43 is offline
TG43's Avatar
Glens Falls, NY
Joined Apr 2010
What is the part number for the Savox servo you guys are running and where is a good place to get them? Use Futaba servo arms?
Old Feb 18, 2012, 09:37 AM
Tom K. is offline
Find More Posts by Tom K.
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
Savox SH-0255MG. 54 oz/in at 0.13 sec. Digital, $33. www.savoxusa.com They come with good plastic arms. They have a 23 tooth spline so I'm not sure if futaba minis match ot not... but the bigger ones with 25 teeth I know fit.
I use that in all my 48" EXP's elevators.
--Tom K.
Tom K. is offline Find More Posts by Tom K.
Old Feb 18, 2012, 11:31 AM
TG43 is offline
TG43's Avatar
Glens Falls, NY
Joined Apr 2010
You run four sh-0225mg's in yours?
Old Feb 18, 2012, 11:41 AM
bryansifsof44 is offline
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
I'm happy with hitecs service... I get my servos back in 10-15 days, last time with no charge. Does Savox take care of you?
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Feb 18, 2012, 01:42 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
I am building a new Edge EXP next week and running HS5065MGs all the way around. The HS65MG is getting a little marginal on these planes. With the big surfaces and high degrees of deflection we are really demanding everything, and more, that we can get out of these little servos.
For a few years I have been getting blowback at speed on my 4s planes, burning out amplifiers and scoring potentiometers. When I went to the EXP series, the extra performance just made the problem worse.
The reason I chose to try this on the Edge is because my first Edge was stalling and blowing back the HS65MG elevator servo pretty badly, but to be fair, that was on an old Airboss and running on 5.2 volts. The HS5065MG should be fine, especially with the newer 6 volt Airboss.
Old Feb 18, 2012, 02:28 PM
RFairbairn's Avatar
Joined Aug 2011
Nice flyin Doc, Really shows off how to "use" that crazy elev throw
Old Feb 18, 2012, 10:29 PM
H.D. is offline
Find More Posts by H.D.
ride hard and fly low
H.D.'s Avatar
Joined Aug 2011
First flights with my MXS, used 3s for the first 3 flights but needed more power. Cracked the landing gear on the 1st landing and crashed on the 3rd flight, a little glue and back up with a 4s, now this is fun, threw her into a high speed tumble and crack, 3 of the 4 hinges came out and the aileron was hanging by the servo linkage and one hinge, ! Managed to gain control and get her down, not much fun with 12-15 mph winds and one working aileron. CA on all hinges and back up with no more issues. Can't wait to get her out again.
H.D. is offline Find More Posts by H.D.
Old Feb 18, 2012, 11:42 PM
Tom K. is offline
Facts, Logic, 3D
Tom K.'s Avatar
Florida
Joined Nov 2010
Unfortunately I don't own one if these... yet... but in my other 48" EXPs I run 3 sh-0257mg servos for rudd and aile, and 1 sh-0255mg on the elevator. They are both digital and the specs and prices blow away the digital hitec equivilants.
--Tom K.
Old Feb 19, 2012, 12:29 AM
TG43 is offline
TG43's Avatar
Glens Falls, NY
Joined Apr 2010
I actually meant the 255, funny how one digit can mess everything up, lol. Found some (0257's/0255's) in stock at A-main hobbies so I'm gonna give them a try. why not right..
Video Extreme flight rc mxs-exp EXTREME FLIGHT Electric Plane Talk 12 Jul 21, 2014 06:24 PM
Discussion EXTREME FLIGHT MXS EXP part 2-First prototype assembly and evaluation process EXTREME FLIGHT 3D Flying 2178 May 13, 2012 10:51 PM
Sold 48" Extreme Flight Edge 540T-EXP red white blue -$320 ARTF AirRaider_2009 Aircraft - Electric - Airplanes (FS/W) 5 Nov 07, 2010 10:50 PM
Sold 48" Edge EXP Extreme Flight, make offer crazyflyin Aircraft - Electric - Airplanes (FS/W) 9 Sep 14, 2010 06:45 AM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 02:48 PM
