Old Dec 28, 2012, 12:00 PM
Liberty10 is offline
Find More Posts by Liberty10
Yin & Yang
Liberty10's Avatar
United States, VA, Sterling
Joined Jul 2011
I see it as an added safety that nothing comes apart. I didn't see it on the 48" build videos but it def. is there on the 60" airframes.
I flew without it for over 100 flights on my 48" Edge before I had the brain fart not remembering I had hit the low rate switch. In my defense I had the "Guy" that loves to talk in my ear yapping away. As poor an excuse as it is it was the reason... I have it's replacement waiting for a good day to get it in the air again.
NOTE: when I put the collar on mine I had to take the Dremel w/ drum sander to the firewall hole so it cleared. Mine was a pure bind but I can see how it could just rub a bit and be overlooked. None of my shafts had a flat spot so I used the metal cutting wheel to grind a small flat spot for the set screw. And always use locktite on metal to metal screw connections to prevent vibration from loosening them.
Liberty10 is offline Find More Posts by Liberty10
Old Dec 28, 2012, 12:39 PM
Vince_TT is offline
Find More Posts by Vince_TT
United States, PA, Philadelphia
Joined Dec 2011
I did have a prop/rotor/shaft ejection once, its was because I cut down a high pitch prop (9x9 down to 7x9) and did a lousy job on balancing it. The vibration took the c-clip out at 70+ mile. If I had the collar on I would have saved that plane.
Have three more flights on MXS on Christmas day. Slowly getting used to this plane. However, when I taxied her back after the third landing, the right wheel, axis and pant got totally ripped off the LG. To be fare, my field is rough and bumpy. I have broke three Dubro micro sport wheels at taxiing on my 42" Slick already. I am wondering if Extra's LG can handle the job better?
Vince_TT is offline Find More Posts by Vince_TT
Old Dec 28, 2012, 12:46 PM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Extra will flex a bit more
stgdz is offline Find More Posts by stgdz
Old Dec 29, 2012, 06:12 AM
rimaarts is offline
Find More Posts by rimaarts
United Kingdom, London
Joined Jul 2011
extra gear is not beefier, its just designed diferently, so it turns out a bit stronger... laser gear seems beefier, but lets see how it handles my field..
rimaarts is offline Find More Posts by rimaarts
Old Dec 29, 2012, 04:40 PM
TheMagician007 is offline
Find More Posts by TheMagician007
TheMagician007's Avatar
United States, CA, Carlsbad
Joined Apr 2012
Rates and Expo
So I'm an MXS virgin...been flying 3D foamies, dynam biplane and su-26 and parkzone extra 300...I'm not nervous about speed or power, more about the crazy throws. I always had everything at its highest, but wondering if you can give any recommendations to a newbie in the balsa world.
Obviously I don't want to crash on my first few flights so I can get used to the plane. Having such large control surfaces is/are a bit intimidating.
Recommendations on expo and rates?
TheMagician007 is offline Find More Posts by TheMagician007
Old Dec 29, 2012, 04:50 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
This is what I had when I started on the 48
Full throws, expo of 75 on ailerons.
Full throws, expo of 70 on elevator.
Full throws, expo of 75 on rudder.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Dec 29, 2012, 05:03 PM
jw357_23043 is offline
Find More Posts by jw357_23043
Shut up and Fly!!!
jw357_23043's Avatar
United States, VA, Hartfield
Joined Aug 2011
+1 That is what I fly with as well.
jw357_23043 is offline Find More Posts by jw357_23043
Old Dec 29, 2012, 06:32 PM
Blucross is offline
Find More Posts by Blucross
Gravity is a cruel mistress...
Blucross's Avatar
United States, FL, Orlando
Joined Mar 2011
I flew that way for the maiden and a few packs after but felt like the 80 degrees of elevator was too much and I had a hard time adjusting on approach for landings. I was over correcting too much. I've since dialed it down to 45 degrees and it's much better for me now. All other surfaces are at max throws with 70ish expo.
Blucross is offline Find More Posts by Blucross
Old Dec 29, 2012, 10:28 PM
Shut up and Fly!!!
Joined Aug 2011
Go back to 80 degrees of throw and just bump your expo up to 75.
Old Dec 30, 2012, 12:50 AM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
Or set up a low rate on the elevator.
hone1er is offline Find More Posts by hone1er
Old Dec 30, 2012, 01:07 AM
Yin & Yang
Liberty10's Avatar
Joined Jul 2011
+1 Hone1er
Dual rates is just one more tool to make us better pilots. An a great tool at that.
Old Dec 30, 2012, 02:10 AM
morrigan is offline
Find More Posts by morrigan
morrigan's Avatar
Deutschland, BW, Ebersbach an der Fils
Joined May 2011
Hi,
I always Use a switch for Low Rates. On maiden flight i usually take 50% of the recommend throws on the Low rate.
With Full deflection it could really be hard if something is Not correct with the Setup.
Later i Use the Low setup for landing. I dont Like Full deflection at the elevator for landing.
Bernd
morrigan is offline Find More Posts by morrigan
Old Dec 30, 2012, 04:21 AM
bryansifsof44 is offline
Find More Posts by bryansifsof44
bryansifsof44's Avatar
United States, AK, Anchorage
Joined Oct 2011
I'm the opposite I use full rates right from the get go including maiden... feel more comfortable in high rates. Point the nose up and hit the gas if you get in trouble. I just started using a low rate to practice high speed stuff, but I don't feel right getting low going fast yet in low rate.
bryansifsof44 is offline Find More Posts by bryansifsof44
Old Dec 30, 2012, 11:12 AM
Doc Austin is offline
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
You're a great pilot though. I think the new guys who are not used to all the throw are better off using thier low rates for general flying around and flip to high when they want to get crazy. Most guys don't take long to get to be flying full rates all the time, bit in the beginning it's a nice security tool for them.
For the longest time I never even bothered to set up a low rate, but at Chris' urging I started using one for my precision stuff. Man, it is so much easier that way. It was just a matter of trying it and getting comfortable. It is much like a pattern plane, but from years of full tilt, full time 3D rates, I had to adjust my style a little. Now I just have to remember which rate I am on and not try anything like a parachute on low rates.
New guys If you have triple rates that is the way to go. Set the low rate up using the manual. That's a precision rare and it is very, very easy to fly. Anyone who can handle a T28 will find themselves right at home on this low rate.
Then, then set the medium rate up using the high rate from the maual and restricting the elevator throw to 45 degrees. For the high rate, crank in all the elevator you can get.
The reason I like a meduim rate with 45 degrees is because the plane harriers much easier like this, and easy is important when you are learning 3D or switching to a new airframe. If you only have dual rates, in the beginning you can dial the high elevator back to 45 degrees until you have a good feel for the plane, and then go to the full 88 degrees when you are very comfortable.
Set up is a very personal thing, which is why there are so many different opinion on it. However, Chris spends a lot of time developing the low rates for these airframes and it makes sense to start there.
Doc Austin is offline Find More Posts by Doc Austin
Old Dec 30, 2012, 11:20 AM
Joined Oct 2011
Totally... It was not my intention to give bad advice for the new guys which should start on low rates and work up of that. I was simply saying what works best for me.
Video Extreme flight rc mxs-exp EXTREME FLIGHT Electric Plane Talk 12 Jul 21, 2014 06:24 PM
Discussion EXTREME FLIGHT MXS EXP part 2-First prototype assembly and evaluation process EXTREME FLIGHT 3D Flying 2178 May 13, 2012 10:51 PM
Sold 48" Extreme Flight Edge 540T-EXP red white blue -$320 ARTF AirRaider_2009 Aircraft - Electric - Airplanes (FS/W) 5 Nov 07, 2010 10:50 PM
Sold 48" Edge EXP Extreme Flight, make offer crazyflyin Aircraft - Electric - Airplanes (FS/W) 9 Sep 14, 2010 06:45 AM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 02:48 PM
