Old Jan 14, 2012, 08:30 AM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
thanks Blakevan!Just having a little fun with iMovie.Neat little program.need more templates to choose from tho..Lotsa learning to do there Those were some fun days flying too
Manta1 is offline Find More Posts by Manta1
Old Jan 14, 2012, 09:50 AM
Doc Austin is online now
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Manta rocks!
I tore up my blue MXS a little yesterday. I am not even sure what happened, but it bounced hard enough to snap both gear legs, break both wheels, shear off a steel axle and crack the spinner cap.
Damage to the airframe was that the two carbon motorbox rods were popped loose at the joint, and a few glue joints were broken where the motorbox goes through the first former. That got twisted enough that I had to force it all back into place, but surprisingly there was no broken wood. I had everything back together and glued in 10 minutes.
The biggest pain was it broke an SFG. That has an $8 decal on it and I did not want to strip the covering, so, and I had to inject CA into the wood through the covering. It is surprising how well that works. CA soaks into everything, so just a sinle pin hole entry point can cover a lot of repeair. Plus, after it dries you can hit it with the trim iron and the entry hole seals up. The tough part is getting hypos, but unfortunetly for them, I have a few diabetic friends.
It was a really hard hit, but I fixed the whole thing, cleaned the plane up, checked all the hinges, critical joints, and tightened all the screws in about 30 mninutes. I am starting to see that part of how I can fly so confidently is because I know most mistakes are not going to do so much damage that I can't fix it fairly easilly. It helps to have so much unshakable faith in the plane's flying abilities, and it is also reassuring to know a small hit isn't going to cost you a replacement airframe.
Doc Austin is online now Find More Posts by Doc Austin
Old Jan 14, 2012, 10:20 AM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Originally Posted by Doc Austin View Post
Manta rocks!
WOW!!Again,Doc is the luckiest crasher i know..lolol..It will fly much better now that you doinked it.I've often said best thing to do it take planes out of the box,throw them across the room,fix what you broke,then put it together and go fly and all the rough edges of flying it will be gone hehehehe
Old Jan 14, 2012, 02:04 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Skilled crashing. Get it right! Skilled.
I didn't care about this one from the beginning. I was always intended to be a backup plane, but my flightbox fell over on the tail and crushed it. I fixed it, but there's a patch on the elevator, which makes me crazy. I am trying to kill it so I have an excuse to build a new one.
Old Jan 14, 2012, 02:26 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
ok skilled!!! lolol.
Old Jan 15, 2012, 07:30 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
No problem. Just a little bad attitude.
Old Jan 15, 2012, 07:47 PM
hercdriver7777 is offline
Find More Posts by hercdriver7777
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Columbia SC
Joined Feb 2005
Nice flying Doc!
hercdriver7777 is offline Find More Posts by hercdriver7777
Old Jan 15, 2012, 10:33 PM
H.D. is offline
Find More Posts by H.D.
ride hard and fly low
H.D.'s Avatar
Joined Aug 2011
Started my MXS today.
Need to order two servos, speed control and two 4s batteries.
H.D. is offline Find More Posts by H.D.
Old Jan 16, 2012, 09:06 AM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
congrats HD!
Old Jan 16, 2012, 10:18 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Not sure what I was thinking on this flight, other than maybe "It's a good thing I have backups."
Old Jan 20, 2012, 01:24 AM
bryansifsof44 is online now
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
Just posted this on the Extreme Flight owners thread... but this thread need some action so here it is. Getting real comfortable with this plane.
Bryan
Extreme flight MXS Flying in the cold (3 min 39 sec)
bryansifsof44 is online now Find More Posts by bryansifsof44
Old Jan 20, 2012, 05:56 AM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
You harrier looks killer!
Old Jan 20, 2012, 11:10 PM
Joined Oct 2011
I'm trying to work on inverted harrier... I don't know is weight of skis is counter productive to my success or not.
Bryan
Old Jan 26, 2012, 03:00 PM
Columbia SC
Joined Feb 2005
Bryan
http://www.youtube.com/watch?v=upkOSHShxgQ
MXS on Skis = Cool! -8 degrees = Pain! You are the man!
Old Jan 26, 2012, 08:56 PM
bigroger is offline
Find More Posts by bigroger
Just flitting about!!
bigroger's Avatar
Joined Aug 2011
God, what is all that white stuff....bbbrrrrrrrr looks cold.
bigroger is offline Find More Posts by bigroger
Video Extreme flight rc mxs-exp EXTREME FLIGHT Electric Plane Talk 12 Jul 21, 2014 06:24 PM
Discussion EXTREME FLIGHT MXS EXP part 2-First prototype assembly and evaluation process EXTREME FLIGHT 3D Flying 2178 May 13, 2012 10:51 PM
Sold 48" Extreme Flight Edge 540T-EXP red white blue -$320 ARTF AirRaider_2009 Aircraft - Electric - Airplanes (FS/W) 5 Nov 07, 2010 10:50 PM
Sold 48" Edge EXP Extreme Flight, make offer crazyflyin Aircraft - Electric - Airplanes (FS/W) 9 Sep 14, 2010 06:45 AM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 02:48 PM
