Old Jan 29, 2012, 04:20 AM
jason H is offline
Find More Posts by jason H
Magic Blue Smoke costs to much
jason H's Avatar
Melbourne, AUSTRALIA
Joined Dec 2004
Not very happy with my EF Boss speedie. Maiden flight my power switch fell apart on final, she rolled over and smashed up the port wing. Second flight after repairing the wing and cutting off the switch it signed off all together 3 min in. R.I.P. EF MXS......
Love there airframes / kits, will never run there electrics again.
jason H is offline Find More Posts by jason H
Old Jan 29, 2012, 06:05 AM
jdubg23 is offline
Find More Posts by jdubg23
half-ass Astronaut
jdubg23's Avatar
United States, FL, St Petersburg
Joined Jan 2011
Originally Posted by Doc Austin View Post
Killed my MXS today.
hey doc whats the chance you salvaged a landing gear from that carnage?
jdubg23 is offline Find More Posts by jdubg23
Old Jan 29, 2012, 10:07 AM
Doc Austin is offline
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Landing gear is ok. You can have it if you get me another one.
Doc Austin is offline Find More Posts by Doc Austin
Old Jan 29, 2012, 09:26 PM
propchief is offline
Find More Posts by propchief
JKasprak
propchief's Avatar
Fayetteville, NC 28304
Joined Jan 2010
Originally Posted by terryj View Post
Thanks Doc. That was my first thought as well. Headed to the workshop now. Plan B would be to try a 2mm heli turnbuckle that is a bit longer. Since you are getter near 90 degrees deflection, geometry must be OK. Take care.
Turning the elevator servo around is a great tip. I wasn't comfortable hammering on the elevator with only a couple threads into the clevis so after the first flying session I turned the servo and also increased the throw. Felt better about the clevis being secured ... but WOW the elevator authority. Really amazed at the MXS' ability to change direction and maintain control. At one point in the second flight today it looked like a hummingbird darting around. Very cool! Wish I had video.
propchief is offline Find More Posts by propchief
Old Feb 05, 2012, 06:28 AM
terryj is offline
Find More Posts by terryj
Arleta, CA
Joined Aug 2005
No blind nuts for wing tips?
All,
I pretty much finished up mine yesterday except for the wing tips and maybe some decals. I was going for the racing tips (they look cool) but could not find the blind nuts behind the covering. All I've managed to do is chew up the covering and balsa looking for them. Anyone else run into this? If so, what did you do?
Terry
terryj is offline Find More Posts by terryj
Old Feb 05, 2012, 06:37 AM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
All,
Terry
There are no blind nuts, just run a trim screw into the wood, then remove the screw and Put a drop of ca in the hole to harden the wood. This way the screws will hold stronger when you screw them back in.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old Feb 05, 2012, 07:40 AM
terryj is offline
Arleta, CA
Joined Aug 2005
Thanks. That's what I figured. Just didn't want to drill into it and THEN find a blind nut behind it.
Old Feb 05, 2012, 12:44 PM
Burke, VA
Joined Sep 2009
What's really crazy is, when I first got mine, I noticed a couple of dimples in the wing tips that lined up with the holes in the sfg's. So, assuming there were blind nuts here, I removed a little covering and took my exacto and drilled through the wood. Then I used the enclosed machine screws to attach the sfg's and they tightened down pretty tight. After about 50 flights I noticed one of the sfg's was loose and when I tightened it down it wouldn't hold. That's when i figured out there were no blind nuts. So I switched all the machine screws out for some #4 trim screws and hardened the wood with ca. Been fine ever since.
Old Feb 05, 2012, 03:40 PM
terryj is offline
Arleta, CA
Joined Aug 2005
There is plywood behind the balsa. You must have "tapped" it with the machine screws. I don't think there were holes in the plywood but I'm not sure. I held the tip in place and took a sharpened piece of music wire and pushed it through a plastic tube. I then drilled 1/16" then 5/64" then 3/32" holes. Screwed in #4 sheet metal (socket head) screws then removed them and hardened the threads. I used some fiber washers I had to increase the gap by a few extra .001" to make sure the ailerons wouldn't hit the tips. RTF next weekend.
Old Feb 10, 2012, 07:42 PM
terryj is offline
Arleta, CA
Joined Aug 2005
Going flying
It was ready last Sunday afternoon but that work thing got in the way.
Old Feb 10, 2012, 08:06 PM
JKasprak
propchief's Avatar
Joined Jan 2010
Nice racing stripe on the bottom of the wing.
I hate when that work thing get in the way of fun!
Old Feb 10, 2012, 09:06 PM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Really wish EF would update some of their manuals at this step, the only one that has had the blind nuts is my EF edge. Now I have 3 big holes in my MXS.
stgdz is offline Find More Posts by stgdz
Old Feb 10, 2012, 09:40 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
How big? Try using the same size bolts as holds the motor mount on. You'll need the long ones if you are going to use the fiberglas tips.
In the times I have pulled the screw out of the wood and taken wood with it, I have plugged the hole with a little balsa dowel. Just cut it to about the right length, tap it into the hoile, and when flush, soak with CA.
Old Feb 10, 2012, 10:47 PM
stgdz is offline
Volts>amps
stgdz's Avatar
Joined Jul 2011
In the times I have pulled the screw out of the wood and taken wood with it, I have plugged the hole with a little baksl dowel. Just it to about the right length, tap it into thge hoile, and when flush, soak with CA.
Put some med CA in there and let it harden, then put the screws in. Seems to hold it in fairly well. Can't wait to get this one up in the air. I mounted both tips and SFG's and this one looks like it is going to haul.
Old Feb 11, 2012, 01:16 AM
bryansifsof44 is offline
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
Got off work early today and put 5 packs through the MXS, you guys will enjoy I'm sure. Also have done repair with CA on the wingtips due to using SFG's as training wheels, easy fix. Good luck!
bryansifsof44 is offline Find More Posts by bryansifsof44
Video Extreme flight rc mxs-exp EXTREME FLIGHT Electric Plane Talk 12 Jul 21, 2014 06:24 PM
Discussion EXTREME FLIGHT MXS EXP part 2-First prototype assembly and evaluation process EXTREME FLIGHT 3D Flying 2178 May 13, 2012 10:51 PM
Sold 48" Extreme Flight Edge 540T-EXP red white blue -$320 ARTF AirRaider_2009 Aircraft - Electric - Airplanes (FS/W) 5 Nov 07, 2010 10:50 PM
Sold 48" Edge EXP Extreme Flight, make offer crazyflyin Aircraft - Electric - Airplanes (FS/W) 9 Sep 14, 2010 06:45 AM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 02:48 PM
