15 mph wind in your face at Hodges Hobbies today. Just hucked msx in front of a small crowd of new guys. Harrier to elevator to landing in front of me lol. Backed it right to me. Sometimes wind is fun if it is steady and going in the right direction lol
Latest blog entry: Lil repair work.
Joined Dec 2007
I was hoping there was an easier way. I guess I will just live with it or look for other that are the right length (42mm 1.69"). Thanks for taking the time to explain how you fix your problem. Dennis |
I met up with my friend Luv3D today at SPARKS and we threw it down. We didnt quite break ewverything week took out, but we tried real hard.
I had a really good day with the MXS. Two more videos are cooking now.
Latest blog entry: Extreme Aviation Has A New Home
Yea, tell me xps doesnt have a solid dang link. Even flew it in a small crowd of planes this way. |
There's still time to get one this year, though not much.
Speaking of which, go to 2:30, and then 3:00. As far as I am aware, these are the first two instances of parachute-to-hover. Maybe someone has done them before, but I've never seen or heard of it. The plane arcs into it a little, but it is very close to a pure 90 degre rotation with the plane headed straight down. I believe I was also getting some elvator blowback because the servo was bouncing when centering. I changed it out for a new one and we'l try it again later today and get it perfect.
Last MXS video for awhile. I'm going to concentrate on the 60" Extra for awhile.
Turn the TX on with the "A" switch in the off position, plug the battery in, turn the Airboss switch on. Let the ESC play the tune, then flip on the "A" switch and dial in the mix until the motor idles. I usually end up with around a minus 27 to minus 30mix. After that, be careful that the "A" switch is off before you do anything. If it is on when the ESC isw turned on, the ESC will look for the endpoints of the throttle range, and if the switch is in the on position, it will ignore the mix ad it won't work. The procedure is: "idle" switch off, radio on, airplane on, flip "A" switch to start idloe. If you screw it up and the idle doesn't work, flip the "A" switch off, unplug the battery and start over. I know it sounds very complicated, but that's just how it plays out in writing. If you could see me do it, you'de agree that it's really pretty simple. It just translates into 1000 words. |
Thanks Bryan |
Yesterday I went flying with Manta, and he put a good hammering on his own MXS.....
| Thread Tools | |
| Discussion EXTREME FLIGHT MXS EXP part 2-First prototype assembly and evaluation process | EXTREME FLIGHT | 3D Flying | 2178 | May 13, 2012 10:51 PM |
| Sold 48" Extreme Flight Edge 540T-EXP red white blue -$320 ARTF | AirRaider_2009 | Aircraft - Electric - Airplanes (FS/W) | 5 | Nov 07, 2010 10:50 PM |
| Video Extreme flight rc mxs-exp | EXTREME FLIGHT | Electric Plane Talk | 10 | Oct 18, 2010 12:44 PM |
| Sold 48" Edge EXP Extreme Flight, make offer | crazyflyin | Aircraft - Electric - Airplanes (FS/W) | 9 | Sep 14, 2010 06:45 AM |
| Video Extreme Flight RC Extra 300 EXP 48" Teaser video! | Jvdo | Electric Plane Talk | 6 | Oct 21, 2009 02:48 PM |
