Old Aug 18, 2011, 01:56 AM
Exsocio is offline
Find More Posts by Exsocio
Cosa Nostra EXP
Exsocio's Avatar
Desio (MB - Italy)
Joined Apr 2007
Originally Posted by hercdriver7777 View Post
Here is a good way to check CG and Incidence and Thrust Angle with nothing but the plane itself by flying it.
1. Trim the plane to fly right-side-up at about 1/4 to 1/2 throttle perfectly straight and level so that if you take your hands of the stick it does not climb or dive. Then test it into the wind and downwind to verify your trim.
2. Turn the plane inverted with the EXACT SAME THROTTLE SETTING. If it climbs inverted then you have a tail-heavy condition (go with that assumption for now). If it dives to the ground inverted then it is nose-heavy.
3. Move the battery until the plane neither climbs or dives upright or inverted when trimmed for the same throttle setting.
4. Now that you have a baseline setting for trim we can check CG through the entire airspeed range with a dive test. Take the plane up very high and slow it down to a stall with the throttle at zero. Drop the nose so that the plane is pointing straight down, leave it at zero throttle and take your hands off the sticks. As the plane accelerates with the motor off it will pass through the entire trim speed range and you will discover one of 4 things.
A. The plane will pull to the canopy meaning that you are actually nose-heavy and that you need to adjust your thrust line UP because in step one you trimmed the plane out under power and in step 4 you tested it power off.
B. The plane will pull to the gear meaning that you are actually tail-heavy and that you need to adjust your thrust line DOWN.
C. OR, the plane will one thing at one airspeed and another at the faster airspeed. One example would be when it starts the dive and is going very slow it tucks to the gear but as it accelerates it straightens out and finally
pulls to the canopy. This situation is going to be some result of incidence problems and you should bust out a incidence checker and straighten it out.
D. Finally, if the plane goes straight as an arrow all the way to the ground you have no issues.
One note here is that you should do this dive test multiple times to verify your results and you should also do it in different relative positions to the wind. Another thing to consider is that you should try the dive test once where you bump the elevator in one direction and let it center and then again in the other direction and let it center to make sure you do not have centering problems with your elevator servo. I have seen a lot of "CG" problems from sloppy linkages or bad servos.
Hope that helps!
Good flying!
This is great, useful info!
printed! it goes right in the TX case!
Thank you Herc for sharing.
Exsocio is offline Find More Posts by Exsocio
Old Aug 18, 2011, 08:31 AM
DenverJayhawk is offline
Find More Posts by DenverJayhawk
Epoxy & CA Investor
DenverJayhawk's Avatar
United States, CO, Denver
Joined May 2010
just to confirm, pull to canopy when in the nose down position means it's trying to pull itself out of the dive and eventually end up in upright, level flight, yes? Tuck to gear is just the opposite and will try to end up in inverted level flight.
DenverJayhawk is offline Find More Posts by DenverJayhawk
Old Aug 18, 2011, 09:26 AM
hercdriver7777 is offline
Find More Posts by hercdriver7777
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Columbia SC
Joined Feb 2005
Correct
hercdriver7777 is offline Find More Posts by hercdriver7777
Old Aug 18, 2011, 10:08 AM
mbritt is offline
Find More Posts by mbritt
mbritt's Avatar
USA, IN, Fishers
Joined Jul 2007
Originally Posted by N_O_V8_R View Post
mbritt
I took some measurements for you.
If you measure the vertical angle from the top ply on the motor box down to the bottom ply (battery tray) I get zero thrust angle.
Measuring from the side ply of the motor box I get 1.5 - 2 thrust angle, depending on where I measure it.
Of course, this assumes your motor box is straight forward of the cowl ply, but you should be able to tell by looking at the battery tray
Hope that helps!
Wow thanks, about 2 degrees sounds about right. Thank you everyone for the input. Haven't had a chance to do the adjustments yet. You know how it is life has been in the way. LOL. I will make them tonight and see where it goes. Thanks to everyone for all of the good input!
mbritt is offline Find More Posts by mbritt
Old Aug 18, 2011, 10:15 AM
Brubache is offline
Find More Posts by Brubache
If it hovers I fly it.
Brubache's Avatar
Canada, BC, Vancouver
Joined Jun 2010
YAY! After being away a few days got my flights in this morning. Looks like I got my CG on now. One thing that suprised me was at nice low speed it basically wants to auto harrier... lol. No idea if thats normal or not but its sure cool!
Anyway cannot be happier with how she flies now. Thanks to the board for all its guidance! Now to start pushing it more and more. Ok.. push ME more and more.
Brubache is offline Find More Posts by Brubache
Old Aug 18, 2011, 11:09 AM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Sweet video!
I already have a 1/2 dozen 4s turnigy 2650 Nano's, rated 20-50c for the plane.
Not sure how they would compare to your G-Force Batt's.
Any wattage numbers for these setups?
Flight times?
Manta1
What prop, bat. & esc are you running with your setup?
Is everyone using an idle-up with their setups?
Anyone having sync problems with the airboss/torque setup like we are experiencing with the 60" exp's? I need five extra clicks of trim after the prop starts to be safe.
I'm gonna run the motrolfly receiver. 60amp. 13x6.5 prop illnplay with and the 14x7 as well. I had the 950 on the edge and ran 12x6 for 4s and 14x7 for 3. My batts for the mxs will be 4s 2600 Ish
Manta1 is offline Find More Posts by Manta1
Old Aug 18, 2011, 12:01 PM
mbritt is offline
mbritt's Avatar
USA, IN, Fishers
Joined Jul 2007
Torque motor still on B/O. Don't know if I can wait any longer!
I have a Hacker 55 amp ESC laying around, so what is the best alternate motor I can put in this thing that will fit the existing motor plate?
A30-14L v2
Old Aug 18, 2011, 01:32 PM
Doc Austin is online now
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
That thing is gonna be sick on 4s.
Doc Austin is online now Find More Posts by Doc Austin
Old Aug 18, 2011, 02:16 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
Yup. I like sick. Kinda matches me. Sitting in dr office now with 100.9 temp. Doc you give me your flu over the phone?
Old Aug 18, 2011, 03:26 PM
justinsebastian is offline
Find More Posts by justinsebastian
Justin S
justinsebastian's Avatar
United States, NC, Mt Holly
Joined Nov 2010
Just ordered one of these to replace my 48" Edge-EXP that will either be sold or crashed very soon I couldn't wait any longer.
justinsebastian is offline Find More Posts by justinsebastian
Old Aug 18, 2011, 05:13 PM
N_O_V8_R is offline
Find More Posts by N_O_V8_R
USA, NE, Waverly
Joined Feb 2011
Night and day difference than the "Skywing" MXS, isn't it?
Can't wait to get mine in the air.
I see the back-order on the motors has been lifted.
You have to get a 60" next - just love my 540T EXP. Rock solid.
N_O_V8_R is offline Find More Posts by N_O_V8_R
Old Aug 18, 2011, 05:14 PM
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
No, if you got the flu I had, you'de be sitting in the bathroom instead of the doctor's office.
Old Aug 18, 2011, 06:17 PM
Brubache is offline
Brubache's Avatar
Joined Jun 2010
Um ya. Totally. this thing flies like a proper airplane lol.
Old Aug 18, 2011, 08:06 PM
jwilliamsrc is offline
Find More Posts by jwilliamsrc
Team Extreme Flight, JR, BandE
Georgetown, IN
Joined Dec 2003
TMI Doc.
Jeff
jwilliamsrc is offline Find More Posts by jwilliamsrc
Old Aug 18, 2011, 08:08 PM
Manta1 is offline
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
LOL yea think its a sinus infection but the nurse said I lost 4 lbs..I told her I did that yesterday....I know TMI.servos should be here tomorrow.Maybe my horsepower will come next week.
Video Extreme flight rc mxs-exp EXTREME FLIGHT Electric Plane Talk 12 Jul 21, 2014 06:24 PM
Discussion EXTREME FLIGHT MXS EXP part 2-First prototype assembly and evaluation process EXTREME FLIGHT 3D Flying 2178 May 13, 2012 10:51 PM
Sold 48" Extreme Flight Edge 540T-EXP red white blue -$320 ARTF AirRaider_2009 Aircraft - Electric - Airplanes (FS/W) 5 Nov 07, 2010 10:50 PM
Sold 48" Edge EXP Extreme Flight, make offer crazyflyin Aircraft - Electric - Airplanes (FS/W) 9 Sep 14, 2010 06:45 AM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 02:48 PM
