Old Jan 09, 2013, 02:07 AM
bryansifsof44 is online now
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
C rating is more then you would need and higher C rated batts usually weigh more but will work fine. If thats what you have use it. With the stock setup I think I was getting 43 amps so 43A/2.5Ah=17.2C. A good true rated 25C would work great.
My batts are between 285-300g for my 2500-2650s and some others are using 2200s in the 260g range. I think the 2500 and 2650s area good balance between flight time and performance, but keep in mind I don't care for the floaty setup.
bryansifsof44 is online now Find More Posts by bryansifsof44
Old Jan 09, 2013, 05:43 AM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
Yup, same here. Although when mine take a dump I may try some 2200's to lighten up a little.
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old Jan 09, 2013, 07:24 AM
Liberty10 is offline
Find More Posts by Liberty10
Yin & Yang
Liberty10's Avatar
United States, VA, Sterling
Joined Jul 2011
thunder power Lite 25C 2700 with connector 254g i bought 1 to see how it does in my Edge
Liberty10 is offline Find More Posts by Liberty10
Old Jan 09, 2013, 09:28 AM
jw357_23043 is offline
Find More Posts by jw357_23043
Shut up and Fly!!!
jw357_23043's Avatar
United States, VA, Hartfield
Joined Aug 2011
Originally Posted by Chris Avllino View Post
Quick question.. Think the answer is yes. Flying stock setup will this work for battery setup? Is the C rating too high?
4S 14.8V 2500mAh 55C RC LiPo Battery Pack
I fly with a 45c and honestly like how it handles than the lighter 25 to 30c packs.
jw357_23043 is offline Find More Posts by jw357_23043
Old Jan 09, 2013, 12:21 PM
Chuck is offline
Find More Posts by Chuck
Balsa to the Wall
Chuck's Avatar
Deep in the East Texas Piney Woods
Joined Dec 2001
I have an Airboss ESC question
I bought the combo with the Airboss ESC, and there is a point in the throttle, I think at about 40%, there is a jump in power, like a change of gears. It's very annoying trying to do harrier rolls, especially. Anyone else having this happen?
Chuck
Chuck is offline Find More Posts by Chuck
Old Jan 09, 2013, 12:27 PM
stgdz is offline
Find More Posts by stgdz
One blade in the water is wet
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Do you have an idle mix programmed?
stgdz is offline Find More Posts by stgdz
Old Jan 09, 2013, 01:07 PM
Chuck is offline
Balsa to the Wall
Chuck's Avatar
Joined Dec 2001
No, I don't ever use an idle mix on anything. Will that help?
Also, does ZTW make Airboss ESC's? The reason I ask, I just talked to a friend who's building a P-51 with a ZTW ESC, and he has noticed the same thing happening with it.
Chuck
Old Jan 09, 2013, 01:20 PM
Doc Austin is offline
Find More Posts by Doc Austin
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Give this a look..............
Throttle Mix For Better Performance
Doc Austin is offline Find More Posts by Doc Austin
Old Jan 09, 2013, 01:30 PM
Chuck is offline
Balsa to the Wall
Chuck's Avatar
Joined Dec 2001
OK, I'll try it. All my other ESC's are CC and I haven't had this happen with them.
Thanks for the feedback.
Chuck
Old Jan 09, 2013, 01:37 PM
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
I
Something worth asking is if you are coming from flying 3s. If you are used to that, 4s power can be a little spikey by comparison. 4s is kind of like having a turbo and there is a point where the boost comes on with a bang. This was happening with other ESCs I tried and the Airboss still had the smoothest delivery.
I've been flying 4s for so long that I don't notice, but when I go back to 3s throttle control is much easier and the plane is much more docile all the way around.
Old Jan 09, 2013, 01:56 PM
Chuck is offline
Balsa to the Wall
Chuck's Avatar
Joined Dec 2001
Good question, but no, I have 1s to 6s planes, for example, a Velox on 4s, 59" Slick and a 60" EF Edge(no. 2) on 6s and the throttle response on all is very linear. This only happens with the MXS.
Chuck
Old Jan 09, 2013, 02:38 PM
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Odd. Try resetting the programming to default. It's pssible you may have changed something in the programming when setting the plane up. Everything works best on the Airboss (Assuming you also have a Torque motor) when set to default anyway.
Old Jan 09, 2013, 05:44 PM
Chuck is offline
Balsa to the Wall
Chuck's Avatar
Joined Dec 2001
Thanks, Doc, I'll try the idle up and see what happens.
If we ever get any flying weather again.
Chuck
Old Jan 09, 2013, 06:16 PM
Shut up and Fly!!!
Joined Aug 2011
Chuck
My Castle Ice Lite 50 does the same thing. Gonna try and take it out with a throttle curve if possible.
Old Jan 09, 2013, 06:24 PM
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Call Bernie at Castle.The guy is on top of it and will know what to tell you to do. I will bet that he tells you to download the newest software and set it up for Outrunner mode.
Please send Bernie my best while you're there. He helped me out a lot when I first got into electrics.
Video Extreme flight rc mxs-exp EXTREME FLIGHT Electric Plane Talk 12 Jul 21, 2014 07:24 PM
Discussion EXTREME FLIGHT MXS EXP part 2-First prototype assembly and evaluation process EXTREME FLIGHT 3D Flying 2178 May 13, 2012 11:51 PM
Sold 48" Extreme Flight Edge 540T-EXP red white blue -$320 ARTF AirRaider_2009 Aircraft - Electric - Airplanes (FS/W) 5 Nov 07, 2010 11:50 PM
Sold 48" Edge EXP Extreme Flight, make offer crazyflyin Aircraft - Electric - Airplanes (FS/W) 9 Sep 14, 2010 07:45 AM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 03:48 PM
