Old Sep 15, 2010, 08:28 AM
rcbirk21 is offline
Find More Posts by rcbirk21
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
Originally Posted by Twisted Realm View Post
I've owned 12 of the MG14's and had one failure, they have a bite to much slop/play for me, but they are descent servo for the price. A realy nice quality alternative are the blue birds 373mg's. I now stick with these guys in all my 42-48" size birds. http://www.hobbycity.com/hobbycity/s....13sec_/_11.4g
so they are more of a hs65mg replacement?
rcbirk21 is offline Find More Posts by rcbirk21
Old Sep 15, 2010, 09:10 AM
nac is offline
nac
Find More Posts by nac
nac
nac's Avatar
Melbourne, Australia
Build part 2
My build is progressing well.
One major pain in the butt is the holes for the SFG's.
They are totally blocked and I have been trying for ages to clear them without luck. I am going to have to just use some self tapping screws!
nac is offline Find More Posts by nac
Old Sep 15, 2010, 09:27 AM
Twisted Realm is offline
Find More Posts by Twisted Realm
Twisted Realm's Avatar
United States, FL
Joined Aug 2008
I like them a lot more than the MG14's.
Looking good nac!
Twisted Realm is offline Find More Posts by Twisted Realm
Site Sponsor
Old Sep 15, 2010, 06:06 PM
dukeofearl is offline
Find More Posts by dukeofearl
3D crazy
dukeofearl's Avatar
Australia, QLD, Warwick
Joined Aug 2010
nac, do the long servo arms come in the kit for the ailerons. Also how does your nose cone fit with that motor being 45mm long, do you have much overhang for mounting. Rated 600w should give you plenty on power.
dukeofearl is offline Find More Posts by dukeofearl
Old Sep 15, 2010, 07:08 PM
nac is offline
nac
nac
nac's Avatar
Hey guys, thanks for your responses.
The kit does come with two servo arms for the elevator and rudder.
But I actually didn't use them and instead used some CF ones from HobbyCity.
I used these 40mm ones for the ailerons and rudder:-
http://www.hobbycity.com/hobbyking/s...%282pcs/bag%29
And this 58mm one for the elevator:-
I haven't fitted the cowl on yet, I'll do that when I get home today. It will fit but only just. The motor itself should sit flush with the front of the cowl with the aluminium prop mount sticking out. The only issue with this is that a spinner will stick out a bit.
NAC
Old Sep 16, 2010, 12:33 AM
3D crazy
dukeofearl's Avatar
Joined Aug 2010
The motor I used on my EF Edge is 42mm long and only just fits. I have ordered the below motor at 40mm long for the MXS hoping I would have a bit more room to move plus at 600w should give plenty of power.
http://www.hobbycity.com/hobbyking/s...idproduct=7708
Old Sep 16, 2010, 12:59 AM
nac is offline
nac
nac
nac's Avatar
Actually I have used one of those motors in the past on an PA Ultimate AMR. On 4S with a 13x6.5 prop I measured just over 2kg static thrust, so with a bigger prop you be right.
Old Sep 16, 2010, 01:46 AM
3D crazy
dukeofearl's Avatar
Joined Aug 2010
Cool... I will be using a 14x7 at this stage. How did the motor perform overall, would you buy another?
Old Sep 16, 2010, 03:31 AM
3D crazy
dukeofearl's Avatar
Joined Aug 2010
Looking real good nac, the spinner finishes it off. What size prop is that?
Old Sep 16, 2010, 05:14 AM
nac is offline
nac
nac
nac's Avatar
The prop is an APC 13x6.5E
I need to get a red spinner
Old Sep 16, 2010, 06:11 AM
United States, FL
Joined Aug 2008
Originally Posted by nac View Post
Actually I was quite happy with the SK motor and never had any real problems.
OK so most of my build is now done.
I just need to put on the stickers and do some adjustments.
nac, I'm using the 35-42-1000kv in my EF Edge I like them to so far so good.
http://www.hobbycity.com/hobbyking/s..._1000Kv_/_605w
Site Sponsor
Old Sep 16, 2010, 06:44 AM
nac is offline
nac
nac
nac's Avatar
Cool!
What prop are you using? Are you using 3S or 4S?
Old Sep 16, 2010, 06:47 AM
United States, FL
Joined Aug 2008
Cool!
3s and I started with 13x6.5 and bumped up to the 14x7. I might back down to bring down the watts since it had plenty of snot with the 13x6.5. I'm assuming your going to run 4s with your 750kv?
Site Sponsor
Old Sep 16, 2010, 08:35 AM
nac is offline
nac
nac
nac's Avatar
Nah, I don't have the 750kv motor any more.
I am using an SK3542-1000 with S3 nano-tech 2650mAh 35-70C Lipo's.
BTW it is finished!
Now I just need some nice weather to maiden.
Video Extreme flight rc mxs-exp EXTREME FLIGHT Electric Plane Talk 12 Jul 21, 2014 06:24 PM
Discussion EXTREME FLIGHT MXS EXP part 2-First prototype assembly and evaluation process EXTREME FLIGHT 3D Flying 2178 May 13, 2012 10:51 PM
Sold 48" Extreme Flight Edge 540T-EXP red white blue -$320 ARTF AirRaider_2009 Aircraft - Electric - Airplanes (FS/W) 5 Nov 07, 2010 10:50 PM
Sold 48" Edge EXP Extreme Flight, make offer crazyflyin Aircraft - Electric - Airplanes (FS/W) 9 Sep 14, 2010 06:45 AM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 02:48 PM
